Hello everyone,
I have an issue where the code I have written only works if the reset button is pressed. I am using a genuine Arduino Pro Mini 5V, 16 MHz (ATmega 328P) for a model boat project. When the board is connected to my computer it works fine (I can upload programs and they do what I want). However when the board is disconnected from the computer, my code cease to work unless, once it's powered on, I press the reset button; then it is working as intended.
I'm not sure why it's behaving that way and I am hoping someone can help me. From my google research it may be linked to the bootloader but that's something I am wholly ignorant about.
Here is my code :
#include <SoftwareSerial.h>
#include <SPI.h>
#include <PWMServo.h>
#include <DFRobotDFPlayerMini.h>
#include <RF24.h>
//Pin definition
#define CSN_PIN A0
#define CE_PIN A1
#define TX 4
#define RX 2
#define ENABL_PIN 6
#define PHASE_PIN 5
#define SERVO_PIN 10
#define MAX_DEFLECT 45
#define NEUTRAL 90
#define NB_TRCK 3
#define DEADZONE 20
#define TIMEOUT 250
struct payload
int joy_x;
int joy_y;
byte buttons;
payload data_to_receive;
payload previous_data;
SoftwareSerial secondarySerial(RX, TX); // RX, TX
DFRobotDFPlayerMini dfmp3;
PWMServo rudder;
uint8_t address[][6] = { "1Node", "2Node" };
RF24 radio(CE_PIN,CSN_PIN);
//Variables to store input from gamepad and gamepad status
bool is_playing = false;
bool radio_status = false;
bool com_started = false;
bool led_on = false;
int motor_input = 0;
int rudder_input = 90;
uint8_t current_trck = 1;
unsigned long previous_time = 0;
unsigned long last_valid_msg = 0;
unsigned long blink_timer = 0;
int attempt = 0;
bool success = false;
// Serial.begin(9600);
// Serial.println(F("Let the show begin !"));
// while (!Serial)
do
radio_status = radio.begin();
// if(!radio_status)
// Serial.println(F("Radio hardware is not responding !"));
// else
// Serial.println(F("Radio started !"));
}while(!radio_status);
radio.setChannel(105);
radio.setDataRate(RF24_250KBPS);
radio.setPALevel(RF24_PA_LOW);
radio.openWritingPipe(address[1]);
radio.openReadingPipe(1, address[0]);
radio.startListening();
//From datasheet : 500 µs = 0°, 2500 µs = 180°, 1500 µs = 90° (neutral)
rudder.attach(SERVO_PIN, 500, 2500);
//Set Motor
pinMode(PHASE_PIN, OUTPUT);
pinMode(ENABL_PIN, OUTPUT);
//pinMode(LED_BUILTIN, OUTPUT);
//init data
data_to_receive.joy_x = 512;
data_to_receive.joy_y = 512;
data_to_receive.buttons = 0;
memcpy(&previous_data, &data_to_receive, sizeof(payload));
secondarySerial.begin(9600);
do
success = dfmp3.begin(secondarySerial);
attempt +=1;
// Serial.print(F("Attempt : "));
// Serial.println(attempt);
// Serial.print(F("Is it starting : "));
// Serial.println(success);
}while(attempt<10 && !success);
dfmp3.setTimeOut(500);
dfmp3.volume(15); // Between 0 and 30
// Play "Larguez les amaaaaaaares !"
dfmp3.advertise(1); // sd:/advert/0001.mp3
dfmp3.playMp3Folder(current_trck);
is_playing = true;
previous_time = millis();
uint8_t pipe;
unsigned long current_time = 0;
// current_time = millis();
// if((current_time - blink_timer)>= 1000)
// if(led_on)
// digitalWrite(LED_BUILTIN, LOW);
// led_on = false;
// Serial.println("LED OFF");
// else
// digitalWrite(LED_BUILTIN, HIGH);
// led_on = true;
// Serial.println("LED ON");
// blink_timer = current_time;
if(radio.available(&pipe))
radio.read(&data_to_receive, sizeof(payload));
// Serial.print(F("Joystick input Y :"));
// Serial.println(data_to_receive.joy_y);
// Serial.print(F("Joystick input X :"));
// Serial.println(data_to_receive.joy_x);
if(data_to_receive.joy_x != 0 || data_to_receive.joy_y != 0 || data_to_receive.buttons!=0)
if(!com_started)
com_started = true;
last_valid_msg = millis();
if((abs(current_time - last_valid_msg)> TIMEOUT) && com_started && (abs(current_time - previous_time)>50))
// Serial.println(F("Radio hardware stopped responding!"));
// Serial.print(F("Current time is : "));
// Serial.println(current_time);
// Serial.print(F("Last msg time was : "));
// Serial.println(last_valid_msg);
// Serial.println(F("Attempting restart"));
if(radio_status)
previous_time = current_time;
// Serial.println(F("Restart success !"));
// else
// Serial.println(F("Restart failed !"));
if(abs(current_time - previous_time) > 50)
if(previous_data.joy_y<(511 - DEADZONE))
digitalWrite(PHASE_PIN, LOW);
motor_input = (512 - previous_data.joy_y)/2;
// Serial.print(F("Motor input backward : "));
// Serial.println(motor_input);
else if(previous_data.joy_y>(511 + DEADZONE))
digitalWrite(PHASE_PIN, HIGH);
motor_input = (previous_data.joy_y - 511)/2;
// Serial.print(F("Motor input forward : "));
// Serial.print(F("No Motor input "));
motor_input = 0;
motor_input = constrain(motor_input, 0, 255);
analogWrite(ENABL_PIN, motor_input);
rudder_input = map(previous_data.joy_x, 0, 1023, NEUTRAL-MAX_DEFLECT, NEUTRAL+MAX_DEFLECT);
rudder.write(rudder_input);
if(dfmp3.available())
if((dfmp3.readType() == DFPlayerPlayFinished) && is_playing)
if(current_trck == NB_TRCK)
current_trck = 1;
current_trck += 1;
if(previous_data.buttons & 0x10)
dfmp3.reset();
if(previous_data.buttons & 0x01)
dfmp3.volumeUp();
if(previous_data.buttons & 0x04)
dfmp3.volumeDown();
if(previous_data.buttons & 0x08)
if(current_trck == 1)
current_trck = NB_TRCK;
current_trck -= 1;
if(previous_data.buttons & 0x02)
current_trck = 1;
current_trck += 1;
// if(previous_data.buttons & 0x20)
// if(is_playing)
// dfmp3.pause();
// is_playing = false;
// else
// dfmp3.start();
// is_playing = true;
// if(previous_data.buttons & 0x40)
// dfmp3.advertise(2);
Thank you in advance for your answers.
