When I enter a digit on the project keyboard, it is overwritten and does not break the line to be displayed on the screen
Good morning, I'm having a problem with my Arduino project because
the code doesn't do what's shown in the video
I took it from, even though it's the same code and the same project with the same components.
Here's the video of the project. I really need to do this project, but I don't have time.
If anyone could tell me what I should change in the code or modify it, it would save my life.
This is the Arduino code
/*Thanks. Remember to visit my Youtube channel
  I've used a i2c LCD screen module and 9g servo motor.
//LCD config
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27,16,2);
#include <Servo.h>
#include <Keypad.h>
//Variables
int mot_min = 90;   //min servo angle  (set yours)
int mot_max = 180; //Max servo angle   (set yours)
int character = 0;
int activated =0;
char Str[16] = {' ', ' ', ' ', ' ', ' ', ' ', '-', '*', '*', '*', ' ', ' ', ' ', ' ', ' ', ' '};
//Pins
Servo myservo;
int buzzer=11;     //pin for the buzzer beep
int external = 12; //pin to inside open
int internal = 13; //pin to inside close
//Keypad config
const byte ROWS = 4; //four rows
const byte COLS = 4; //four columns
//define the cymbols on the buttons of the keypads
char hexaKeys[ROWS][COLS] = {
  {'1','4','7','*'},
  {'2','5','8','0'},
  {'3','6','9','#'},
  {'A','B','C','D'}
byte rowPins[ROWS] = {5, 4, 3, 2}; //connect to the row pinouts of the keypad
byte colPins[COLS] = {9, 8, 7, 6}; //connect to the column pinouts of the keypad
//initialize an instance of class NewKeypad
Keypad customKeypad = Keypad( makeKeymap(hexaKeys), rowPins, colPins, ROWS, COLS);
void setup(){
  myservo.attach(10); //attach the servo to pin D10
  pinMode(buzzer,OUTPUT);
  pinMode(external,INPUT);
  pinMode(internal,INPUT);
  //Init the screen and print the first text
  lcd.init();
  lcd.backlight();
  lcd.clear();
  lcd.print("    PASSWORD");
  lcd.setCursor(0,1);
  lcd.print("      -***     ");
  //put the servo in the close position first
  myservo.write(mot_min);
void loop(){
///////////////EMERGENCY OPEN/CLOSE/////////
  if (digitalRead(external))
     myservo.write(mot_max);
      lcd.clear();
      lcd.setCursor(2,0);
      lcd.print("INSIDE  OPEN");
      activated = 2;
      analogWrite(buzzer,240);
      delay(250);
      analogWrite(buzzer,200);
      delay(250);
      analogWrite(buzzer,180);
      delay(250);
      analogWrite(buzzer,250);
      delay(250);
      analogWrite(buzzer,LOW);
      lcd.clear();
      lcd.setCursor(4,0);
      lcd.print("WELLCOME");
      lcd.setCursor(2,1);
      lcd.print("ELECTRONOOBS");
      lcd.clear();
      lcd.setCursor(3,0);
      lcd.print("DOOR  OPEN");
      lcd.setCursor(2,1);
  if (digitalRead(internal))
    activated = 0;
    character=0;
    Str[6]= '-';
    Str[7]= '*';
    Str[8]= '*';
    Str[9]= '*';
    Str[10]= ' ';
    lcd.clear();
    lcd.setCursor(0,0);
    lcd.setCursor(0,1);
    lcd.print(Str);
///////////////KEYPAD OPEN/CLOSE////////////
  char customKey = customKeypad.getKey(); //this function reads the presed key
  if (character < 4) {  // Se asegura de que solo tome 4 caracteres
    Serial.println(customKey);
    Str[6 + character] = customKey; // Guarda el número en la posición correcta
    character++;  // Incrementa el índice
    lcd.clear();  // Borra la pantalla antes de mostrar la nueva contraseña
    lcd.setCursor(0,0);
    lcd.setCursor(0,1);
    lcd.print(Str);
  if (activated == 1)
/*Change your password below!!!
Change each of Str[6], Str[7], Str[8], Str[9]*/
    if(Str[10]='A' && character==5 && Str[6]=='3' && Str[7]=='0' && Str[8]=='0' && Str[9]=='7' )
      lcd.clear();
      lcd.setCursor(4,0);
      lcd.print("ACCEPTED");
      activated = 2;
      delay(250);
      delay(250);
      delay(250);
      delay(250);
      lcd.clear();
      lcd.setCursor(4,0);
      lcd.setCursor(2,1);
      lcd.clear();
      lcd.setCursor(3,0);
      lcd.setCursor(2,1);
      lcd.clear();
      lcd.setCursor(1,0);
      lcd.print("PASSWORD ERROR");
      lcd.setCursor(3,1);
      lcd.print("TRY  AGAIN");
      analogWrite(buzzer,150);
      delay(3000);
      character=0;
      Str[6]= '-';
      Str[7]= '*';
      Str[8]= '*';
      Str[9]= '*';
      Str[10]= ' ';
      activated = 0;
      lcd.clear();
      lcd.setCursor(4,0);
      lcd.print("PASSWORD");
      lcd.setCursor(0,1);
      lcd.print(Str);
  if (activated == 2)
    if(customKey == 'B' )
      activated = 0;
      character=0;
      Str[6]= '-';
      Str[7]= '*';
      Str[8]= '*';
      Str[9]= '*';
      Str[10]= ' ';
      lcd.clear();
      lcd.setCursor(0,0);
      lcd.setCursor(0,1);
      lcd.print(Str);
This is the scheme
This is how the screen looks like with the red circle where it stays blinking and if I type several times the same number will always be entered in the same position.
When I run the code to make the project functional and display the password screen so that the password can be entered on the Mitral keyboard, below the password there are asterisks that hide the characters and cover the password. I want to know why when I enter the password it is overwritten in the same position without making a line break to enter the second digit of the password, and even if I press enter, it does not allow me to enter at least an incorrect password.
You wrote the code that does that; did you mean to do something else?
One potential problem is the way that your momentary closure switches have been wired:
This would correspond to the following arrangement, which will make pins 12 and 13 HIGH always (whether the button is pushed or not):
Got nothing with the actual question,
but remove the resistor, connect one end of the button to the IO pin and the other to GND. Then replace
and
with
  pinMode(external,INPUT_PULLUP);
and
if (digitalRead(external, LOW))
Is this some undocumented feature of digitalRead(), and if so, what does it do?
Or did you mean
if (!digitalRead(external))
I wonder if it is. Can you post a link to the original source code?
This
uses the value customKey uncritically, that is to say it returns 0 when you do not press a button, but the rest of the code goes on to think there is a valid button press.
I'm happy to help you fix the code you found, but let's be sure you are working with the code you found and not something you've messed with and broke.
a7
It's super undocumented :wink:
Hello, the page where I got the code is here How to make Keypad door lock using arduino and servo
I have not modified the code at any time and have only copied and pasted it.
Can you show where in the original code this is:
Where did all of this go?
  if (customKey){
    if (character ==0)
    Str[6]= customKey;
    lcd.clear();
    lcd.setCursor(0,0);
    lcd.setCursor(0,1);
    lcd.print(Str);
    if (character ==1)
    Str[7]= customKey;
    lcd.clear();
    lcd.setCursor(0,0);
    lcd.setCursor(0,1);
    lcd.print(Str);
    if (character ==2)
    Str[8]= customKey;
    lcd.clear();
    lcd.setCursor(0,0);
    lcd.setCursor(0,1);
    lcd.print(Str);
    if (character ==3)
    Str[9]= customKey;
    lcd.clear();
    lcd.setCursor(0,0);
    lcd.setCursor(0,1);
    lcd.print(Str);
    if (character ==4)
    Str[10]= customKey;
    activated=1;
    character=character+1;
Here's a suggestion: Click NEW SKETCH in the IDE, then press Ctrl+A, followed by Del. Next, copy the code below, and paste it into your empty sketch (using Ctrl+V). Verify (compile) the code, and if there are no errors, upload it.
//LCD config
#include <Wire.h>
LiquidCrystal_I2C lcd(0x3f,20,4);
#include <Servo.h>
#include <Keypad.h>
//Variables
int character = 0;
int activated =0;
//Pins
Servo myservo;
//Keypad config
  {'1','4','7','*'},
  {'2','5','8','0'},
  {'3','6','9','#'},
  {'A','B','C','D'}
void setup(){
  lcd.init();
  lcd.backlight();
  lcd.clear();
  lcd.setCursor(0,1);
void loop(){
      lcd.clear();
      lcd.setCursor(2,0);
      activated = 2;
      delay(250);
      delay(250);
      delay(250);
      delay(250);
      lcd.clear();
      lcd.setCursor(4,0);
      lcd.setCursor(2,1);
      lcd.clear();
      lcd.setCursor(3,0);
      lcd.setCursor(2,1);
    activated = 0;
    character=0;
    Str[6]= '-';
    Str[7]= '*';
    Str[8]= '*';
    Str[9]= '*';
    Str[10]= ' ';
    lcd.clear();
    lcd.setCursor(0,0);
    lcd.setCursor(0,1);
    lcd.print(Str);
  if (customKey){
    if (character ==0)
    Str[6]= customKey;
    lcd.clear();
    lcd.setCursor(0,0);
    lcd.setCursor(0,1);
    lcd.print(Str);
    if (character ==1)
    Str[7]= customKey;
    lcd.clear();
    lcd.setCursor(0,0);
    lcd.setCursor(0,1);
    lcd.print(Str);
    if (character ==2)
    Str[8]= customKey;
    lcd.clear();
    lcd.setCursor(0,0);
    lcd.setCursor(0,1);
    lcd.print(Str);
    if (character ==3)
    Str[9]= customKey;
    lcd.clear();
    lcd.setCursor(0,0);
    lcd.setCursor(0,1);
    lcd.print(Str);
    if (character ==4)
    Str[10]= customKey;
    activated=1;
  if (activated == 1)
      lcd.clear();
      lcd.setCursor(4,0);
      activated = 2;
      delay(250);
      delay(250);
      delay(250);
      delay(250);
      lcd.clear();
      lcd.setCursor(4,0);
      lcd.setCursor(2,1);
      lcd.clear();
      lcd.setCursor(3,0);
      lcd.setCursor(2,1);
      lcd.clear();
      lcd.setCursor(1,0);
      lcd.setCursor(3,1);
      delay(3000);
      character=0;
      Str[6]= '-';
      Str[7]= '*';
      Str[8]= '*';
      Str[9]= '*';
      Str[10]= ' ';
      activated = 0;
      lcd.clear();
      lcd.setCursor(4,0);
      lcd.setCursor(0,1);
      lcd.print(Str);
  if (activated == 2)
      activated = 0;
      character=0;
      Str[6]= '-';
      Str[7]= '*';
      Str[8]= '*';
      Str[9]= '*';
      Str[10]= ' ';
      lcd.clear();
      lcd.setCursor(0,0);
      lcd.setCursor(0,1);
      lcd.print(Str);
The code @grb posted works better, almost works period.
I did have to add a few lines to setup():
  Serial.println("\nOops!\n");
I used the internal pullups (pinMode INPUT_PULLUP) and changed the pushbutton logic both places to match:
# define PRESST LOW
void loop(){
  if (digitalRead(external) == PRESST)
For my keypad, the rows and columns were reversed, so I swapped the pin number array initial values.
If this is not at least limping along, it is the fact that you bungled the code somewhere along the line, or you have outstanding wiring or other not-the-software problems.
"3007A" opens the servo thing. "B" closes it. The pushbuttons operate immediately and require no password. I did not investigate what else is possible.
It prints garbage on the 4th line of the LCD, I leave that as an exercise for the reader to figure out and fix.
a7
The code that I posted was copied verbatim from the electronnoobs tutorial that had been linked by OP above.
But how can that be?
Your other topics on the same subject have been deleted or locked
Please do not duplicate your questions as doing so wastes the time and effort of the volunteers trying to help you as they are then answering the same thing in different places.
Please create one topic only for your question and choose the forum category carefully. If you have multiple questions about the same project then please ask your questions in the one topic as the answers to one question provide useful context for the others, and also you won’t have to keep explaining your project repeatedly.
Repeated duplicate posting could result in a temporary or permanent ban from the forum.
Could you take a few moments to Learn How To Use The Forum
Thank you.
