I am creating a code for a barcode system. I am using a Host USB, Clock, SD card and a scanner. The idea is to read the bar code using a scanner connected to the host USB. Then, this information should be stored on an SD card along with the date and time.
Can anyone review my code below?
/* Program to demonstrate Data Logging/Visualisation using Arduino
* ###Connection with SD card module###
* Vcc->5V
* Gnd->Gnd
* MISO->pin 12
* MOSI->pin 11
* SCK-> pin 13
* CS-> pin 4
* ###Connection with DS3231###
* Vcc->5V
* Gns->Gnd
* SCL->pin A5
* SDA-> pin A4
* Vcc->5V
* Gnd->Gnd
* Out-> pin 7
#include "RTClib.h"
#include <hidboot.h>
#include <usbhub.h>
#include <SPI.h>
#include <SD.h>
RTC_DS3231 rtc;
const int chipSelect = 4;
String codigoLido="";
bool leituraRealizada = false;
#include "Leitor.h"
Remove_SDcard();
Initialize_RTC();
Serial.println("Serial begin");
Serial.println("Iniciando USB Host Shield");
usb();
Initialize_SDcard();
Serial.println("initialize end!");
void Remove_SDcard()
SD.remove("Barcode.txt");
void Initialize_RTC()
if (rtc.lostPower()) {
Serial.println("RTC lost power, lets set the time!");
// following line sets the RTC to the date & time this sketch was compiled
//rtc.adjust(DateTime(F(__DATE__), F(__TIME__)));
// Initialize the rtc object
rtc.begin();
// This line sets the RTC with an explicit date & time, for example to set
// January 21, 2014 at 3am you would call:
//rtc.adjust(DateTime(2021, 06, 30, 07, 59, 00));
//#### The following lines can be uncommented to set the date and time for the first time###
rtc.setDOW(FRIDAY); // Set Day-of-Week to SUNDAY
rtc.setTime(18, 46, 45); // Set the time to 12:00:00 (24hr format)
rtc.setDate(6, 30, 2017); // Set the date to January 1st, 2014
void usb () {
if (Usb.Init() == -1) {
Serial.println("Something went wrong :( ");
Serial.println("Check your Sketch");
delay( 200 );
// CONFIGURA O OBJETO DO LEITOR DE CODIGO DE BARRAS
Serial.println("Starting Barcode reading");
HidKeyboard.SetReportParser(0, &Prs);
Serial.println("Setup completed");
void Initialize_SDcard()
DateTime now = rtc.now();
// see if the card is present and can be initialized:
if (!SD.begin(chipSelect)) {
Serial.println("Card failed, or not present");
// don't do anything more:
return;
// open the file. note that only one file can be open at a time,
// so you have to close this one before opening another.
File dataFile = SD.open("Barcode.txt", FILE_WRITE);
// if the file is available, write to it:
if (dataFile) {
dataFile.print("Date Time Input "); //Write the first row of the excel file
dataFile.print(now.day(), DEC);
dataFile.print("/");
dataFile.print(now.month(), DEC);
dataFile.print(now.year(), DEC); //Store date on SD card
dataFile.print(" ");
dataFile.print(now.hour(), DEC); //Store date on SD card
dataFile.print(":");
dataFile.print(now.minute(), DEC);
dataFile.print(now.second(), DEC);
dataFile.println();
dataFile.close();
// ***************** FIM DO SETUP ***************************
// ***************** INÍCIO DO LOOP *************************
// REALIZA A LEITURA DA PORTA USB DA SHIELD
Usb.Task();
// EXECUTA AS FUNÇÕES APÓS TER IDENTIFICADO UMA LEITURA COMPLETA
if(leituraRealizada){
Serial.print("Código lido: ");
Serial.println(codigoLido);
codigoLido = "";
Write_SDcard();
//Write_PlxDaq();
delay(1000); //Wait for 5 seconds before writing the next data
void Write_SDcard() {
if (dataFile) {
// Serial print
Serial.print(now.day());
Serial.print("/");
Serial.print(now.month(), DEC);
Serial.print("/");
Serial.print(now.year(), DEC); //Store date on SD card
Serial.print(" ");
//dataFile.print(","); //Move to next column using a ","
// Serial print
Serial.print(now.hour(), DEC); //Store date on SD card
Serial.print(":");
Serial.print(now.minute(), DEC);
Serial.print(":");
Serial.print(now.second(), DEC);
Serial.print(" ");
dataFile.print(codigoLido);
//Serial print
Serial.print(codigoLido);
Serial.print(" ");
dataFile.println(); //End of Row move to next row
dataFile.close(); //Close the file
Serial.println("OOPS!! SD card writing failed");
