Here's a new code, it has only one color, but handles 21x32 tiles on the screen. Each tile is a 7 byte icon stored in flash, so you can have a lot of icons in flash, not RAM. The problem now is that the code needs more optimizations and also if I try to change the memory data for the tiles in real-time, the video goes out of sync. I need to figure out why.
Edit: I also changed the connections, I'm using SPI for the video output now.
For connections, use:
Pin 9 = HZync (PWM) = VGA Pin 13
Pin 8 = VSync = VGA Pin 14
Pin 11 = RGB Video (SPI) = VGA Pins 1, 2 & 3 (or use just one to get a single color)
Ground the following pins on the VGA connector: 6 and 10
VSync us
64 - Sync = 1024 cycles
1020 - Blank = 16320 cycles
15240 - Lines = 243840 cycles
350 - Blank = 5600 cycles
266784 = cycles total (60 times per second = 60hz)
HSync us (Lines)
3.77 - Sync = 60.32 cycles
1.89 - Blank = 30.24 cycles
25.17 - RGB = 402.72 cycles
0.94 - Blank = 15.04 cycles
508 Cycles per line
VSync Start = 2 lines
Vsync blank = 32 lines
480 lines
VSync Blank = 11 lines
Total of 525 lines
#include <SPI.h>
#include <avr/pgmspace.h>
#include <avr/sleep.h>
volatile unsigned int linecount;
#define vSyncLow PORTB &= ~(1 << 0);
#define vSyncHigh PORTB |= (1 << 0);
uint8_t tileData[34*21]; // 714 bytes
set_sleep_mode(SLEEP_MODE_IDLE);
pinMode(11, OUTPUT);
pinMode(8, OUTPUT); // VZync = VGA Pin 14
pinMode(9, OUTPUT); // HZync = VGA Pin 13
digitalWrite(8, LOW);
digitalWrite(11, LOW);
SPI.begin();
SPI.setClockDivider(SPI_CLOCK_DIV2);
SPI.setDataMode(0x04);
memset(tileData,1,sizeof(tileData));
tileData[0] = tileData[3] = 0;
tileData[9] = tileData[12] = 2;
tileData[21] = tileData[21*3] = 0;
tileData[21+7] = tileData[(21+7)*3] = 3;
// Disable Arduino Timer0 and UART Timer
TCCR0A = TCCR0B = 0;
TIMSK0 = 0;
TCCR1A = _BV(COM1A1) | _BV(COM1A0) | _BV(WGM11);
TCCR1B = _BV(WGM12) | _BV(WGM13) | _BV(CS10); // No Prescalar
ICR1 = 508;
TIMSK1 = _BV(TOIE1); // Enable timer overflow interrupt
OCR1A = 60; // HSync Pulse
sei(); // enable global interrupts
uint8_t y = 0;
uint8_t y2 = 0;
uint8_t temp = 0;
int line21 = 0;
extern PROGMEM prog_uchar charData[];
#define topOffset 39
if (linecount >= topOffset && line21 < (34*21))
sleep_mode();
temp = pgm_read_byte_near(charData + (tileData[0+line21]*7) + y);
SPDR = temp; temp = pgm_read_byte_near(charData + (tileData[1+line21]*7) + y);
SPDR = temp; temp = pgm_read_byte_near(charData + (tileData[2+line21]*7) + y);
SPDR = temp; temp = pgm_read_byte_near(charData + (tileData[3+line21]*7) + y);
SPDR = temp; temp = pgm_read_byte_near(charData + (tileData[4+line21]*7) + y);
SPDR = temp; temp = pgm_read_byte_near(charData + (tileData[5+line21]*7) + y);
SPDR = temp; temp = pgm_read_byte_near(charData + (tileData[6+line21]*7) + y);
SPDR = temp; temp = pgm_read_byte_near(charData + (tileData[7+line21]*7) + y);
SPDR = temp; temp = pgm_read_byte_near(charData + (tileData[8+line21]*7) + y);
SPDR = temp; temp = pgm_read_byte_near(charData + (tileData[9+line21]*7) + y);
SPDR = temp; temp = pgm_read_byte_near(charData + (tileData[10+line21]*7) + y);
SPDR = temp; temp = pgm_read_byte_near(charData + (tileData[11+line21]*7) + y);
SPDR = temp; temp = pgm_read_byte_near(charData + (tileData[12+line21]*7) + y);
SPDR = temp; temp = pgm_read_byte_near(charData + (tileData[13+line21]*7) + y);
SPDR = temp; temp = pgm_read_byte_near(charData + (tileData[14+line21]*7) + y);
SPDR = temp; temp = pgm_read_byte_near(charData + (tileData[15+line21]*7) + y);
SPDR = temp; temp = pgm_read_byte_near(charData + (tileData[16+line21]*7) + y);
SPDR = temp; temp = pgm_read_byte_near(charData + (tileData[17+line21]*7) + y);
SPDR = temp; temp = pgm_read_byte_near(charData + (tileData[18+line21]*7) + y);
SPDR = temp; temp = pgm_read_byte_near(charData + (tileData[19+line21]*7) + y);
SPDR = temp; temp = pgm_read_byte_near(charData + (tileData[20+line21]*7) + y);
SPDR = temp;
y2++;
if (y2 == 2)
y2 = 0;
y++;
if (y == 7)
y = 0; line21 += 21;
else if (linecount == 0)
y = y2 = temp = line21 = 0;
ISR(TIMER1_OVF_vect)
if (linecount == 0) vSyncLow;
if (linecount == 2) vSyncHigh;
if (++linecount == 525) linecount = 0;
And the symbols-test:
PROGMEM prog_uchar charData[7*4] = {
B11000110,
B11000110,
B11100110,
B11101110,
B00111000,
B00010000,
B00000000,
B00010000,
B01101100,
B11000110,
B11000110,
B01101100,
B00111000,
B00000000,
B11111110,
B11111110,
B11111110,
B11111110,
B00111000,
B00010000,
B00000000,
B00010000,
B01111100,
B11111110,
B11111110,
B01111100,
B00111000,
B00000000};
