I'm a little inexperienced in programming and using the arduino UNO
Would it be possible for someone to help explain how the converter works and maybe help adjust one of the scripts in the forms to help read gray code and work with my encoders.
It will be tricky for a beginner in programming to read that encoder, which looks to be very nice.
It is serial output and there are signal timing requirements that must be obeyed. The encoder datasheet is not very clear.
Something similar to the code in the last post (#8) here will probably work, but you will have to carefully check the signal polarity and the bit timing.
Unfortunately it will be difficult for anyone on the forum to help, as it is unlikely that anyone has that encoder. You should contact the manufacturer for example code, or do an extensive web search.
knut_ny: Do you mean the serial output? I don't really know how to set everything up to read the output in general I'm very new to anything dealing with encoders.
jremington: Unfortunately my searches have not been very helpful and Gurley Precision does not provide any example codes Would i be ale to adjust the code on post #8 to account for bit timing? Also I'm actually a little be confused on how to connect the SN75176BP to the encoder. Is he using 2 SN75179B, http://www.ti.com.cn/cn/lit/ds/symlink/sn75176b.pdf, with one encoder? or is he using one where R and RE are Clock + and -, D and DE is Data + and -, and A is receiver input and B is driver output?
You will need the SN75179B line drivers or similar. A & B are the RS485 line output, which are connected to the encoder (+/-) clock and data lines. You may need resistive termination, so read up on RS485, e.g. http://www.ti.com/lit/an/slla272b/slla272b.pdf
