Code Error
I have a problem with my code , it say "ReadDistance" was not declared in this scope. I dont understand , i tried put " int x; " but didnt work.
Can someone help , I have to make a presentation for my project next week bruhhh
#include <Wire.h>
unsigned char ok_flag;
unsigned char fail_flag;
unsigned short lenth_val = 0;
unsigned char i2c_rx_buf[16];
unsigned char dirsend_flag=0;
const int echoPin = 2;
const int trigPin = 3;
const int buzzer1 = 4;
const int buzzer2 = 5;
const int ledRed = 8;
const int ledYellow = 9;
const int ledGreen = 10;
const int relay = 11;
  Wire.begin();
  Serial.begin(9600,SERIAL_8N1);
  printf_begin();
   int x=ReadDistance();
   Serial.print(x);
   Serial.println(" mm");
int serial_putc( char c, struct __file * )
  Serial.write( c );
  return c;
void printf_begin(void)
  fdevopen( &serial_putc, 0 );
if (x <=30 && x >20 )
  digitalWrite(10,HIGH);
else if (x <= 20 && x >10)
  digitalWrite(10,LOW);
  digitalWrite(buzzer1,HIGH);
  digitalWrite(9,HIGH);
else if(x <=10)
  digitalWrite(buzzer1,LOW);
  digitalWrite(9,LOW);
  digitalWrite(buzzer2,HIGH);
  digitalWrite(8,HIGH);
  digitalWrite(11,HIGH);
  digitalWrite(buzzer2,LOW);
  digitalWrite(8,LOW);
  digitalWrite(11,LOW);
delay (100);
void SensorRead(unsigned char addr,unsigned char* datbuf,unsigned char cnt)
  unsigned short result=0;
  // step 1: instruct sensor to read echoes
  Wire.beginTransmission(82); // transmit to device #82 (0x52)
  // the address specified in the datasheet is 164 (0xa4)
  // but i2c adressing uses the high 7 bits so it's 82
  Wire.write(byte(addr));      // sets distance data address (addr)
  Wire.endTransmission();      // stop transmitting
  // step 2: wait for readings to happen
  delay(1);                   // datasheet suggests at least 30uS
  // step 3: request reading from sensor
  Wire.requestFrom(82, cnt);    // request cnt bytes from slave device #82 (0x52)
  // step 5: receive reading from sensor
  if (cnt <= Wire.available()) { // if two bytes were received
    *datbuf++ = Wire.read();  // receive high byte (overwrites previous reading)
    *datbuf++ = Wire.read(); // receive low byte as lower 8 bits
int ReadDistance(){
    SensorRead(0x00,i2c_rx_buf,2);
    lenth_val=i2c_rx_buf[0];
    lenth_val=lenth_val<<8;
    lenth_val|=i2c_rx_buf[1];
    delay(300);
    return lenth_val;
if (x <= 30 && x > 20 )
This program statement, and many more, are not in a function
You also may want to try to define your functions above setup and loop. The code is looking for a function that has not yet been defined. Or could initiate the function above setup and loop.
queenlexi13:
You're new to Arduino, aren't you?
