Hello guys im trying to create a security door system which uses an rfid and fingerprint sensor (adafruit) to allow/deny access to a door system. For now i have the door set as an led being that i didn't build the door yet. Im having some problems with the code. Basically i want the door to OPEN ONLY when both rfid and fingerpint is verified if not stay locked. Im having some problems with the code. When i try to compile it i get an error. Here i the preliminary sketch i have. I tried to combine the codes which came with the rfid and finger sensor to compile this code. Please help me out here.
//HEADERFILES
#include <SPI.h> //rfid
#include <MFRC522.h>//rfid
#include <Adafruit_Fingerprint.h> //FINGERPRINT
#include <SoftwareSerial.h> //FINGERPRINT
#include<stdint.h> //FINGERPRINT
//rfid settings
#define RST_PIN 9 // rfid pin 9 RST_pin
#define SS_PIN 10 // rfid pin 10 SS_pin
MFRC522 mfrc522(SS_PIN, RST_PIN); // Create MFRC522 instance
String read_rfid;
String ok_rfid_1= "cbb427b2"; //white card
String ok_rfid_2="0ebb14f39"; //blue key chain
//fingerprint settings
int getFingerprintIDez();
// pin #2 is IN from sensor (GREEN wire)
// pin #3 is OUT from arduino (YELLOW wire)
SoftwareSerial mySerial(2, 3); //activates serial communication on pin 2 & 3
Adafruit_Fingerprint finger = Adafruit_Fingerprint(&mySerial);
//output garage door pin
int door = 7; //motor to door
void setup(){
//RFID setup
Serial.begin(9600); // Initialize serial communications with the PC
while (!Serial); // Do nothing if no serial port is opened (added for Arduinos based on ATMEGA32U4)
finger.begin(57600);
SPI.begin(); // Init SPI bus
mfrc522.PCD_Init(); // Init MFRC522 rfid
void dump_byte_array(byte * buffer , byte bufferSize){ //why so important
read_rfid="";
for (byte i=0; i< bufferSize; i++) {
read_rfid=read_rfid + String(buffer[i], HEX);
pinMode (door, OUTPUT);
//FINGERPRINT setup
while (!Serial); // For Yun/Leo/Micro/Zero/...
if (finger.verifyPassword()) {
Serial.println("Found fingerprint sensor!");
Serial.println("Did not find fingerprint sensor :(");
while (1);
Serial.println("Waiting for valid finger...");
//DOOR/OUTPUT PIN PROPERTIES CHANGE TO REFLECT HOW FAST AND HOW LONG MOTOR PULLS DOOR USING DIGITALWRITE; BREAK.. //USING LED FOR NOW
void open_door(){
digitalWrite (door, HIGH);
delay (2000);
digitalWrite (door, LOW);
// RFID LOOP SETTINGS `
if ( ! mfrc522.PICC_IsNewCardPresent()) { // Look for new cards
return;
if ( ! mfrc522.PICC_ReadCardSerial()) { // Select one of the c ards
return;
dump_byte_array(mfrc522.uid.uidByte, mfrc522.uid.size);
Serial.println(read_rfid);
// FINGERPRINT LOOP SETTINGS
getFingerprintID(); // start fingerprint sensor
delay(100);
uint8_t getFingerprintID() {
uint8_t p = finger.getImage();
switch (p) {
case FINGERPRINT_OK:
Serial.println("Image taken");
case FINGERPRINT_NOFINGER:
Serial.println("No finger detected");
return p;
case FINGERPRINT_PACKETRECIEVEERR:
Serial.println("Communication error");
return p;
case FINGERPRINT_IMAGEFAIL:
Serial.println("Imaging error");
return p;
default:
Serial.println("Unknown error");
return p;
// OK success!
p = finger.image2Tz();
switch (p) {
Serial.println("Image converted");
case FINGERPRINT_IMAGEMESS:
Serial.println("Image too messy");
return p;
return p;
case FINGERPRINT_FEATUREFAIL:
Serial.println("Could not find fingerprint features");
return p;
case FINGERPRINT_INVALIDIMAGE:
return p;
default:
return p;
p = finger.fingerFastSearch();
if (p == FINGERPRINT_OK && read_rfid == ok_rfid_1){
Serial.println(ok_rfid_1);
open_door();
You need to tell us about the error messages you got. They contain important clues.
Also, it's better if you post your code, in tags so it looks like this:
//HEADERFILES
//rfid settings
String read_rfid;
void setup(){
//RFID setup
read_rfid="";
//FINGERPRINT setup
while (1);
void open_door(){
delay (2000);
return;
return;
delay(100);
switch (p) {
return p;
return p;
return p;
default:
return p;
// OK success!
switch (p) {
return p;
return p;
return p;
return p;
default:
return p;
open_door();
Arduino: 1.8.1 (Windows 10), Board: "Arduino/Genuino Uno"
fingerprint:127: error: expected unqualified-id before '{' token
exit status 1
option enabled in File -> Preferences.
the code after that is the default which came with the libraries thats pasted from there. The only portion of that which is mine is towards the end which is the way of saying if the led and fingerprint are good to turn led on. is there things i dont need in the code ?
open_door();
No. But, if you are going to add information to a book, you don't write on the desk that the book is laying on, and expect the information to be in the book when you put it away, do you?
No. You write IN the book. You add code IN the function, not after the end of the function.
I'm not very familiar with coding my friend I'm in need of some learning I know.
So what your indicating is that all those functions belong in the setup not loop?
Please guide me . I've read and tried a lot nothing seems to compile without an error
PaulS:
Ok so i pretty much got everything to work out the way i want it to but now the led only turns on when the rfid card is directly on the scanner. The fingerprint sensor is only active when the card is directly infront. My intent was to Scan the card and than scan in the fingerprint directly after. Here's is the code so far and note that i put in the functions for open and close door so its is n longer an led.
//HEADERFILES
//rfid settings
String read_rfid;
read_rfid="";
//RFID setup
void setup(){
mfrc522.PCD_DumpVersionToSerial(); // Show details of PCD - MFRC522 Card Reader details
//FINGERPRINT setup
void setup1()
Serial.println("Adafruit finger detect test");
// set the data rate for the sensor serial port
while (1);
void open_door(){
delay (2000);
void loop(){
return;
// Select one of the cards
return;
// Dump debug info about the card; PICC_HaltA() is automatically called
mfrc522.PICC_DumpToSerial(&(mfrc522.uid));
void loop1()
getFingerprintIDez(); // start fingerprint sensor
delay(100);
switch (p) {
return p;
return p;
return p;
default:
return p;
//ok success!
switch (p) {
return p;
return p;
return p;
return p;
default:
return p;
if (p == FINGERPRINT_OK && read_rfid == ok_rfid_1 || ok_rfid_2 ){
Serial.println("access granted");
open_door();
I tried separating the line
open_door();
with two if statements one for rfid and one for fingerprint to no success any help plz?
Then, why didn't you write the code that way?
That example you started from is garbage. Complete garbage.
The loop() function should NOT be bypassed just because there is no card present. Only a complete moron would have written the code so the Arduino could no NOTHING unless a card was present.
You'll need to rewrite that code, so that loop() CAN do something if there is a card present AND if there is not a card present.
You need to separate reading the RFID card from reading the fingerprint scanner.
You need to create a boolean, cardScanned, initialized to false. When a card is presented, and is valid, set cardScanned to true.
Only bother reading the fingerprint scanner when cardScanned is true.
You'll need to figure out when to set cardScanned to false. Likely times are after a fingerprint is scanned or after it has been true for a reasonable period of time.
PaulS:
I followed your advice as best as i can, Yet the fingerprint sesnor is still lighting olny one brief second the not staying on.
if (read_rfid == ok_rfid_1 || read_rfid==ok_rfid_2)
CardScanned= true;
while (CardScanned= true);
if (p == FINGERPRINT_OK)
open_door();
delay (4000);
close_door();
else if
(p == FINGERPRINT_NOTFOUND)
CardScanned=false;
return p;
{ return p; }
PS: understand im learning here no need to call me a moron. No one is born with talent like you.
OK thanks for the advice buddy. I fixed that little issue up. Heres the code now. It gives me no errrs when compiling but i wont be able to test it until tomorrow. any issues you can see? syntax wise
#include<stdint.h>
#include <SPI.h>
boolean CardScanned = false;
int timer = 4000;
//-----bluetooth-settings//
SoftwareSerial bluetooth(4, 8);
//---------RFID ------------------------------------------------------------------------------------------------------//
#define RST_PIN 9 // Configurable, see typical pin layout above
#define SS_PIN 10 // Configurable, see typical pin layout above
String read_rfid;
String ok_rfid_1 = "cbb427b2"; //card
String ok_rfid_2 = "0ebb14f39"; //key chain
//--------Fingerprint-------------------------------------------------------------------------//
// pin #2(A5)is IN from sensor (GREEN wire)
// pin #3(A4) is OUT from arduino (YELLOW wire)
SoftwareSerial mySerial(A5, A4 ); //activates serial communication on pin A5 & A4
pinMode( 6, OUTPUT); // Using pin 6 for the 'enable' on the H bridge IC.
pinMode( 3, OUTPUT); // Using pin 3 for the 'input 1' on the H bridge IC.
pinMode( 5, OUTPUT); // Using pin 5 for the 'input 2' on the H bridge IC.
Serial.begin(9600); // initialize the serial communications:
finger.begin(57600); // set the data rate for the sensor serial port
//-----Bluetooth-----//
Serial.println("Welcome. This a system designed to use a two step verification to allow enetry to a door/garage. It will utilize an RFID (white card/blue chip) as means to verfiy the user. If both ways are verified the door will open otherwise it wewill not");
pinMode(4, INPUT);
pinMode(5, OUTPUT);
bluetooth.begin(9600);
bluetooth.println("Bluetooth is activated.");
void dump_byte_array(byte * buffer , byte bufferSize) { ///why so important
read_rfid = "";
for (byte i = 0; i < bufferSize; i++) {
read_rfid = read_rfid + String(buffer[i], HEX);
//-----------DOOR Properties-----------------//
// The motor will rotate in the right direction.
void open_door() {
digitalWrite( 6, HIGH); // Command stating that the enable will always be on. When enable is on, commands can be processed to input 1 & 2.
digitalWrite( 3, LOW); // Command that input 1 is given no current
digitalWrite( 5, HIGH); // Command that input 2 has current.
analogWrite( 6, 225); // motor will rotate at a speed with a duty cycle of 80.
delay(30000); // Commands will be continious for three seconds.
// Commands will cause the motor to break for three seconds
digitalWrite( 3, HIGH); // Current is provided to input 1.
digitalWrite( 5, HIGH); // Current is provided to input 2.
delay(3000);
void close_door()
// The motor will rotate in the left direction.
digitalWrite( 3, HIGH); // Command that input 1 has current
digitalWrite( 5, LOW); // Command that input 2 is given no current.
analogWrite( 6, 225); // motor will rotate at a speed with a duty cycle of 200.
delay(3000);
digitalWrite( 6, LOW); // Enable is off.
delay(10000); // No current will be provided to the circuit for ten seconds.
// Look for new cards`
return;
return;
getFingerprintID();
delay(100);
switch (p)
return p;
return p;
return p;
default:
return p;
// OK success!
switch (p)
return p;
return p;
return p;
return p;
default:
return p;
// OK converted!
if (read_rfid == ok_rfid_1 || read_rfid == ok_rfid_2) {
CardScanned = true;
while (CardScanned == true)
open_door();
delay (4000);
close_door();
else if
return p;
return p;
Serial.println("wrong card");
// returns -1 if failed, otherwise returns ID #
int getFingerprintIDez() {
if (p != FINGERPRINT_OK) return -1;
