Below is my code for controlling a digital potentiometer MCP4131. I set up strings to control "the number to steps" and that will then change the output of the digi-pot.
At the moment, my code is stuck at the SPI.transfer(128); line because after I enter "B0D0" in the serial monitor, the last line that it prints is "before steps"
Can someone help me out please? Thanks!
#include <SPI.h>
#define degrees0 3
#define degrees45 4
String readString;
pinMode (degrees0, OUTPUT); //Make pin available for 0 degrees element
pinMode(degrees45, OUTPUT); //Make pin available for 45 degrees element
digitalWrite(degrees0, LOW);
digitalWrite(degrees45, LOW);
Serial.println("Serial with Digi-Pots has begun"); // so I can keep track of when the program starts
while (Serial.available()) {
char c = Serial.read(); //gets one byte from serial buffer
if (c == 'n') {
Serial.println(readString);
// 0 Degrees
if(readString.indexOf("B0D0") >=0) // Button 0 Degrees #0
Serial.println("BEFORE SPI");
digitalWrite(degrees0, LOW); //select the pin to allow communication with digi-pot
Serial.println("before steps");
SPI.transfer(128); //transfer the "number of steps" to the digi-pot
Serial.println("after steps");
digitalWrite(degrees0, HIGH); //deselect the pin to end communication
Serial.println("0 Degrees Element is FULLY ON");
if(readString.indexOf("B0D1") >=0) // Button 0 Degrees #1
SPI.transfer(64);
Serial.println("0 Degrees Element is HALF-ON");
if(readString.indexOf("B0D2") >=0) // Button 0 Degrees #2
SPI.transfer(0);
Serial.println("0 Degrees Element is OFF");
readString=""; //clears variable for new input
else {
readString += c; //makes the string readString
For a start, you need an SPI.begin in setup. And those break statements take you out of the while loop, which means the String doesn't get emptied. Maybe you should comment out all the SPI stuff and make sure you can enter and recognize commands, first.
Thank you both!
I added SPI.begin(); (rookie mistake...) and also readString = ""; to clear what was in the string. (would this also end the if statement?)
I've also noticed that the 'L' LED (Pin13/SCK) on the Uno is not on after I added the SPI.begin(); and that SPI.transfer(128) does not make the digi-pot fully output 5V (my input is 5V).
mclaren12c:
Thank you both!
What is the Idle state for SCK (clock signal of the SPI interface, depending on the which SPI MODE you choose, It is either High or Low)? If the clock Idle Level is Low you will never see the flicker of the LED.
If you use the default SPI configurations, the SCK signal is changing at 4mhz, way above your visual range.
Robin2:
Post your latest code.
Tell us what it actually does and tell us what you want it to do.
...R
I apologize, I have been working on the Java portion of my project.
My project is for controlling 8 digital potentiometers, by transferring the number of steps, (SPI.transfer(128), SPI.transfer(64), etc.), it will vary the output voltage.
My updated code is now:
#include <SPI.h>
#define test 8
#define degrees0 3
#define degrees45 4
//#define degrees90
//#define degrees135
//#define degrees180
//#define degrees225
//#define degrees270
//#define degrees315
String readString;
SPI.begin();
pinMode (test, OUTPUT);
digitalWrite(test, LOW);
digitalWrite(degrees45, HIGH);
if (c == '\n') {
Serial.println(readString); //prints string to serial port out
else {
if(readString.indexOf("T0D0") >=0) // Button 0 Degrees #0
//delay(1000);
readString = "";
if(readString.indexOf("T0D1") >=0) // Button 0 Degrees #1
SPI.transfer(64);
readString = "";
if(readString.indexOf("T0D2") >=0) // Button 0 Degrees #2
SPI.transfer(0);
readString = "";
//readString=""; //clears variable for new input
To test, I should see a change in the LED's brightness depending on the number of steps. However, it doesn't seem to change anything. (I tried using different digi-pots and still no change)
Does anyone have any advice on why it is not outputting anything? Thanks!
