How to shown G-force acting on a remote control car with LED's ?
Hi Everyone,
I am working on a project where i have a 3 axis accelerometer fitted on a RC car. The purpose is to demonstrate when the car impacts an objects, the LED is activated. I am using an Arduino Uno and MMA8451 accelerometer for this project.
I am looking to adapt my code to set g-force limits (example 0.4g) to temporarily activate a orange LED's on the car for 5 seconds then go off. If this Orange LED is activated three times a second (Red) LED is permanently activated and stays ON until the program or button is reset.
The current code I am using operates differently (see below)
1st impact - Orange LED ON for 5 seconds then go's OFF.
2nd impact - Orange LED ON for 10 seconds then go's OFF, After 5 seconds of this the Red LED comes ON and stays ON.
3rd impact - Orange LED ON for 5 seconds then go's OFF.
4th impact - Orange LED ON for 5 seconds then go's OFF
Can anybody help with adapting the below code so the LED will come ON when g-force limit is reached ?
#include <Wire.h>
#include <Adafruit_MMA8451.h>
#include <Adafruit_Sensor.h>
//#define TEST_RESULTANT      1               //comment out to exclude resultant vector from g check
#define MAX_G               3.0             //g limit over which an "event" is logged (org LED etc) (individual axes)
#define MAX_G_RESULTANT     3.0             //g limit over which an "event" is logged (org LED etc) (resultant vector only)
#define ORG_LED_ONTIME      5000ul          //mS orange LED flash time when G limit exceeded
#define EVENTS_LIMIT        3.0             //# of times G limit can be exceeded before RED LED comes on
#define ERROR_BLINK         300ul           //mS blink time for error condition
#define SAMPLE_RATE         5000            //uS (microseconds) per sample
#define LOGGING_RATE        100             //mS between logging file writes
const int pinORANGE =       13;             //pin driving orange LED. Logic assumes HIGH turns LED on
const int pinRED =          12;             //pin driving red LED. Logic assumes HIGH turns LED on
Adafruit_MMA8451 mma = Adafruit_MMA8451();
char
   szStr[50];
//accumulators for x, y and z axes averaging
//samples are taken once per millisecond
//average is written to SD card at 100mS intervals
float
   xg_f,
   yg_f,
   zg_f,
   xg_sum,
   yg_sum,
   zg_sum;
unsigned long
   sample_count;
bool
   bGLimitExceeded;
   pinMode( pinORANGE, OUTPUT );
   digitalWrite( pinORANGE, LOW );         //LED off.
   pinMode( pinRED, OUTPUT );
   digitalWrite( pinRED, LOW );            //LED off.
   Serial.println("Adafruit MMA8451 OK");
   if (!mma.begin())
       Serial.println("###Failed to start MMA8451.");
       ErrorLED();
   }//if
       Serial.println("MMA8451 found!");
   mma.setRange(MMA8451_RANGE_4_G);        //need +/-4g for checking >3g...
   Serial.print(" Range = "); Serial.print(2 << mma.getRange());
   Serial.println("G");
   bGLimitExceeded = false;
   xg_sum = 0.0;
   yg_sum = 0.0;
   zg_sum = 0.0;
   sample_count = 0;
}//setup
//if an error occurs during init, LEDs alternate blinking rapidly
void ErrorLED( void )
   bool
       bLEDState = false;
   unsigned long
       timeBlink = 0;
   unsigned long
       timeNow;
   while( true )
       timeNow = millis();
       //time for a blink?
       if( timeNow - timeBlink >= ERROR_BLINK )
           //yes, save time
           timeBlink = timeNow;
           //toggle flag indicating LED state
           bLEDState ^= true;
           //update orange and red LEDs
           digitalWrite( pinORANGE, (bLEDState)?HIGH:LOW );
           digitalWrite( pinRED, (bLEDState)?LOW:HIGH );
       }//if
   }//while
}//ErrorLED
void TakeSamples()
   float
       intermediate,
       resultant;
   static unsigned long
       timeSample = 0;
   unsigned long
       timeNow;
   timeNow = micros();
   if( (timeNow - timeSample ) < SAMPLE_RATE )
       return;
   timeSample = timeNow;
   mma.read();
   xg_f = (float)mma.x/2048.0;
   yg_f = (float)mma.y/2048.0;
   zg_f = (float)mma.z/2048.0;
   xg_sum = xg_sum + xg_f;
   yg_sum = yg_sum + yg_f;
   zg_sum = zg_sum + zg_f;
   sample_count = sample_count + 1;
   //look for excursions over pre-set limits for LED flag
   //include check of resultant vector; can comment this out
   //if not desired
#ifndef TEST_RESULTANT
   resultant = 0.0;
#else
   resultant = sqrt( pow(xg_f,2) + pow(yg_f,2) + pow(zg_f,2) );
#endif
   if( (abs(xg_f) > MAX_G ) ||
           (abs(yg_f) > MAX_G ) ||
               (abs(zg_f) > MAX_G ) ||
                   resultant > MAX_G_RESULTANT )
       bGLimitExceeded = true;
   }//if
}//TakeSamples
#define LED_IDLE        0
#define LED_TIME        1
void LED_StateMachine( void )
   static int
       nEvents = 0;
   static byte
       stateLED = LED_IDLE;
       timeLED;
   unsigned long
       timeNow;
   switch( stateLED )
       case    LED_IDLE:
           if( bGLimitExceeded )
               nEvents++;
               if( nEvents >= EVENTS_LIMIT )
                   digitalWrite( pinRED, HIGH );
               digitalWrite( pinORANGE, HIGH );
               timeLED = millis();
               stateLED = LED_TIME;
           }//if
       case    LED_TIME:
           if( (millis() - timeLED) >= ORG_LED_ONTIME )
           }//if
   }//switch
}//LED_StateMachine
void Logging( void )
   float
       x, y, z;
       timeLogging = 0;
   unsigned long
       timeNow;
   timeNow = millis();
   if( (timeNow - timeLogging) < LOGGING_RATE )
       return;
   timeLogging = timeNow;
   x = xg_sum / (float)sample_count;
   y = yg_sum / (float)sample_count;
   z = zg_sum / (float)sample_count;
   xg_sum = 0.0;
   yg_sum = 0.0;
   zg_sum = 0.0;
   sample_count = 0;
   Serial.print("\tX:\t"); Serial.print(x);
   Serial.print("\tY:\t"); Serial.print(y);
   Serial.print("\tZ:\t"); Serial.println(z);
}//Logging
   //samping, logging and LED control done in their own functions
   TakeSamples();
   Logging();
   LED_StateMachine();
}//loop
Arduino Schematic - 3.pdf (134 KB)
The code should already do that, subject to certain conditions.
What do you want to do differently, and what have you tried?
If you want someone to rewrite the program for you, consider posting on the Gigs and Collaborations forum section. You may be asked to pay for the help.
The code is not working correctly. On the RC car 2nd impact the RED LED is activating. This should not active until the car impacts an object on the 4th occasion. The code just needs adapting, so i'm seeking anybody's experts and advise.
Most likely, the code is registering more than one "event" per impact.
For investigating this, I would put in some code to print out individual events and the event count as they are detected. Here, for example:
Did you write this code? If not, you need to go through it line by line and make sure that you understand what each line is doing.
Hi Jremington,
I amended the changes you recommended in my code and it solved the problem. Thank you for you help !
