Hello All,
I am looking for Arduino code for AC Dimmer or want to combine Robotdyn AC Dimmer code with Sparkfun Touch Potentiometer as input.
i am attaching both code, can anyone help me to fix this.
I don't know anything about that particular pot or that particular code...
But if you can dim the lamp and you read the pot, you can map() the pot value to a dim level.
It's possible that the I2C communication with the pot will interfere with the dimmer-timing and that could be an issue. You also shouldn't have delay() in the pot-reading code because that will mess-up the dimmer-timing.
