Not declared in this scope
Hi all
Not sure why i can only post the this area but here goes
I am not sure why I get this message
'readPing' was not declared in this scope
see attached code. I have used this code before.
Any help would be great, I am still new to this.
//Start for Skid Steer Tank project
#include <Wire.h>
#include <Adafruit_MotorShield.h>
#include <NewPing.h>
#include <Servo.h>
#define TRIG_PIN A1
#define ECHO_PIN A2
#define MAX_DISTANCE 100
const int FLIGHT_Pin = A3;
const int RLIGHT_Pin = A4;
const int LLIGHT_Pin = A5;
Adafruit_MotorShield AFMS = Adafruit_MotorShield();  // Create the Motor shield object with the default I2C address
Adafruit_DCMotor *myRightMotor = AFMS.getMotor(1);  // Select which 'port' M1, M2, M3 or M4. In this case, M1
Adafruit_DCMotor *myLeftMotor = AFMS.getMotor(4);
NewPing sonar(TRIG_PIN, ECHO_PIN, MAX_DISTANCE);
Servo myservo;
int distance = 200;
//  int readPing();
  AFMS.begin();  // create with the default frequency 1.6KHz
  myservo.attach(10);
  myservo.write(115);
  delay(2000);
   distance = readPing();
   // delay(100);
  // distance = readPing();
  // delay(100);
  // delay(100);
  // delay(100);
  myRightMotor->run(FORWARD);
    myRightMotor->setSpeed(200);
  myRightMotor->run(BACKWARD);
    myRightMotor->setSpeed(150);
  myRightMotor->run(RELEASE);
  //  Left Motor Test
  myLeftMotor->run(FORWARD);
    myLeftMotor->setSpeed(200);
  myLeftMotor->run(BACKWARD);
    myLeftMotor->setSpeed(150);
  myLeftMotor->run(RELEASE);
You do not have a function named readPing() in your sketch, hence the error
Your topic has been moved to the Programming Questions category of the forum. Could you not select that category when starting the new topic ?
There's a forward definition of the function here, but it's commented out. If you uncomment that, it will fix the error you have, but create another error because you will have a forward definition of a function but no full definition of that function.
I guess you lost part of it when you copied it over to this code.
Hi
I could not see where the Programming Topic was but have now serched a bit futher and found it
Thank You
Ok
now have uncommented " int readPing(); " above Setup and now get this error
" C:\Users\User\AppData\Local\Temp\ccG2ZC0q.ltrans0.ltrans.o: In function setup': C:\Users\User\Documents\Arduino\Skid_Steer_Tank_Start_2/Skid_Steer_Tank_Start_2.ino:34: undefined reference to readPing()'
collect2.exe: error: ld returned 1 exit status
Multiple libraries were found for "Servo.h"
Used: C:\Users\User\Documents\Arduino\libraries\Servo
Not used: C:\Users\User\AppData\Local\Arduino15\libraries\Servo
exit status 1
Compilation error: exit status 1 "
How do I fix " undifined reference to "readPing"
Sorry I am still trying to learn this coding.
Hi, @ianrusch
What model Arduino are you using?
What do you expect;
readPing();
to do.
This is the NewPing example,
// Example NewPing library sketch that does a ping about 20 times per second.
#define TRIGGER_PIN  12  // Arduino pin tied to trigger pin on the ultrasonic sensor.
#define ECHO_PIN     11  // Arduino pin tied to echo pin on the ultrasonic sensor.
#define MAX_DISTANCE 200 // Maximum distance we want to ping for (in centimeters). Maximum sensor distance is rated at 400-500cm.
NewPing sonar(TRIGGER_PIN, ECHO_PIN, MAX_DISTANCE); // NewPing setup of pins and maximum distance.
  Serial.begin(115200); // Open serial monitor at 115200 baud to see ping results.
  delay(50);                     // Wait 50ms between pings (about 20 pings/sec). 29ms should be the shortest delay between pings.
  Serial.print("Ping: ");
  Serial.print(sonar.ping_cm()); // Send ping, get distance in cm and print result (0 = outside set distance range)
  Serial.println("cm");
Note what is called to get the distance.
Did you write the code in post #1?
Thanks.. Tom.. :smiley: :+1: :coffee: :australia:
Hi Tom
this bit of code was used in an " Obstacle Avoiding Vehicle " I built and just copied all it over to the new code
I can not see any reference to " readPing " except in void Setup().
I am trying to read the distance info from the HC-SR04
I can still compile that code.
My IDE version is 2.3.2
hope this helps
Ian
readPing() was probably in another file that you forgot to copy.
Hi, @ianrusch
Is the call for distance, does your other code you copied from still compile.
The version of NewPing may have changed since you last used it.
Use the example to re-edit your new code.
Post error messages inside code tags please.
As you were thusly informed.
This is the original code but was using an old V1 Motor board
This was for a 4 motor car I am now trying to build a 2 motor skidsteer tank.
This code still compiles on all my computers.
I can not see any other references to " readPing " anywhere.
Any more ideas
Thank you
#include <AFMotor.h>
#include <Servo.h>
#define TRIG_PIN A1
#define ECHO_PIN A2
#define MAX_SPEED 150 // sets speed of DC  motors
#define RMAX_SPEED 150 //  try to set Bacward speed higher to make it move back further
#define MAX_SPEED_OFFSET 20
AF_DCMotor motor1(1, MOTOR12_64KHZ);
AF_DCMotor motor2(2, MOTOR12_64KHZ);
AF_DCMotor motor3(3, MOTOR34_64KHZ);
AF_DCMotor motor4(4, MOTOR34_64KHZ);
Servo myservo;
boolean goesForward=false;
int distance = 200;   //   change from 100 to 200 did not see much difference
int speedSet = 0;
  pinMode(FLIGHT_Pin, OUTPUT);
  pinMode (RLIGHT_Pin, OUTPUT);
  pinMode(LLIGHT_Pin, OUTPUT);
  myservo.attach(10);
  myservo.write(115);
  delay(2000);
  delay(100);
  delay(100);
  delay(100);
  delay(100);
 int distanceR = 0;
 int distanceL = 0;
 delay(40);
 if(distance<=50)   //  change from 25  to 50 this makes it stop further away
  moveStop();
  delay(100);
  moveBackward();
  delay(400);    //   increase from 200 to 400 to try and get to move back further
  moveStop();
  delay(200);
  distanceR = lookRight();
  delay(200);
  distanceL = lookLeft();
  delay(200);
  if(distanceR>=distanceL)
    turnRight();
    moveStop();
      if(distanceR>=distanceL)  // second look Rt makes it turn 180
         turnRight();
          moveStop();
    turnLeft();
    moveStop();
      if(distanceL>=distanceR)  //  added second ckeck on turn Left
         turnLeft();
          moveStop();
  moveForward();
int lookRight()
    myservo.write(50);
    int distance = readPing();
    delay(100);
    myservo.write(115);
    return distance;
int lookLeft()
    myservo.write(170);
    delay(100);
    myservo.write(115);
    return distance;
    delay(100);
int readPing() {
  delay(100);
  int cm = sonar.ping_cm();
  if(cm==0)
    cm = 250;
  return cm;
void moveStop() {
  motor1.run(RELEASE);
  motor2.run(RELEASE);
  motor3.run(RELEASE);
  motor4.run(RELEASE);
void moveForward() {
 if(!goesForward)
    goesForward=true;
    digitalWrite(A3, HIGH);  // Turn ON Forward LED
    motor1.run(FORWARD);
    motor2.run(FORWARD);
    motor3.run(FORWARD);
    motor4.run(FORWARD);
   for (speedSet = 0; speedSet < MAX_SPEED; speedSet +=2) // slowly bring the speed up to avoid loading down the batteries too quickly
    motor1.setSpeed(speedSet);
    motor2.setSpeed(speedSet);
    motor3.setSpeed(speedSet);
    motor4.setSpeed(speedSet);
    delay(5);
    // digitalWrite(A3, LOW);  // Turn OFF Forward LED
void moveBackward() {
    goesForward=false;
    motor1.run(BACKWARD);
    motor2.run(BACKWARD);
    motor3.run(BACKWARD);
    motor4.run(BACKWARD);
  for (speedSet = 0; speedSet < RMAX_SPEED; speedSet +=2) // Useing RMAX_SPEED  slowly bring the speed up to avoid loading down the batteries too quickly   works better
    delay(5);
void turnRight() {
   digitalWrite(A4, HIGH); // Turn ON Right LED
  motor1.run(FORWARD);    //  CHANGED TO FORWARD FOR STEERING TEST
  motor3.run(FORWARD);   // changed to FORWARD to try and make it move better
  digitalWrite(A4, LOW);   // Turn OFF Right LED
void turnLeft() {
  digitalWrite(A5, HIGH);   // turn ON Left LED
  motor1.run(BACKWARD);     // CHANGED TO BACKWARD FOR STEERING TEST
  motor3.run(BACKWARD);        // changed to BACKWARD to try and make it move better
  digitalWrite(A5, LOW);   // turn OFF Left LED
In the code you just posted is the "missing" function:
int readPing() {
  delay(100);
  if(cm==0)
    cm = 250;
  return cm;
Which as you can read, calls the ping_cm method for the NewPing object sonar.
a7
THANK YOU SO MUCH
that has solved my problem
You are all very helpful on this forum
I wish I could find someone I could sit down with in person to teach me how this coding works.
Ian R
