Coding a Revolution Counter for a Stepper Motor, Id like to pre-program in the source code a fixed number of revolutions. Each 200 steps decrements 1 from the "pre-programmed" number until zero, motor stop.
there are 1000 possible counts, so there are 3 seven segment units with the 4th thousands place is just a 2 segment led for the "1"
So is it possible to count from 1000 to 0 revolutions while outputing a BCD output in real time for 3 LED displays? Ill use direction and pulse pins for the motor to an external H-Bridge, and three 7447 decoders to drive the 3 digits. Ill also use the potentiometer in real time to make fine adjustments to speed.
Also i dont know if (turns decrement 1) can be put at the end of void loop and execute once after every 200 steps?
Ive seen code but dont know how to do conversion to BCD and assign it to output pins.
Some code ive been modding:
Stepper Motor Control - speed control
This program drives a unipolar or bipolar stepper motor.
The motor is attached to digital pins 8 - 11 of the Arduino.
A potentiometer is connected to analog input 0.
The motor will rotate in a clockwise direction. The higher the potentiometer value,
the faster the motor speed. Because setSpeed() sets the delay between steps,
you may notice the motor is less responsive to changes in the sensor value at
low speeds.
Created 30 Nov. 2009
Modified 28 Oct 2010
by Tom Igoe
#include <Stepper.h>
const int stepsPerRevolution = 200; // change this to fit the number of steps per revolution
// for your motor
// initialize the stepper library on pins 8 through 11:
Stepper myStepper(stepsPerRevolution, 8, 9, 10, 11);
int stepCount = 0; // number of steps the motor has taken
// nothing to do inside the setup
// read the sensor value:
int sensorReading = analogRead(A0);
// map it to a range from 0 to 100:
int motorSpeed = map(sensorReading, 0, 1023, 0, 100);
// set the motor speed:
if (motorSpeed > 0) {
myStepper.setSpeed(motorSpeed);
// step 1/100 of a revolution:
myStepper.step(stepsPerRevolution / 100);
You have told us that you want to change the rev count every 200 steps, but you have not told us what commands you are giving to the motor.
If you command the motor to move 200 steps at a time then you can just increment the counter each time the motor is told to move.
If you want the motor to move (say) 1000 steps and you want to update the counter every 200 steps then the standard stepper library is not really suitable because it will block the Arduino until all 1000 steps are complete.
There are two options. The AccelStepper library has a function distanceToGo() which reports how many steps are left. Or you could use the standard stepper library and move the motor one step at a time using your own code to do the step timing.
It would be a potentiometer to speed up or slow down the simple code Ive seen is good enough, the speed update and resolution doesnt need to be super accurate. (The 200 steps per rev needs to be perfect obviously.)
Yes every 200 steps decrement the counter value by 1. This should be simple odometry like a robot car.
Not sure i understand...
Updating the counter slowly is fine, the rotational speed would be one rotation per 3 seconds, so slow compared to most stepper uses.
not sure what to do, this doesnt sound good. Could i program it to slowly ramp up/down to its new speed when each 200th step was completed ?
This device is for winding coils, transformers and motors.
PatrickZ:
You mean every step, decrement the counter by 1. Display counter/stepsPerRevolution on the display. (Notice I don't use the magic-number "200".) So long as you use a variable big enough, you can take millions of steps and the division operation is still "accurate".
The AccelStepper library may be preferable, since it can easily do linear accelerations and decellerations. Tell it to move a million steps and it will smoothly speed up, run and slow down to a stop at the end.
PatrickZ:
I'm inclined to think I don't understand your requirement.
I thought the problem was that you could not (or did not know how to) increment (or decrement) a counter after every revolution of the motor if the Stepper library has been asked to do a large number of steps.
So 1000 then 200 steps, 999 then 200 steps. and so on till zero. While a pot controls the speed faster or slower but always clockwise.
low speeds.
by Tom Igoe
// for your motor
int RotationsNeeded = 1000; // count down display value
int Display = 0;
Serial.begin(9600); // open the serial port at 9600 bps:
Display = RotationsNeeded--;
// new area for serial monitor code
// print labels
Serial.print("Count down"); // prints a label
Serial.print("\t"); // prints a tab
Serial.println(); // carriage return after the last label
Serial.print(Display); // print as an ASCII-encoded decimal - same as "DEC"
Serial.print("\t\t"); // prints two tabs to accomodate the label lenght
Serial.println(); // print as an ASCII-encoded binary
// then adds the carriage return with "println"
delay(200); // delay 200 milliseconds
this is sort of what i crammed together, turn up or down the speed as needed with a pot, while decrementing 1 for every 200 steps of a 200 step motor. I may use a peg or bump to press a micro-switch to do the decrement, it would guarantee the right rotation count even with lost steps. but i would rather a software solution...
It still needs to convert the "Display" variable to BCD and the assign them to pins.
You have not addressed my understanding of the problem as set out in Reply #4. It is much easier to help when your replies follow on from comments you have received so there is a stream of development of ideas rather than things popping up out of the blue. And if you don't understand something please say so - it can save a lot of wasted time.
Also you have posted a program but you have not told us what happens when your run it.
As far as I can see your program causes the motor to move 2 steps at the set speed and then print stuff and wait 200 millisecs before the next 2 steps.
Is that correct, and is it what you want it to do?
Robin2:
...R
I dont know how else to describe my need... revolve once decrement by 1, revolve again decrement again until zero, then stop... all while i can speed up or slow down in real time to avoid tangles or breaking the wire. My digital logic analyzer Isnt working and serial monitor only shows the decrement count. Eventually the code would put out BCD for the LED segments as seen in the beginning pic.
And no what you describe is not what i want.
the emergency stop is easy compared to the rest of this.
PatrickZ:
That description reads as if you would be content for the motor to move 1 rev, stop, decrement the counter, do the next rev, stop, decrement the counter etc. Keep in mind that computers are stupid and interpret instructions literally - they have no capability to figure out what you want.
My guess is that what you really want is for the motor to run continuously for (perhaps) several hundred revs decrementing the counter as each rev is completed.
If so, you need to re-read the last paragraph in Reply #1 for two options for implementing that.
I suggest you try some of the examples that come with the AccelStepper library and study its documentation so you understand how it can be used.
Robin2:
Yes that is what i want.
// ProportionalControl.pde
// -*- mode: C++ -*-
// Make a single stepper follow the analog value read from a pot or whatever
// The stepper will move at a constant speed to each newly set posiiton,
// depending on the value of the pot.
// Copyright (C) 2012 Mike McCauley
// $Id: ProportionalControl.pde,v 1.1 2011/01/05 01:51:01 mikem Exp mikem $
#include <AccelStepper.h>
// Define a stepper and the pins it will use
AccelStepper stepper; // Defaults to AccelStepper::FULL4WIRE (4 pins) on 2, 3, 4, 5
// This defines the analog input pin for reading the control voltage
// Tested with a 10k linear pot between 5v and GND
#define ANALOG_IN A0
stepper.setMaxSpeed(1000);
// Read new position
int analog_in = analogRead(ANALOG_IN);
stepper.moveTo(analog_in);
stepper.setSpeed(100);
stepper.runSpeedToPosition();
This code does the analog in speed control like i want. But i dont see the step/rev that all code needs to know what each steppers step per degree is. my motor is 200 steps per turn. Im trying to use the link you provided.
You have chosen an inappropriate example from the AccelStepper library because runSpeedToPosition() blocks until it completes.
You need to use run() [which uses acceleration] or runSpeed() [which does not]. Study the examples for those functions.
Suppose that you tell the motor to go 1000 steps with myStepper.move(1000); Then in every iteration of loop() you can check how far it has got with code in loop() like this
PatrickZ:
Does this go in the void loop section, and more in the void setup ?
It must go in the loop() function (or be called from loop() ) as it needs to be checked regularly.
You will need to declare the relevant variable before the setup() function.
I suspect you would benefit from taking a little time to study the basics of Arduino C++ programming so you have a better idea where things need to go in programs.
There is not enough information to tell you how to display a number on your 7-segment displays. A wiring diagram would help.
low speeds.
by Tom Igoe
// for your motor
long int stepCount = 0; // number of steps the motor has taken
void display(int value)
// Display the value on the 3+ digit display
if (motorSpeed > 0)
int stepsToTake = stepsPerRevolution / 100;
// Only move if we have not reached the limit
if (stepCount + stepsToTake < 1000L * stepsPerRevolution)
stepCount += stepsToTake;
int revolutionsTaken = stepCount / stepsPerRevolution;
display(1000 - revolutionsTaken);
Robin2:
...R
Ive done 2 semesters of c++ in college 14 years ago. But we never turned pins on or off. i know some basic and propeller stuff. but how and in what way to use libraries and functions is something i stuggle with. thats why i appreciate your help. I do have an Arduino for dummies book.
yes, i think we can agree to figure out BCD and pinouts to 7447 ic's can wait until ive gotten the rest of my furball together. And i did find a library for seven segment leds.
PatrickZ:
Turning pins on and off is just detail stuff and you can look up the syntax in the Reference section. My comment was prompted by your question (in Reply #12) " Does this go in the void loop section, and more in the void setup ? "
I have glanced through that in a bookshop and it looked good. Sailing for Dummies was excellent
