Hello. I am now working on my project on studying how each plastic injection parameter affercts the mold deflection. I decided to use a strain gauges to collect the deformation that occurs while injecting the workpiece. I applied my strain gauge to HX711 module and serial monitor via arduino UNO to see the value. But there is one thing I concerned is I'm not really sure about the calibration factors I'm using and how to know which value I should use and what is the raw data that came from the HX711 module.
So if anyone here has used or has some idea please help me.
From the code, I applied 2 Hx711 but in the schematic, I only draw 1 Hx711
#include "HX711.h"
#define DOUT 2
#define CLK 3
#define DOUT2 4
#define CLK2 5
HX711 scale1;
HX711 scale2;
float calibration_factor = -700000; // set up calibration factor here
float calibration_factor2 = -700000;
// Serial.println("HX711 calibration sketch");
// Serial.println("Remove all weight from scale");
// Serial.println("After readings begin, place known weight on scale");
// Serial.println("Press + or a to increase calibration factor");
// Serial.println("Press - or z to decrease calibration factor");
scale1.begin(DOUT, CLK);
scale1.set_scale();
scale1.tare(); //Reset the scale to 0
scale2.begin(DOUT2, CLK2);
scale2.set_scale();
scale2.tare();
// long zero_factor = scale1.read_average(); //Get a baseline reading
// long zero_factor = scale2.read_average();
// Serial.print("Zero factor: "); //This can be used to remove the need to tare the scale. Useful in permanent scale projects.
// Serial.println(zero_factor);
scale1.set_scale(calibration_factor); //Adjust to this calibration factor
scale2.set_scale(calibration_factor2);
// Serial.print("Reading: ");
Serial.print("SG Left : ");
Serial.print(scale1.get_units(), 5);
Serial.print(" || SG Right (compensate) : ");
Serial.println(scale2.get_units(), 5);
//Serial.println(" lbs"); //Change this to kg and re-adjust the calibration factor if you follow SI units like a sane person
// Serial.print(" calibration_factor: ");
// Serial.print(calibration_factor);
// Serial.println();
if(Serial.available())
char temp = Serial.read();
if(temp == '+' || temp == 'a')
calibration_factor += 10;
else if(temp == '-' || temp == 'z')
calibration_factor -= 10;
delay(100);
I'd use '1' and post-process the raw values until you figure out how to calibrate your system.
I'd also move the ...set_scale(calibration_factor); stuff inside of the Serial.read(); ... stuff because it's a confusing waste of time to re-set the calibration factor if you haven't actually changed it.
If your primary interest is not the "exact" magnitude of strain for a certain injection parameter, but ratios or differences between strains caused by different injection parameters, then the above approach may be sufficient.
But if you really need more accurate values, the shunt calibration method may be the only practical way, if the "mold" is so complex that you can't apply a known "load" that causes a known strain.
Also, this sort of project is often combined with a finite element analysis, to compare modeled vs measured values.
Usually, I do 2-point calibration for the Load Cell/Strain Gauge to find the Gain and Offset of the system.
A(W1, C1) //known weight-1 applied on Strain Gauge; C1 = Count (value of ADC)
B(W2, C2) //known weight-2 on Strain gauge
C(W, C) //unknown weight to be measured.
W1-W2/C1-C2 = W1-W/C1-C
==> W = mC + k //m = Gain; k = offset
Sketch to find gain and Offset
/* This program takes 10 samples from LC + HX711B at
1-sec interval and then computes the average.
unsigned long x = 0, y=0;
unsigned long dataArray[10];
int j = 0;
pinMode(2, INPUT); //data line //Yellow cable
pinMode(3, OUTPUT); //SCK line //Orange cable
for (int j = 0; j < 10; j++)
digitalWrite(A0, LOW);//SCK is made LL
while (digitalRead(2) != LOW) //wait until Data Line goes LOW
for (int i = 0; i < 24; i++) //read 24-bit data from HX711
clk(); //generate CLK pulse to get MSB-it at A1-pin
bitWrite(x, 0, digitalRead(A1));
x = x << 1;
clk(); //25th pulse
Serial.println(x, HEX);
y = x;
x = 0;
dataArray[j] = y;
Serial.println("===averaging process=========");
unsigned long sum = 0;
for (j = 0; j < 10; j++)
sum += dataArray[j];
Serial.print("Average Count = ");
sum = sum / 10;
Serial.println(sum, HEX);
// float W = (float)0.90*(sum-901002)/946560 + 0.75;//0.005331 * sum - 1146.176;
//W = (float)W / 1000.00;
// Serial.println(W, 2);
void clk()
digitalWrite(3, HIGH);
digitalWrite(3, LOW);
"Strength of materials" (aka "mechanics of materials") principles are usually used to select gauges, decide where to apply them, and to interpret the resulting strains.
For simple problems, those principles take the form of simple formulas that are covered in first-year university classes for structural engineers and mechanical engineers. Similar principles are used for complex problems, though hidden within analysis software.
