Collision Avoidance Robot Swiffer Fuzzy Logic
Hi, I am trying to build a little robot to clean the dust on the floor in our house.
Based on an Arduino Uno with a CNC shield, 2 stepper motors to drive the 2 wheels, 2 switches to sense nearby walls and an US sensor (HC-SR05) to measure distances to obstacles, battery operated at 12V.
The random targets (distance and angle) together with the distance to obstacle are fed into a fuzzy logic algorithm with an output of 2 speeds, one for the left motor and one for the right motor. These speeds are used to calculate 2 pulse durations that are fed into OCR1A and OCR1B of Timer1. Timer1 is setup in Normal mode with a prescaler of 8. Timer1 is handling 2 ISR routines on compare match OCR1A/B. These ISRs generate 2 pulse trains with different frequencies to result in 2 different motor speeds...and everything works fine...most of the time.
After a number of random targets (mostly around 20) the software start running around wasting time.
In normal operation Timer1 overflows a number of times (between 40 and 80 times) before moving to the next target, but f.e. at target nr 21 it starts overflowing between 200 to 350 times and I can not find any reason for that.
Any suggestion would be appreciated. Thank you.
// Collision Avoidance Swiffer Robot Fuzzy Logic
#include "Configuration.h"
#include <NewPing.h>
NewPing sonar(usTrig, usEcho, usMaxD);  //setup sonar
#include "PinChangeInterrupt.h"
#include "MeasDist.h"
#include "switchesHR.h"
#include "Fuzzification.h"
#include "Defuzzification.h"
    noInterrupts ();
        TCCR1A = 0; TCCR1B = 0; TIMSK1 = 0;
        bitClear(TCCR1A, WGM10);
        bitClear(TCCR1A, WGM11);
        bitClear(TCCR1B, WGM12);
        bitClear(TCCR1B, WGM13);        // Normal mode
        bitClear(TCCR1B, CS10);
        bitSet(TCCR1B, CS11);
        bitClear(TCCR1B, CS12);         // Prescaler : 8
        bitSet(TIFR1, OCF1A);
        bitSet(TIFR1, OCF1B);
        bitSet(TIFR1, TOV1);            // Clear Interrupt Flags
        bitSet(TIMSK1, OCIE1A);         // Output Compare match Interrupt Enable 1A
        bitSet(TIMSK1, OCIE1B);         // Output Compare match Interrupt Enable 1B
        bitSet(TIMSK1, TOIE1);          // Enable Overflow Interrupt
        OCR1A = cntLM;                  // Count for left motor pulses
        OCR1B = cntRM;                  // Count for right motor pulses
        TCNT1 = 0;                      // Timer1 set count to 0
    interrupts ();
    pinMode(leSwPin, INPUT_PULLUP);
    attachPCINT(digitalPinToPCINT(leSwPin),fncMLeftSw, FALLING);
    pinMode(riSwPin, INPUT_PULLUP);
    attachPCINT(digitalPinToPCINT(riSwPin),fncMRightSw, FALLING);
    pinMode(mEnpin, OUTPUT);            // Motors Enable pin
    pinMode(mXstepP, OUTPUT);           // Left stepper motor
    pinMode(mXdirP, OUTPUT);            // HIGH = forward or LOW= backward
    pinMode(mYstepP, OUTPUT);           // Right stepper motor
    pinMode(mYdirP, OUTPUT);            // LOW = forward or HIGH= backward
    digitalWrite(mEnpin, LOW);          // enable motors
    cntLM = 800; incLM = 800;
    cntRM = 800; incRM = 800;
    randomSeed(analogRead(0));
    if (nrSt <= 0){
//        fncswitchesHR();
        fncMeasDist();
        dTarget = random(1000,8000);
        tTarget = -pi + (2*pi*random(0,10001))/10000;
        bitClear(TIMSK1, OCIE1A);
        bitClear(TIMSK1, OCIE1B);
        fncFuzzification();
        fncDefuzzification();
        cntLM = int(stDelay/vL); cntRM = int(stDelay/vR);
        incLM = cntLM; incRM = cntRM;
        nrSt = int(8 * dTarget);        //60000;
        Serial.print(dTarget); Serial.print("  "); Serial.print(tTarget); Serial.print("  ");
        Serial.print(cntLM); Serial.print("  "); Serial.print(cntRM); Serial.print("  ");
        Serial.print(nrSt); Serial.print("  "); Serial.println(overflowCnt);
        overflowCnt = 0;
void fncMLeftSw(){
// reverse run Rmotor 200 steps
    if (rightSw == true){
        digitalWrite(mYdirP, HIGH);
        for (int steps = 0; steps < 200; steps++) {
            digitalWrite(mYstepP, HIGH);
            delayMicroseconds(stDelay);
            digitalWrite(mYstepP, LOW);
            delayMicroseconds(stDelay);}
        leftSw = true;
void fncMRightSw(){
// reverse run Lmotor 200 steps
    if (leftSw == true){
        digitalWrite(mXdirP, LOW);
            digitalWrite(mXstepP, HIGH);
            digitalWrite(mXstepP, LOW);
        rightSw = true;
ISR(TIMER1_COMPA_vect){
    digitalWrite(mXdirP, HIGH);
    pulseLM = !pulseLM;
    digitalWrite(mXstepP, pulseLM ? HIGH : LOW);
    cntLM = cntLM + incLM;
    OCR1A = cntLM;
    nrSt--;
ISR(TIMER1_COMPB_vect){
    digitalWrite(mYdirP, LOW);
    pulseRM = !pulseRM;
    digitalWrite(mYstepP, pulseRM ? HIGH : LOW);
    cntRM = cntRM + incRM;
    OCR1B = cntRM;
    nrSt--;
ISR(TIMER1_OVF_vect){
    overflowCnt++;
Problem solved
