Code is randomly getting stuck in a particular function
Edits: I kept posting the prior version of the code, it's correct now
Edit2: Added a bit cut off the schematic
Hi everyone
I'll post the full code and schematic at the bottom but here is a screenshot that demonstrates where it is happening and what the serial monitor is doing
As you can see, it's getting stuck right at the delay(vaDelay); part, the sound is not being triggered (but is working elsewhere in the code)
The variable vaDelay is 45000, so 45 seconds I guess. Kinda perplexed why this is happening, it's never been an issue for me.
There may be something it doesn't like about that particular mp3 so I will try play the specific mp3.playTrack(3); elsewhere
full code:
// #define DEBUG
// Scare control UNO
#include <AltSoftSerial.h> // Alt serial library, see library folder in dropbox
#include <Wire.h>
#include <MD_YX5300.h> // See library folder in dropbox
#include <Bounce2.h> // For debouncing button input. See https://github.com/thomasfredericks/Bounce2
// Tunable variables - These are so you can sync up sounds and scares easily
// #ifdef DEBUG
// int vaDelay = 5000; // violent attack delay. Debug 5000. Live 60000.
// int cbDelay1 = 5000; // first crying delay. Debug 5000. Live 10000.
// int cbDelay2 = 5000; // second cry delay. Debug 5000. Live  5000.
// int FHdim = 1500; // Time for the spotlight to dim after the MP3 has been triggered
// int FHrelay = 2500; // Time for relay to hit
// int BYdelay1 = 2000; // Time for first behind you after reed trigger
// int BYdelay2 = 4000; // Time for second behind you after first behind you
// int BYflicker1 = 2000; // Time for first flicker pulse
// int BYflicker2 = 3000; // Time for second flicker pulse
// int fadeAmount = 5;  // how many points to fade the spotlight by
// int fadeinTime = 50; // how quickly to fade the spotlight up (this is slower)
// int fadeoutTime = 20; // how quickly to fade the spotlight up (this is quick)
// int postScareTime = 5000;
// #endif
//#ifndef DEBUG
int vaDelay = 45000; // violent attack delay. Debug 5000. Live 60000.
int cbDelay1 = 10000; // first crying delay. Debug 5000. Live 10000.
int FHdim = 1000; // Time for the spotlight to dim after the MP3 has been triggered
int FHrelay = 2000; // Time for relay to hit
int FYflicker = 50; // Time for the flicker to pulse after facehugger has dropped
int BYdelay1 = 12000; // Time for first behind you after reed trigger
int BYdelay2 = 20000; // Time for second behind you after first behind you
int fadeoutTime = 10; // how quickly to fade the spotlight up (this is quick)
int postScareTime = 3000;
// #endif
// Input pins
int hiss = 12; // Yellow cable connected to office
int hissSelect = 0; // Number to cycle which hiss mp3 to select
int flicker = 6; // Orange cable connected to office
int exhale = 10; // White cable connected to office
int baby = 11; // Yellow cable connected to office
// Output pins
int megaFlicker = A5; // THIS IS NOW ATTACHED TO A red LED
// int megavolumeDown = 2;
// Input triggers
int circsqtriPin = A0; // CHANGED Trigger for 1612 and starts violet attack countdown
int circsqtriLev;
int rfidPin = A1; // CHANGED Trigger the facehugger sequence
int rfidLev;
int jump7Pin= A2; // CHANGED Trigger the window opening sounds
int jump7Lev;
int reedPin = A3; // CHANGED Trigger any behind you sequence
int reedLev;
int plugPin = A4; // Trigger the scare
// int ultrasoundPin = 7;
int threshold = 800; // Threshold for detecting the LED flashes
// Pins for scare switch
int scareSwitch = 13; // This is pulled low when scares are being turned on.
int switchState; //
bool scaresOn = false; // bool to keep track of if scares are on
// Utility
int spotlight = 5; // PWM pin to control the brightness of the light
int spotlightDelay = 0; // Counter to keep track of the delay for the spotlight
int spotlightThreshold = 10000; // Threshold for when to turn on the spotlight
int brightness = 0;  // how bright the spotlight is
int lightRelay = 3; // Relay attached to light NO is floor NC is hand
int facehuggerRelay = 4; // Relay to release the facehugger scare
bool plugState = false; // Keeps the "waiting for plug" loop going
bool plugConnected; // Bool to test if the plug is connected and warn the user if it is
// GLOBALS
// Create an array of Bounce objects for each input button
//Bounce circsqtriSwitch = Bounce();
//Bounce reedSwitch = Bounce();
//Bounce rfidSwitch = Bounce();
//Bounce jump7Switch = Bounce();
Bounce plugSwitch = Bounce();
//Bounce ultrasoundSwitch = Bounce();
Bounce hissSwitch = Bounce();
Bounce exhaleSwitch = Bounce();
Bounce babySwitch = Bounce();
Bounce flickerSwitch = Bounce();
// Initialise a software serial interface on the approriate Rx/Tx pins (8/9)
AltSoftSerial altSerial;
// And create an MP3 object based on the serial connection
MD_YX5300 mp3(altSerial);
  delay (1000);
  // Initialise a serial connection (used for debugging only)
  Serial.println(__FILE__ __DATE__);
  Serial.println("Serial connection initialised");
  Serial.println ("Setup 2 begun, buffer initiated");
  delay (5000);
  Serial.println ("Buffer 2 complete");
  //reedSwitch.attach(reedPin, INPUT_PULLUP); // REED
  //rfidSwitch.attach(rfidPin, INPUT_PULLUP); // DOOR
  //circsqtriSwitch.attach(circsqtriPin, INPUT_PULLUP);// 16
  //jump7Switch.attach(jump7Pin, INPUT_PULLUP); // J7
  plugSwitch.attach(plugPin, INPUT_PULLUP);
  // ultrasoundSwitch.attach(ultrasoundPin, INPUT_PULLUP);
  // Changes adding the LDRs
  pinMode(reedPin, INPUT);
  pinMode(rfidPin, INPUT);
  pinMode(circsqtriPin, INPUT);
  pinMode(jump7Pin, INPUT);
  hissSwitch.attach(hiss, INPUT_PULLUP);
  flickerSwitch.attach(flicker, INPUT_PULLUP);
  exhaleSwitch.attach(exhale, INPUT_PULLUP);
  babySwitch.attach(baby, INPUT_PULLUP);
  Serial.println("Utility buttons initialised");
  // Scare mode?
  pinMode (scareSwitch, INPUT_PULLUP);
  switchState = digitalRead(scareSwitch);
  Serial.println(switchState);
  // Initialise pins and test
  pinMode(megaFlicker, OUTPUT); // Because this is the LED
  digitalWrite(megaFlicker, LOW); // Make sure it's not on
  //pinMode(megavolumeDown, OUTPUT);
  pinMode(spotlight, OUTPUT);
  pinMode(facehuggerRelay, OUTPUT);
  digitalWrite(facehuggerRelay, LOW);
  pinMode(lightRelay, OUTPUT);
  digitalWrite (lightRelay, HIGH);
  // Test
  // Initialise the serial interface to the MP3 player
  altSerial.begin(9600);
  mp3.begin();
  mp3.volume(30);
  if (switchState == 0){
    scaresOn = true;
    Serial.print(switchState);
    mp3.playTrack(1); // "Horror mode is turned on"
    Serial.println ("Horror mode is turned ON");
  else {
    scaresOn = false;
    mp3.playTrack(2); // "Horror mode is turned off"
    Serial.println ("Horror mode is turned OFF");
  delay(3000);
  plugConnected = digitalRead(plugPin);
  Serial.print ("plugConnected is ");
  Serial.println(plugConnected);
  if (plugConnected == 0)
   mp3.playTrack(14); // Alien hiss
    mp3.playTrack(11); // Exhale
  delay(5000);
  Serial.println("Setup complete");
    scaresOn = true;
    // #ifdef DEBUG
    Serial.println("SPOOKY");
    // #endif
  if (switchState != 0) {
    scaresOn = false;
    // #ifdef DEBUG
    Serial.println("Safe");
    // #endif
  // reedSwitch.update();
  // rfidSwitch.update();
  // circsqtriSwitch.update();
  // jump7Switch.update();
  // ultrasoundSwitch.update();
  // Read the light levels
  circsqtriLev = analogRead (circsqtriPin);
  rfidLev = analogRead (rfidPin);
  jump7Lev = analogRead (jump7Pin);
  reedLev = analogRead (reedPin);
  // Print the light levels
  Serial.print(circsqtriLev);
  Serial.print("\t");
  Serial.print(rfidLev);
  Serial.print("\t");
  Serial.print(jump7Lev);
  Serial.print("\t");
  Serial.print(reedLev);
  Serial.println("\t");
  // Update the manual switches
  hissSwitch.update();
  flickerSwitch.update();
  exhaleSwitch.update();
  babySwitch.update();
  // Now run through the statements to detect changes
  //if(circsqtriSwitch.fell())
  if (circsqtriLev>threshold)
    Serial.println("1612 complete");
    violentAttack();
  //if(rfidSwitch.fell())
  if (rfidLev>threshold)
    Serial.println("rfid complete");
    if (scaresOn == true)
      Serial.println("SCARES ARE ON");
      jumpScare();
      Serial.println("SCARES ARE OFF");
      noScare();
  //if(jump7Switch.fell())
  if (jump7Lev>threshold)
    Serial.println("jump7 complete");
    cryBabies();
  //if(reedSwitch.fell())
  if (reedLev>threshold)
    Serial.println("reed complete");
    behindYou();
  if(flickerSwitch.fell())
    Serial.println("flicker");
      sendFlicker();
  if(babySwitch.fell())
    Serial.println("baby");
      mp3.playTrack(10);
  if(hissSwitch.fell())
    Serial.println("hiss");
      whataHisser();
  if(exhaleSwitch.fell())
    Serial.println("exhale");
      mp3.playTrack(11);
void violentAttack()
  Serial.println("in function violentAttack");
    Serial.println("playing violent attack");
    delay(vaDelay);
    mp3.playTrack(3);
  Serial.println("returning to loop");
  return;
void jumpScare() // TO DO
  Serial.println("in jumpScare");
  digitalWrite(lightRelay, LOW);
  mp3.playTrack(7); // Containment cell access granted, warning eteenfeijnfei
  do
    plugSwitch.update();
    spotlightDelay ++;
    Serial.print("Spotlight delay is ");
    Serial.println(spotlightDelay);
    if (spotlightDelay == spotlightThreshold)
      mp3.playTrack(6); // Facehugger cry
      Serial.println ("Facehugger crying");
      brightness = 0;
      do
        analogWrite(spotlight, brightness); // Set current brightness
        // Serial.println (brightness);
        brightness = brightness + fadeAmount; // Increase brightness
        delay(fadeinTime);
      while (brightness <= 225); // Till brightness maxed
      analogWrite(spotlight,225);
    if(plugSwitch.fell())
      Serial.println("plug connected");
      mp3.playTrack(9); // Facehugger strike begins
      delay(FHdim); // Delay a bit so people can react to the sound
      do
        //Serial.println (brightness);
        brightness = brightness - fadeAmount; // Decrease brightness
        delay(fadeoutTime);
      while (brightness >= 0); // Till brightness at minimum
      analogWrite(spotlight, 0);
      delay(FHrelay);
      digitalWrite (facehuggerRelay, HIGH);
      delay(200);
      plugState = true;
      delay(postScareTime);
      // digitalWrite(lightRelay, HIGH);
      sendFlicker();
      // digitalWrite(megavolumeDown, LOW); // Send volume up signal
      // delay(200);
      // digitalWrite(megavolumeDown, HIGH);
  while (plugState == false);
void noScare()
  Serial.println ("in noScare");
  mp3.playTrack(8);
  return;
void cryBabies ()
    delay(cbDelay1);
    mp3.playTrack(5);
    delay(cbDelay2);
    mp3.playTrack(4);
    return;
void behindYou()
  if(scaresOn == true)
    mp3.volume(25);
    delay (BYdelay1);
    mp3.playTrack(12);
    delay (BYdelay2);
    sendFlicker();
    delay (BYflicker1);
    mp3.playTrack(13);
    delay (BYflicker2);
    sendFlicker();
    return;
void spotlightOff()
  do
    delay(fadeoutTime);
  return;
void whataHisser()
  #ifdef DEBUG
    Serial.print ("hissSelect is ");
    Serial.println (hissSelect);
	  Serial.println("Debug pause");
	  delay(5000);
  #endif
  if (hissSelect == 0)
    mp3.playTrack(14);
    hissSelect=1;
  else if (hissSelect == 1)
    mp3.playTrack(15);
    hissSelect=2;
  else if (hissSelect == 2)
    mp3.playTrack(16);
    hissSelect=0;
void sendFlicker()
    digitalWrite(megaFlicker, HIGH);
    delay(200);
    mp3.playTrack(18);
Schematic (apologies, some of the power wires look dodgy because I haven't finalised their layout)
Part of the image cut off (these are essentially LDRs looking out for changes in light to trigger parts of the code, they are working as intended (but the diagram is not updated)
Okay, really weird. I fixed it by going from
delay(vaDelay);
to just
delay(45000);
And it was happy with that enough to get through the function and back to the loop. Would love anyone's insight about why it didn't like the previous version?
Marking this as solved
an int can't be 45000 on an Arduino UNO (int are on 2 bytes, signed, so the max value is 32767 and then you roll over).... so your delay is not 45 seconds anymore
why do you need to be stuck there for 45 seconds before playing a sound ?
you might benefit from studying state machines. Here is a small introduction to the topic: Yet another Finite State Machine introduction
This I did not know, i had learned about byte allocations etc so it makes sense to me. But thanks for pointing it out.
The code is to control scares and sounds in an alien theme escape room. I want that sound to trigger 45 seconds after another sound, space out the sound effects.
I will look into your suggestion, Im always trying to learn more about this stuff
Delay will block everything for 45 seconds - meaning your Arduino wont deal with anything else for 45 seconds. Is that desired ?
If you want to use delay, use unsigned long variables
unsigned long waitingTime = 45000ul; // ul indicates you want an unsigned long. Does not make a difference here but would if you had maths
delay(waitingTime);
Glad you got it sorted, cool looking project!
It’s not a solution - you introduced a bug against your design and you are not waiting 45s…
I want to wait 45 seconds...
Dude, its over, I'm happy. I know this is the arduino forums and everyones gotta tryhard it but yeah, it wasnt working because of the limit on int. I changed it. It works.
Thank you for your input sir it was very useful. Your work here is over
Well im waiting near enough 45 seconds, is what i meant. And whats the bug exactly? Seems to work perfectly to me
After looking at the code, I have a few (small) notes.
Overall there is nothing wrong with is, except the 45000 as mentioned.
You can make the sketch better by adding a header with comments, what the project is for, a date, which parts are used, and so on.
You could put all the timing in "unsigned long" variables.
unsigned long vaDelay = 5000UL;
unsigned long cbDelay1 = 5000UL;
unsigned long cbDelay2 = 5000UL;
Both millis() and delay() work with unsigned long anyway.
You could define the timing in seconds, and then multiply it with 1000UL, each time delay() is called. That can be an improvement when the data is put in a table, then the table is easier to read.
A boolean variable is true or false. An if-statement has a condition that is true or false. Therefor, you can do this:
if (scaresOn)  // same as if(scaresOn == true)
if (!scaresOn) // same as if(scaresOn == false)
I prefer that you use the Bounce2 library for the switches as well.
But if you use digitalRead() directly, then please follow the reference: https://www.arduino.cc/reference/en/language/functions/digital-io/digitalread/
The digitalRead() returns HIGH or LOW.
The code will be:
  if (switchState == LOW)
    scaresOn = true;
    scaresOn = false;
or how about this:
  scaresOn = (switchState == LOW) ? true : false;
When a variable is only used locally, then you can declare that variable locally. It will make the source code better to read and the compiler likes it more because more optimizations can be done.
You could also add the 'const' keyword in front of variables that do not change.
Do you know the 'F()' macro ? https://www.arduino.cc/reference/en/language/variables/utilities/progmem/
OK - you had flagged the post #2 as a solution and it was still showing int instead of unsigned long.
have fun
Okay. Thanks for your help
Thanks for the advice, i wasnt aware of those boolean shortcut things. I understand why they work, but i often like to say out loud what i want the code to do, so if its laid out like "if lightson equals false then..." so sometimes if it actually says that on the screen it helps with my understanding
Im not a professional if it isnt obvious :joy: however youve taught me some cool things
Try to say this:
if (thrustersActivated and enableFlaps and flanBlowing)
then it makes perfect sense :smiley:
It's all about the variable's name. You don't say "if it's raining is true then I'll take my umbrella" you will say "if it's raining then I'll take my umbrella". so you can name your variable itsRaining and the code will be easily readable
bool itsRaining = false;
if (itsRaining) takeTheUmbrella();
from a technical perspective, in C++ a bool is already a truth type (with values true or false) so there is no need to ask the compiler to perform another comparison with == true
