stephenfitz32:
Hi Blackfin,
Just wondering can you assist with my last message for the code. I am almost completed but just need to change the Red LED from been activated on the 2nd to been activated on the 4th instead. I would much appreciate your assistance.
I had a quick look and can't see an obvious reason for what you're seeing but do have a suspicion.
First, FWIW, the EVENTS_LIMIT constant should just be an int (3) rather than a float (3.0) as we're counting integral values, not fractional values.
#define EVENTS_LIMIT 3 //# of times G limit can be exceeded before RED LED comes on
For your actual problem, my suspicion is that the bGLimitExceeded flag is being set true more than once per collision because we're sampling quickly (every 5mS) and collision events are slow, messy things.
In this version I added a dead-time of 500mS after an "event" that sets bGLimitExceeded where the threshold is not checked. This should allow the system/car to settle before allowing for checks again.
I also added a serial print in the LED state machine to print the value of nEvents after each detection as well as a millisecond timestamp. With the dead time I suspect the problem will be fixed but if not, some valuable info can be obtained from this info.
#include <Wire.h>
#include <Adafruit_MMA8451.h>
#include <Adafruit_Sensor.h>
//#define TEST_RESULTANT 1 //comment out to exclude resultant vector from g check
#define MAX_G 3.0 //g limit over which an "event" is logged (org LED etc) (individual axes)
#define MAX_G_RESULTANT 3.0 //g limit over which an "event" is logged (org LED etc) (resultant vector only)
#define ORG_LED_ONTIME 5000ul //mS orange LED flash time when G limit exceeded
#define ERROR_BLINK 300ul //mS blink time for error condition
#define SAMPLE_RATE 5000 //uS (microseconds) per sample
#define CHK_DEADTIME 100 //uS = CHK_DEADTIME x SAMPLE_RATE
#define LOGGING_RATE 100 //mS between logging file writes
const int pinORANGE = 13; //pin driving orange LED. Logic assumes HIGH turns LED on
const int pinRED = 12; //pin driving red LED. Logic assumes HIGH turns LED on
Adafruit_MMA8451 mma = Adafruit_MMA8451();
char
szStr[50];
//accumulators for x, y and z axes averaging
//samples are taken once per millisecond
//average is written to SD card at 100mS intervals
float
xg_f,
yg_f,
zg_f,
xg_sum,
yg_sum,
zg_sum;
unsigned long
sample_count;
bool
bGLimitExceeded;
pinMode( pinORANGE, OUTPUT );
digitalWrite( pinORANGE, LOW ); //LED off.
pinMode( pinRED, OUTPUT );
digitalWrite( pinRED, LOW ); //LED off.
Serial.println("Adafruit MMA8451 OK");
if (!mma.begin())
Serial.println("###Failed to start MMA8451.");
ErrorLED();
}//if
Serial.println("MMA8451 found!");
mma.setRange(MMA8451_RANGE_4_G); //need +/-4g for checking >3g...
Serial.print(" Range = "); Serial.print(2 << mma.getRange());
Serial.println("G");
bGLimitExceeded = false;
xg_sum = 0.0;
yg_sum = 0.0;
zg_sum = 0.0;
sample_count = 0;
}//setup
//if an error occurs during init, LEDs alternate blinking rapidly
void ErrorLED( void )
bool
bLEDState = false;
unsigned long
timeBlink = 0;
unsigned long
timeNow;
while( true )
timeNow = millis();
//time for a blink?
if( timeNow - timeBlink >= ERROR_BLINK )
//yes, save time
timeBlink = timeNow;
//toggle flag indicating LED state
bLEDState ^= true;
//update orange and red LEDs
digitalWrite( pinORANGE, (bLEDState)?HIGH:LOW );
digitalWrite( pinRED, (bLEDState)?LOW:HIGH );
}//if
}//while
}//ErrorLED
void TakeSamples()
static byte
gLimitDeadTime = 0;
float
intermediate,
resultant;
static unsigned long
timeSample = 0;
unsigned long
timeNow;
timeNow = micros();
if( (timeNow - timeSample ) < SAMPLE_RATE )
return;
timeSample = timeNow;
mma.read();
xg_f = (float)mma.x/2048.0;
yg_f = (float)mma.y/2048.0;
zg_f = (float)mma.z/2048.0;
xg_sum = xg_sum + xg_f;
yg_sum = yg_sum + yg_f;
zg_sum = zg_sum + zg_f;
sample_count = sample_count + 1;
//look for excursions over pre-set limits for LED flag
//include check of resultant vector; can comment this out
//if not desired
#ifndef TEST_RESULTANT
resultant = 0.0;
#else
resultant = sqrt( pow(xg_f,2) + pow(yg_f,2) + pow(zg_f,2) );
#endif
if( gLimitDeadTime )
gLimitDeadTime--;
if( gLimitDeadTime == 0 )
if( (abs(xg_f) > MAX_G ) ||
(abs(yg_f) > MAX_G ) ||
(abs(zg_f) > MAX_G ) ||
resultant > MAX_G_RESULTANT )
bGLimitExceeded = true;
gLimitDeadTime = CHK_DEADTIME; //N*SAMPLE_RATE microseconds dead time after event (500mS)
}//if
}//if
}//TakeSamples
#define LED_IDLE 0
#define LED_TIME 1
void LED_StateMachine( void )
static int
nEvents = 0;
static byte
stateLED = LED_IDLE;
timeLED;
unsigned long
timeNow;
switch( stateLED )
case LED_IDLE:
if( bGLimitExceeded )
timeNow = millis();
Serial.print( timeNow );
Serial.print( " nEvents = " ); Serial.println( nEvents );
nEvents++;
if( nEvents >= EVENTS_LIMIT )
digitalWrite( pinRED, HIGH );
digitalWrite( pinORANGE, HIGH );
timeLED = millis();
stateLED = LED_TIME;
}//if
case LED_TIME:
if( (millis() - timeLED) >= ORG_LED_ONTIME )
}//if
}//switch
}//LED_StateMachine
void Logging( void )
float
x, y, z;
timeLogging = 0;
unsigned long
timeNow;
timeNow = millis();
if( (timeNow - timeLogging) < LOGGING_RATE )
return;
timeLogging = timeNow;
x = xg_sum / (float)sample_count;
y = yg_sum / (float)sample_count;
z = zg_sum / (float)sample_count;
xg_sum = 0.0;
yg_sum = 0.0;
zg_sum = 0.0;
sample_count = 0;
Serial.print("\tX:\t"); Serial.print(x);
Serial.print("\tY:\t"); Serial.print(y);
Serial.print("\tZ:\t"); Serial.println(z);
}//Logging
//samping, logging and LED control done in their own functions
TakeSamples();
Logging();
LED_StateMachine();
}//loop
