Code not compiling for ESP32-S3
Hello,
I got a new ESP32-S3 (dev-kit-n8r8) board and trying to use it with Arduino IDE. I downloaded esp32 from boards manager, using board type ESP32S3 Dev Module and trying to upload a basic code to perform an analog read, but there code is not compiling and I am getting this error:
exit status 1
Compilation error: exit status 1
The board is also showing on 2 COM ports (8 and 9). Any clues?
Thank you
require more information
upload the code using code tags </>, e.g.. click </> and paste your code in the highlighted area
also in the Arduino IDE select File>Preferences and enable "Verbose output during Compiling and upload" then attempt to compile and upload your program again
if there are still problems upload the error messages as text
Here is the code:
// Define the analog pin
const int analogPin = 14;  // GPIO pin where the analog sensor is connected
  // Initialize serial communication at 115200 baud rate
  // Read the analog value from the sensor
  int analogValue = analogRead(analogPin);
  // Print the analog value to the Serial Monitor
  Serial.println(analogValue);
Here is the error:
FQBN: esp32:esp32:esp32s3
Using board 'esp32s3' from platform in folder: C:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.2
Using core 'esp32' from platform in folder: C:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.2
cmd /c if exist "C:\Users\User\Documents\Arduino\sketch_jun26b\partitions.csv" COPY /y "C:\Users\User\Documents\Arduino\sketch_jun26b\partitions.csv" "C:\Users\User\AppData\Local\Temp\arduino\sketches\214DDEA39B94B17CBB8ED60928A60443\partitions.csv"
your code compiles, links and download OK on my ESP32-S3-DevKitC-1 - Tools>Boards set to ESP32S3 module
your error message printout is very short - there should be much more detail
EDIT: compiling for the ESP32-S3-DevKitC-1
Using board 'esp32s3' from platform in folder: C:\Users\bb\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.1
Using core 'esp32' from platform in folder: C:\Users\bb\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.1
cmd /c if exist "C:\\Users\\bb\\AppData\\Local\\Temp\\.arduinoIDE-unsaved2024527-13836-16iroz6.9p1lf\\sketch_jun27a\\partitions.csv" COPY /y "C:\\Users\\bb\\AppData\\Local\\Temp\\.arduinoIDE-unsaved2024527-13836-16iroz6.9p1lf\\sketch_jun27a\\partitions.csv" "C:\\Users\\bb\\AppData\\Local\\Temp\\arduino\\sketches\\9BABDC6944596B34E709BF4EF02C953D\\partitions.csv"
cmd /c if not exist "C:\\Users\\bb\\AppData\\Local\\Temp\\arduino\\sketches\\9BABDC6944596B34E709BF4EF02C953D\\partitions.csv" if exist "C:\\Users\\bb\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.1\\variants\\esp32s3\\partitions.csv" COPY "C:\\Users\\bb\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.1\\variants\\esp32s3\\partitions.csv" "C:\\Users\\bb\\AppData\\Local\\Temp\\arduino\\sketches\\9BABDC6944596B34E709BF4EF02C953D\\partitions.csv"
cmd /c if not exist "C:\\Users\\bb\\AppData\\Local\\Temp\\arduino\\sketches\\9BABDC6944596B34E709BF4EF02C953D\\partitions.csv" COPY "C:\\Users\\bb\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.1\\tools\\partitions\\default.csv" "C:\\Users\\bb\\AppData\\Local\\Temp\\arduino\\sketches\\9BABDC6944596B34E709BF4EF02C953D\\partitions.csv"
cmd /c IF EXIST "C:\\Users\\bb\\AppData\\Local\\Temp\\.arduinoIDE-unsaved2024527-13836-16iroz6.9p1lf\\sketch_jun27a\\bootloader.bin" ( COPY /y "C:\\Users\\bb\\AppData\\Local\\Temp\\.arduinoIDE-unsaved2024527-13836-16iroz6.9p1lf\\sketch_jun27a\\bootloader.bin" "C:\\Users\\bb\\AppData\\Local\\Temp\\arduino\\sketches\\9BABDC6944596B34E709BF4EF02C953D\\sketch_jun27a.ino.bootloader.bin" ) ELSE ( IF EXIST "C:\\Users\\bb\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.1\\variants\\esp32s3\\bootloader.bin" ( COPY "C:\\Users\\bb\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.1\\variants\\esp32s3\\bootloader.bin" "C:\\Users\\bb\\AppData\\Local\\Temp\\arduino\\sketches\\9BABDC6944596B34E709BF4EF02C953D\\sketch_jun27a.ino.bootloader.bin" ) ELSE ( "C:\\Users\\bb\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esptool_py\\4.6\\esptool.exe" --chip esp32s3 elf2image --flash_mode dio --flash_freq 80m --flash_size 4MB -o "C:\\Users\\bb\\AppData\\Local\\Temp\\arduino\\sketches\\9BABDC6944596B34E709BF4EF02C953D\\sketch_jun27a.ino.bootloader.bin" "C:\\Users\\bb\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-442a798083\\esp32s3\\bin\\bootloader_qio_80m.elf" ) )
esptool.py v4.6
Creating esp32s3 image...
Merged 1 ELF section
Successfully created esp32s3 image.
cmd /c if exist "C:\\Users\\bb\\AppData\\Local\\Temp\\.arduinoIDE-unsaved2024527-13836-16iroz6.9p1lf\\sketch_jun27a\\build_opt.h" COPY /y "C:\\Users\\bb\\AppData\\Local\\Temp\\.arduinoIDE-unsaved2024527-13836-16iroz6.9p1lf\\sketch_jun27a\\build_opt.h" "C:\\Users\\bb\\AppData\\Local\\Temp\\arduino\\sketches\\9BABDC6944596B34E709BF4EF02C953D\\build_opt.h"
cmd /c if not exist "C:\\Users\\bb\\AppData\\Local\\Temp\\arduino\\sketches\\9BABDC6944596B34E709BF4EF02C953D\\build_opt.h" type nul > "C:\\Users\\bb\\AppData\\Local\\Temp\\arduino\\sketches\\9BABDC6944596B34E709BF4EF02C953D\\build_opt.h"
cmd /c type nul > "C:\\Users\\bb\\AppData\\Local\\Temp\\arduino\\sketches\\9BABDC6944596B34E709BF4EF02C953D/file_opts"
Detecting libraries used...
C:\Users\bb\AppData\Local\Arduino15\packages\esp32\tools\esp-xs3\2302/bin/xtensa-esp32s3-elf-g++ -c @C:\Users\bb\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-442a798083\esp32s3/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32S3_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32S3_DEV" -DARDUINO_VARIANT="esp32s3" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32s3:UploadSpeed=921600,USBMode=hwcdc,CDCOnBoot=default,MSCOnBoot=default,DFUOnBoot=default,UploadMode=default,CPUFreq=240,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_MODE=1 -DARDUINO_USB_CDC_ON_BOOT=0 -DARDUINO_USB_MSC_ON_BOOT=0 -DARDUINO_USB_DFU_ON_BOOT=0 @C:\Users\bb\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-442a798083\esp32s3/flags/defines -IC:\Users\bb\AppData\Local\Temp\.arduinoIDE-unsaved2024527-13836-16iroz6.9p1lf\sketch_jun27a -iprefix C:\Users\bb\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-442a798083\esp32s3/include/ @C:\Users\bb\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-442a798083\esp32s3/flags/includes -IC:\Users\bb\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-442a798083\esp32s3/qio_qspi/include -IC:\Users\bb\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.1\cores\esp32 -IC:\Users\bb\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.1\variants\esp32s3 @C:\Users\bb\AppData\Local\Temp\arduino\sketches\9BABDC6944596B34E709BF4EF02C953D/build_opt.h @C:\Users\bb\AppData\Local\Temp\arduino\sketches\9BABDC6944596B34E709BF4EF02C953D/file_opts C:\Users\bb\AppData\Local\Temp\arduino\sketches\9BABDC6944596B34E709BF4EF02C953D\sketch\sketch_jun27a.ino.cpp -o nul
Generating function prototypes...
C:\Users\bb\AppData\Local\Arduino15\packages\esp32\tools\esp-xs3\2302/bin/xtensa-esp32s3-elf-g++ -c @C:\Users\bb\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-442a798083\esp32s3/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32S3_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32S3_DEV" -DARDUINO_VARIANT="esp32s3" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32s3:UploadSpeed=921600,USBMode=hwcdc,CDCOnBoot=default,MSCOnBoot=default,DFUOnBoot=default,UploadMode=default,CPUFreq=240,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_MODE=1 -DARDUINO_USB_CDC_ON_BOOT=0 -DARDUINO_USB_MSC_ON_BOOT=0 -DARDUINO_USB_DFU_ON_BOOT=0 @C:\Users\bb\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-442a798083\esp32s3/flags/defines -IC:\Users\bb\AppData\Local\Temp\.arduinoIDE-unsaved2024527-13836-16iroz6.9p1lf\sketch_jun27a -iprefix C:\Users\bb\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-442a798083\esp32s3/include/ @C:\Users\bb\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-442a798083\esp32s3/flags/includes -IC:\Users\bb\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-442a798083\esp32s3/qio_qspi/include -IC:\Users\bb\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.1\cores\esp32 -IC:\Users\bb\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.1\variants\esp32s3 @C:\Users\bb\AppData\Local\Temp\arduino\sketches\9BABDC6944596B34E709BF4EF02C953D/build_opt.h @C:\Users\bb\AppData\Local\Temp\arduino\sketches\9BABDC6944596B34E709BF4EF02C953D/file_opts C:\Users\bb\AppData\Local\Temp\arduino\sketches\9BABDC6944596B34E709BF4EF02C953D\sketch\sketch_jun27a.ino.cpp -o C:\Users\bb\AppData\Local\Temp\1622059800\sketch_merged.cpp
C:\Users\bb\AppData\Local\Arduino15\packages\builtin\tools\ctags\5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives C:\Users\bb\AppData\Local\Temp\1622059800\sketch_merged.cpp
Compiling sketch...
"C:\\Users\\bb\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-xs3\\2302/bin/xtensa-esp32s3-elf-g++" -MMD -c "@C:\\Users\\bb\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-442a798083\\esp32s3/flags/cpp_flags" -w -Os -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32S3_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32S3_DEV\"" "-DARDUINO_VARIANT=\"esp32s3\"" -DARDUINO_PARTITION_default "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32s3:UploadSpeed=921600,USBMode=hwcdc,CDCOnBoot=default,MSCOnBoot=default,DFUOnBoot=default,UploadMode=default,CPUFreq=240,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default\"" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_MODE=1 -DARDUINO_USB_CDC_ON_BOOT=0 -DARDUINO_USB_MSC_ON_BOOT=0 -DARDUINO_USB_DFU_ON_BOOT=0 "@C:\\Users\\bb\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-442a798083\\esp32s3/flags/defines" "-IC:\\Users\\bb\\AppData\\Local\\Temp\\.arduinoIDE-unsaved2024527-13836-16iroz6.9p1lf\\sketch_jun27a" -iprefix "C:\\Users\\bb\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-442a798083\\esp32s3/include/" "@C:\\Users\\bb\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-442a798083\\esp32s3/flags/includes" "-IC:\\Users\\bb\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-442a798083\\esp32s3/qio_qspi/include" "-IC:\\Users\\bb\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.1\\cores\\esp32" "-IC:\\Users\\bb\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.1\\variants\\esp32s3" "@C:\\Users\\bb\\AppData\\Local\\Temp\\arduino\\sketches\\9BABDC6944596B34E709BF4EF02C953D/build_opt.h" "@C:\\Users\\bb\\AppData\\Local\\Temp\\arduino\\sketches\\9BABDC6944596B34E709BF4EF02C953D/file_opts" "C:\\Users\\bb\\AppData\\Local\\Temp\\arduino\\sketches\\9BABDC6944596B34E709BF4EF02C953D\\sketch\\sketch_jun27a.ino.cpp" -o "C:\\Users\\bb\\AppData\\Local\\Temp\\arduino\\sketches\\9BABDC6944596B34E709BF4EF02C953D\\sketch\\sketch_jun27a.ino.cpp.o"
Compiling libraries...
Compiling core...
cmd /c echo -DARDUINO_CORE_BUILD > "C:\\Users\\bb\\AppData\\Local\\Temp\\arduino\\sketches\\9BABDC6944596B34E709BF4EF02C953D/file_opts"
Using precompiled core: C:\Users\bb\AppData\Local\Temp\arduino\cores\02ae50214693248d77e396ff11be6788\core.a
Linking everything together...
"C:\\Users\\bb\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-xs3\\2302/bin/xtensa-esp32s3-elf-g++" "@C:\\Users\\bb\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-442a798083\\esp32s3/flags/ld_flags" "@C:\\Users\\bb\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-442a798083\\esp32s3/flags/ld_scripts" "-Wl,--Map=C:\\Users\\bb\\AppData\\Local\\Temp\\arduino\\sketches\\9BABDC6944596B34E709BF4EF02C953D/sketch_jun27a.ino.map" "-LC:\\Users\\bb\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-442a798083\\esp32s3/lib" "-LC:\\Users\\bb\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-442a798083\\esp32s3/ld" "-LC:\\Users\\bb\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-442a798083\\esp32s3/qio_qspi" -Wl,--wrap=esp_panic_handler -Wl,--start-group "C:\\Users\\bb\\AppData\\Local\\Temp\\arduino\\sketches\\9BABDC6944596B34E709BF4EF02C953D\\sketch\\sketch_jun27a.ino.cpp.o" "C:\\Users\\bb\\AppData\\Local\\Temp\\arduino\\cores\\02ae50214693248d77e396ff11be6788\\core.a" "@C:\\Users\\bb\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-442a798083\\esp32s3/flags/ld_libs" -Wl,--end-group -Wl,-EL -o "C:\\Users\\bb\\AppData\\Local\\Temp\\arduino\\sketches\\9BABDC6944596B34E709BF4EF02C953D/sketch_jun27a.ino.elf"
"C:\\Users\\bb\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esptool_py\\4.6/esptool.exe" --chip esp32s3 elf2image --flash_mode dio --flash_freq 80m --flash_size 4MB --elf-sha256-offset 0xb0 -o "C:\\Users\\bb\\AppData\\Local\\Temp\\arduino\\sketches\\9BABDC6944596B34E709BF4EF02C953D/sketch_jun27a.ino.bin" "C:\\Users\\bb\\AppData\\Local\\Temp\\arduino\\sketches\\9BABDC6944596B34E709BF4EF02C953D/sketch_jun27a.ino.elf"
esptool.py v4.6
Merged 2 ELF sections
"C:\\Users\\bb\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.1\\tools\\gen_esp32part.exe" -q "C:\\Users\\bb\\AppData\\Local\\Temp\\arduino\\sketches\\9BABDC6944596B34E709BF4EF02C953D/partitions.csv" "C:\\Users\\bb\\AppData\\Local\\Temp\\arduino\\sketches\\9BABDC6944596B34E709BF4EF02C953D/sketch_jun27a.ino.partitions.bin"
cmd /c if exist "C:\\Users\\bb\\AppData\\Local\\Temp\\arduino\\sketches\\9BABDC6944596B34E709BF4EF02C953D\\libraries\\Insights" "C:\\Users\\bb\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.1\\tools\\gen_insights_package.exe" "C:\\Users\\bb\\AppData\\Local\\Temp\\arduino\\sketches\\9BABDC6944596B34E709BF4EF02C953D" sketch_jun27a.ino "C:\\Users\\bb\\AppData\\Local\\Temp\\.arduinoIDE-unsaved2024527-13836-16iroz6.9p1lf\\sketch_jun27a"
cmd /c if exist "C:\\Users\\bb\\AppData\\Local\\Temp\\arduino\\sketches\\9BABDC6944596B34E709BF4EF02C953D\\libraries\\ESP_SR" if exist "C:\\Users\\bb\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-442a798083\\esp32s3\\esp_sr\\srmodels.bin" COPY /y "C:\\Users\\bb\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-442a798083\\esp32s3\\esp_sr\\srmodels.bin" "C:\\Users\\bb\\AppData\\Local\\Temp\\arduino\\sketches\\9BABDC6944596B34E709BF4EF02C953D\\srmodels.bin"
"C:\\Users\\bb\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esptool_py\\4.6/esptool.exe" --chip esp32s3 merge_bin -o "C:\\Users\\bb\\AppData\\Local\\Temp\\arduino\\sketches\\9BABDC6944596B34E709BF4EF02C953D/sketch_jun27a.ino.merged.bin" --fill-flash-size 4MB --flash_mode keep --flash_freq keep --flash_size keep 0x0 "C:\\Users\\bb\\AppData\\Local\\Temp\\arduino\\sketches\\9BABDC6944596B34E709BF4EF02C953D/sketch_jun27a.ino.bootloader.bin" 0x8000 "C:\\Users\\bb\\AppData\\Local\\Temp\\arduino\\sketches\\9BABDC6944596B34E709BF4EF02C953D/sketch_jun27a.ino.partitions.bin" 0xe000 "C:\\Users\\bb\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.1/tools/partitions/boot_app0.bin" 0x10000 "C:\\Users\\bb\\AppData\\Local\\Temp\\arduino\\sketches\\9BABDC6944596B34E709BF4EF02C953D/sketch_jun27a.ino.bin"
esptool.py v4.6
Wrote 0x400000 bytes to file C:\Users\bb\AppData\Local\Temp\arduino\sketches\9BABDC6944596B34E709BF4EF02C953D/sketch_jun27a.ino.merged.bin, ready to flash to offset 0x0
"C:\\Users\\bb\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-xs3\\2302/bin/xtensa-esp32s3-elf-size" -A "C:\\Users\\bb\\AppData\\Local\\Temp\\arduino\\sketches\\9BABDC6944596B34E709BF4EF02C953D/sketch_jun27a.ino.elf"
Sketch uses 274853 bytes (20%) of program storage space. Maximum is 1310720 bytes.
Global variables use 14192 bytes (4%) of dynamic memory, leaving 313488 bytes for local variables. Maximum is 327680 bytes.
"C:\Users\bb\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\4.6/esptool.exe" --chip esp32s3 --port "COM26" --baud 921600  --before default_reset --after hard_reset write_flash  -z --flash_mode keep --flash_freq keep --flash_size keep 0x0 "C:\Users\bb\AppData\Local\Temp\arduino\sketches\9BABDC6944596B34E709BF4EF02C953D/sketch_jun27a.ino.bootloader.bin" 0x8000 "C:\Users\bb\AppData\Local\Temp\arduino\sketches\9BABDC6944596B34E709BF4EF02C953D/sketch_jun27a.ino.partitions.bin" 0xe000 "C:\Users\bb\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.1/tools/partitions/boot_app0.bin" 0x10000 "C:\Users\bb\AppData\Local\Temp\arduino\sketches\9BABDC6944596B34E709BF4EF02C953D/sketch_jun27a.ino.bin"
esptool.py v4.6
Serial port COM26
Connecting....
Chip is ESP32-S3 (revision v0.1)
Features: WiFi, BLE
Crystal is 40MHz
MAC: 68:b6:b3:2c:16:08
Uploading stub...
Running stub...
Stub running...
Changing baud rate to 921600
Changed.
Configuring flash size...
Flash will be erased from 0x00000000 to 0x00003fff...
Flash will be erased from 0x00008000 to 0x00008fff...
Flash will be erased from 0x0000e000 to 0x0000ffff...
Flash will be erased from 0x00010000 to 0x00053fff...
Compressed 14880 bytes to 10569...
Writing at 0x00000000... (100 %)
Wrote 14880 bytes (10569 compressed) at 0x00000000 in 0.4 seconds (effective 316.8 kbit/s)...
Hash of data verified.
Compressed 3072 bytes to 146...
Writing at 0x00008000... (100 %)
Wrote 3072 bytes (146 compressed) at 0x00008000 in 0.1 seconds (effective 351.6 kbit/s)...
Compressed 8192 bytes to 47...
Writing at 0x0000e000... (100 %)
Wrote 8192 bytes (47 compressed) at 0x0000e000 in 0.1 seconds (effective 468.8 kbit/s)...
Compressed 275232 bytes to 155612...
Writing at 0x00010000... (10 %)
Writing at 0x0001b8a5... (20 %)
Writing at 0x000242c0... (30 %)
Writing at 0x00029d49... (40 %)
Writing at 0x0002f0ea... (50 %)
Writing at 0x0003477f... (60 %)
Writing at 0x0003c515... (70 %)
Writing at 0x00045063... (80 %)
Writing at 0x0004ac71... (90 %)
Writing at 0x0005056e... (100 %)
Wrote 275232 bytes (155612 compressed) at 0x00010000 in 2.4 seconds (effective 913.3 kbit/s)...
Leaving...
Hard resetting via RTS pin...
Yeah it does when I use a different computer. But I have had a few different Arduino IDE versions and libraries on my computer and apparently setup files are being mixed up now. Uninstalled and reinstalled and still same error
No error there. Only the first four lines (more than doubled after wrapping) of the compile output.
In the Output window, right-click and select Copy All. Then paste in the forum as code.
There you go:
cmd /c if exist "C:\\Users\\User\\Documents\\Arduino\\sketch_jun26a\\partitions.csv" COPY /y "C:\\Users\\User\\Documents\\Arduino\\sketch_jun26a\\partitions.csv" "C:\\Users\\User\\AppData\\Local\\Temp\\arduino\\sketches\\2367B8B779E2A8A41111BF0E9B7356F4\\partitions.csv"
exit status 1
Do another Verify (that fails), then open a Command Prompt. That can be from the Windows menu; or you can open the Run dialog -- pressing Windows-R is one way -- and run
cmd
In the Command Prompt window, you can right-click to Copy and Paste. Try that long command that starts (again) with cmd
Press Enter, and note any output; there shouldn't be any. Then run
echo %errorlevel%
That should be 0 (zero). Then try the same two commands again, the first without the cmd /c: press Up, Up, Home, and Del several times
echo %errorlevel%
Copy the whole session and paste it here as code
Okay, it didn't quite work out as expected. One issue I have with my PC is that I cannot run cmd (I don't know why) so I use powershell instead. But here is the session log anyway:
PS C:\Users\User> cmd /c if exist "C:\\Users\\User\\OneDrive - University of Cambridge\\Arduino\\sketch_jun26a\\partitions.csv" COPY /y "C:\\Users\\User\\OneDrive - University of Cambridge\\Arduino\\sketch_jun26a\\partitions.csv" "C:\\Users\\User\\AppData\\Local\\Temp\\arduino\\sketches\\2367B8B779E2A8A41111BF0E9B7356F4\\partitions.csv"
PS C:\Users\User> echo %errorlevel%
%errorlevel%
PS C:\Users\User> echo errorlevel
errorlevel
PS C:\Users\User> if exist "C:\\Users\\User\\OneDrive - University of Cambridge\\Arduino\\sketch_jun26a\\partitions.csv" COPY /y "C:\\Users\\User\\OneDrive - University of Cambridge\\Arduino\\sketch_jun26a\\partitions.csv" "C:\\Users\\User\\AppData\\Local\\Temp\\arduino\\sketches\\2367B8B779E2A8A41111BF0E9B7356F4\\partitions.csv"
At line:1 char:3
+ if exist "C:\\Users\\User\\OneDrive - University of Cambridge\\Arduin ...
Missing '(' after 'if' in if statement.
    + CategoryInfo          : ParserError: (:) [], ParentContainsErrorRecordException
    + FullyQualifiedErrorId : MissingOpenParenthesisInIfStatement
%errorlevel%
That is certainly a problem; the board platform is trying to as well, and that is likely the error that is being reported.
It appears that if you start PowerShell, then cmd works. FYI, in PowerShell, the syntax of the commands (including if) is different, and the variable with the exit code is $LASTEXITCODE; you can just type it alone
PS > cmd /c dir C:\Windows\notepad.exe /b
notepad.exe
PS > $LASTEXITCODE
0
PS > cmd /c dir C:\no_such_thing /b
File Not Found
PS > $LASTEXITCODE
1
But that's just for diagnosing things in PowerShell, which is not the problem here.
The issue is that I cannot open cmd (flashes and exits), so I created a new user account (Windows 10) and now it works!
Thank you for your replies.
