Can someone please guide me with the code for serial communication between arduino nano and esp32?
Sure
What do you need to know?
None of the quarter million hits from a search for "serial communication between arduino nano and esp32" has what you want?
I'm making a heart rate sensor so want to show my data over ubidots I am using arduino nano and esp32 I have used a unidirectional converter to match the voltage levels and using the pin d6 and d7 of nano as RX TX and pins RX0 and TX0 of ESP32 for the communication but I don't know what code I should be using.
I have not been able to find what I'm looking for yet.
I would recommend a solution that requires no code and no voltage converters for serial communication between nano and ESP32. Remove the Nano!
And Rx0 and Tx0 on a ESP32 is the programming port.
For what you are looking?
Shall we made the analyzis of the WWW search?
Is there a specific reason why the 'heart rate' monitor cannot be run on the ESP32 ?
I'm looking for the serial communication code for esp 32 and arduino nano
Yeah that's definitely a better idea, I didn't consider that earlier will try it asap.
Thank you <3
Read and understand post #3.
