I've run auto format:
Here is the formatted code
#include <LiquidCrystal.h>
#include <Wire.h>
#include <Password.h> //http://www.arduino.cc/playground/uploads/Code/Password.zip
#include <Keypad.h> //Arduino Playground - HomePage
//Password
Password password = Password( "1234" );
const byte ROWS = 4; // Four rows
const byte COLS = 4; // Four columns
char keys[ROWS][COLS] = { // Define the Keymap
'1', '2', '3', 'A'
'4', '5', '6', 'B'
'7', '8', '9', 'C'
'*', '0', '#', 'D'
byte rowPins[ROWS] = {
46, 47, 48, 49
}; //connect to the row pinouts of the keypad
byte colPins[COLS] = {
50, 51, 52, 53
}; //connect to the column pinouts of the keypad
// Create the Keypad
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(7, 8, 9, 10, 11, 12); // Assignign arduino pins to LCD display module
//Stroke LED Lights
int ledDelay = 50; // delay by 50ms
int redPin = 29;
int bluePin = 31;
//constants for LEDs, inputs and outputs
//int blueLED = 36;
int greenLED = 37;
int redLED = 38;
int pirPin1 = 39;
int pirPin2 = 34;
int reedPin1 = 41;
int reedPin2 = 42;
int speakerPin = 35;
int alarmStatus = 0;
int zone = 0;
int alarmActive = 0;
lcd.begin(20, 4);
//Adding time
Wire.begin();
displayCodeEntryScreen();
//Police LED Lights
pinMode(redPin, OUTPUT);
pinMode(bluePin, OUTPUT);
//setup and turn off both LEDs
pinMode(redLED, OUTPUT);
pinMode(greenLED, OUTPUT);
pinMode(speakerPin, OUTPUT);
pinMode(pirPin1, INPUT); //Bedroom 2
digitalWrite(redLED, LOW);
digitalWrite(greenLED, HIGH);
digitalWrite(speakerPin, LOW);
keypad.getKey();
//Serial.println(digitalRead(reedPin2));
//Serial.println(digitalRead(pirPin));
//Serial.println(digitalRead(pirPin2));
if (alarmActive == 1) {
if (digitalRead(pirPin1) == HIGH)
zone = 0;
alarmTriggered();
if (digitalRead(reedPin1) == LOW)
zone = 1;
alarmTriggered();
if (digitalRead(reedPin2) == LOW)
zone = 2;
alarmTriggered();
if (digitalRead(pirPin2) == HIGH)
zone = 3;
alarmTriggered();
///////////////////////// Functions /////////////////////////////////
//take care of some special events
void keypadEvent(KeypadEvent eKey) {
switch (keypad.getState()) {
case PRESSED:
return ;
lcd.setCursor
void checkPassword() {
checkPassword();
; case '': // is to reset password attempt
password.reset();
// TODO: clear the screen output
default:
password.append(eKey);
lcd.print("*");
void alarmTriggered() {
int expected_pos;
int incr;
digitalWrite(speakerPin, HIGH);
digitalWrite(redPin, HIGH);
password.reset();
alarmStatus = 1;
// alarmActive = 0;
lcd.clear();
lcd.setCursor(0, 2);
lcd.print(" SYSTEM TRIGGERED ");
lcd.setCursor(0, 4);
if (zone == 1)
if (zone == 0) {
expected_pos = 40;
lcd.print("Motion in Passage");
if (expected_pos > pos) {
incr = 1;
incr = -1;
StrokeLight();
void StrokeLight() { //Stroke LED Lights
digitalWrite(redPin, HIGH); // turn the red light on
delay(ledDelay); // wait 50 ms
digitalWrite(redPin, LOW); // turn the red light off
void checkPassword() { // To check if PIN is corrected, if not, retry!
if (password.evaluate())
if (alarmActive == 0 && alarmStatus == 0)
activate();
else if ( alarmActive == 1 || alarmStatus == 1) {
deactivate();
else {
invalidCode();
void invalidCode() // display meaasge when a invalid is entered
password.reset();
lcd.clear();
lcd.setCursor(1, 0);
lcd.print("INVALID CODE! LOL!");
lcd.setCursor(5, 2);
lcd.print("TRY AGAIN!");
digitalWrite(greenLED, LOW);
digitalWrite(redLED, HIGH);
delay(2000);
void activate() // Activate the system if correct PIN entered and display message on the screen
if ((digitalRead(reedPin1) == HIGH) && (digitalRead(reedPin2) == HIGH)) {
digitalWrite(2, HIGH);
lcd.setCursor(0, 0);
lcd.print("SYSTEM ACTIVE!");
alarmActive = 1;
password.reset();
delay(2000);
else {
deactivate(); // if PIN not corrected, run "deactivate" loop
void deactivate()
//digitalWrite(camera, LOW);
alarmStatus = 0;
lcd.clear();
lcd.print(" SYSTEM DEACTIVATED!");
alarmActive = 0;
password.reset();
delay(5000);
digitalWrite(relay2, HIGH);
digitalWrite(relay3, HIGH);
void displayCodeEntryScreen() // Dispalying start screen for users to enter PIN
lcd.clear();
lcd.print("Enter PIN:");
lcd.print("Home Security System");
lcd.setCursor(0, 3);
lcd.print("By Andrew O'Brien, B4");
