Hey everyone, im trying to help someone with this arduino project for a ultrasonic sensor robot device. Ive verified my connections several times but my servo still wont startup. I was wondering if you lovely people could help me out and determine if its the code or my connections. The code is posted below. Thank you:
#include <Servo.h> #define echoPin 2 #define trigPin 3 #define LED 7 #define Buzz 6
Servo myservo;
int Position = 0; long Durat; int Dist; int currentPosition = 0;
int firstSweep[181]; int secondSweep[181];
myservo.attach(9);
pinMode(Buzz, OUTPUT);
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
pinMode(LED, OUTPUT);
firstScan();
turnServo(true);
turnServo(false);
delay(80);
int checkWave() {
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
Durat = pulseIn(echoPin, HIGH);
Dist = (Durat / 2) / 29.1;
return Dist;
void firstScan() {
for (Position = 0; Position < 181; Position++)
myservo.write(Position); firstSweep[Position] = checkWave();
delay(50);
for (Position = 180; Position >= 0; Position--)
myservo.write(Position); secondSweep[Position] = checkWave();
delay(60);
void turnServo(boolean clockwise)
for (int i = 0; i < 181; i += 1)
int index = clockwise ? i : 180 - i;
int currentDist = clockwise ? firstSweep[index] : secondSweep[index];
myservo.write(index);
currentPosition = checkWave(); if (currentPosition < currentDist + 3 && currentPosition >
currentDist - 3)
digitalWrite(LED, LOW);
digitalWrite(Buzz, LOW);
digitalWrite(LED, HIGH);
digitalWrite(Buzz, HIGH);
delay(60);
}`Preformatted text`
Start by putting each #define on its own line then look carefully at where the turnServo() function ends. Did you miss a closing curly bracket in the code or maybe just when you copied it here ?
I had copied it as is, I did an auto format since I read that sometimes solves these issues or at least makes them easier to solve. But to no avail I have been stuck pondering for a while now
I can confirm the "}" is on the left margin after copying and pasting. I also did the first part of your suggestion and made each "#define" on their own line. It verified but now I am having issues uploading.
I beg to differ. How many curly braces are there after the delay(60) at the end of the code ?
So, you fixed the problem with the #defines but now cannot upload the code
Please post your revised code and the full error message (copied using the Copy Error Message button in the IDE, that you get when trying to upload the code
#include <Servo.h>
#define echoPin 2
#define trigPin 3
#define LED 7
#define Buzz 6
Servo myservo;
myservo.attach(9);
firstScan();
turnServo(true);
turnServo(false);
delay(80);
int checkWave() {
return Dist;
void firstScan() {
delay(50);
delay(60);
currentDist - 3)
delay(60);
Error codes:
Arduino: 1.8.20 Hourly Build 2021/12/20 07:34 (Mac OS X), Board: "Arduino Uno"
/var/folders/tq/tc5bk51d2x5b8gck1_c14msr0000gn/T/arduino_modified_sketch_76876/HelloWorld.ino: In function 'void turnServo(boolean)':
HelloWorld:64:4: error: expected '}' at end of input
exit status 1
option enabled in File -> Preferences.
The board i am using is the UNO R3 Controller Board.
This is the error message I get when I attempt to upload, and sorry. Im fairly new to this stuff, I didnt mean to upset you. I believed I was copying the right stuff.
/var/folders/tq/tc5bk51d2x5b8gck1_c14msr0000gn/T/arduino_modified_sketch_41418/HelloWorld.ino:36:65: warning: null character(s) ignored
Sketch uses 4360 bytes (13%) of program storage space. Maximum is 32256 bytes.
Global variables use 951 bytes (46%) of dynamic memory, leaving 1097 bytes for local variables. Maximum is 2048 bytes.
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x00
Problem uploading to board. See https://support.arduino.cc/hc/en-us/sections/360003198300 for suggestions.
As far as I am aware, the servo is powered through the tethered connection to my laptop which connects to the UNO R3.
I just tried running my code in the sweep example and I am getting a very similar, if not the same error message. I will paste below:
/var/folders/tq/tc5bk51d2x5b8gck1_c14msr0000gn/T/arduino_modified_sketch_785943/Sweep.ino:36:65: warning: null character(s) ignored
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
Have you ever been able to upload a sketch to the Uno ? Does the Serial port selected in the IDE match the port that the Uno is plugged into ? Does your PC recognise the Uno when it is plugged in and create a virtual serial port ?
Yeah, so turns out the uno was not selected. Now it is, code uploaded fine. But my servo's not moving. Does this now eliminate the fact that its a code issue? Also sorry about that mistake. Ive been up a while working on this, so im more prone to making errors.
