est_1
October 21, 2024, 4:45pm
1
Hello
I have an Arduino UNO and switch pushbuttons with protectors like this:
I want to code an interruptor so that when press the pushbutton, two LEDs go HIGH, and when pressing again they go LOW.
I have searched the following help links:
I need to understand the basics for the kids. We use blocks to code. We use Tinkercad for simulation and mBlock to translate the block-code solution into Arduino code. This is what I got:
Circuit:
Arduino code automatically generated by Tinkercad:
// C++ code
int buttonState = 0;
int timesPressed = 0;
pinMode(2, INPUT);
pinMode(11, OUTPUT);
pinMode(12, OUTPUT);
buttonState = digitalRead(2);
if (buttonState == HIGH) {
digitalWrite(11, HIGH);
digitalWrite(12, HIGH);
timesPressed = (timesPressed + 1);
if (timesPressed % 2 == 0) {
digitalWrite(11, LOW);
digitalWrite(12, LOW);
timesPressed = 0;
delay(100); // Wait for 100 millisecond(s)
Block-based solution:
Problem:
Sometimes it bugs, flashing the LEDs or even having to press twice for the LEDs to change state:
Question:
What can be improved from the code (if possible, a block-based answer)? Why does they flash or have to press twice in order to change the LEDs state?
Considerations:
At this time I am unable to test the code in real life.
Of course I could use an interruptor like this:
But we don't have one, so a push button is mandatory.
Thank you!
est_1
October 21, 2024, 4:54pm
4
Thank you for your fast answer!
I've read about debouncing and stuff, but in order to solve it you mean to code the solution using https://docs.arduino.cc/built-in-examples/digital/Debounce/ ?
Oh, I see.
The code without bug should change a lot from the initial code? Can you help me, please?
est_1
October 21, 2024, 4:55pm
5
LarryD:
The kids and I code with blocks.
Go to Tinkercad, start a new project (circuit), drag the components and code with blocks. Then go to the Text view and copy the generated Arduino code
est_1
October 21, 2024, 5:01pm
7
I was thinking maybe using another if condition to avoid immediate change of state, but I couldn't. Any ideas?
est_1
October 21, 2024, 5:07pm
8
I was thinking about these and tried with the following blocks:
// C++ code
pinMode(2, INPUT);
if (buttonState == LOW) {
timesPressed = 0;
It still requires that sometimes have to press more than once, but at least the flickering problem seems to have disappeared.
Also, I put wait 0.1 seconds out the if but I don't know if it is correct.
LarryD
October 21, 2024, 5:28pm
9
#define PRESSED HIGH
#define RELEASED LOW
#define LEDon HIGH
#define LEDoff LOW
const byte mySwitch = 2;
const byte firstLED = 11;
const byte secondLED = 12;
byte timesPressed;
byte buttonState;
byte lastButtonState = LOW;
pinMode(mySwitch, INPUT);
pinMode(firstLED, OUTPUT);
pinMode(secondLED, OUTPUT);
} //END of setup()
buttonState = digitalRead(mySwitch);
//has there been a change in the switch's state ?
if (lastButtonState != buttonState)
//update to this new state
lastButtonState = buttonState;
//poor mans de-bounce
delay(50); //wait for 50 millisecond(s)
//has the switch been pressed ?
if (buttonState == PRESSED)
digitalWrite(firstLED, LEDon);
digitalWrite(secondLED, LEDon);
//has the switch been released ?
else if (buttonState == RELEASED)
digitalWrite(firstLED, LEDoff);
digitalWrite(secondLED, LEDoff);
timesPressed = 0;
} //END of loop()
system
Closed
April 19, 2025, 5:35pm
11
