Collision Avoidance Vehicle
Hello, I have been building a collision avoidance vehicle with a DIY sensor on the front of the vehicle and a kit sensor mounted on a servomotor at the back of the vehicle. These work fine, and will override the drive commands if an object is in the way. However, the drive of the vehicle it not so good, with it being jumpy.... I believe to be because of the delays (with the servo function). Can anyone suggest, how can I get around this, is there anyway to run two functions at the same time?
Any help will be welcomed.
#include <Servo.h>
Servo scanservo;     //Ping Sensor Servo
#define txPin 4
#define rxPin A4
const int motor1 = 12;
const int motor2 = 9;
const int steer1 = 13;
const int steer2 = 8;
const int PWM_M = 3;
int up = 0;
int down = 0;
int left = 0;
int right = 0;
const int a = 800;
const int turntime = 500;  //Number of milliseconds to turn when turning
const int pingPin = 6;     //Pin that the Ping sensor is attached to.
const int echoPin = 5;     //Pin that the Ping sensor is attached to.
const int scanservopin = 7;   // Pin number for scan servo
const int distancelimit = 30;
  Serial.begin (9600);
  scanservo.attach(scanservopin); // Attach the scan servo
  pinMode(echoPin, INPUT);
  pinMode(rxPin, INPUT);
  pinMode(txPin, OUTPUT);
  pinMode(A0, INPUT);
  pinMode(A1, INPUT);
  pinMode(A2, INPUT);
  pinMode(A3, INPUT);
  pinMode(motor1, OUTPUT);
  pinMode(motor2, OUTPUT);
  pinMode(steer1, OUTPUT);
  pinMode(steer2, OUTPUT);
  digitalWrite(motor1,LOW);
  digitalWrite(motor2,LOW);
  digitalWrite(steer1,LOW);
  digitalWrite(steer2,LOW);
void loop(){
left = analogRead(A0);
Serial.print("left:  ");
Serial.println(left);
right = analogRead(A1);
Serial.print("right:  ");
Serial.println(right);
down = analogRead(A3);
Serial.print("down:  ");
Serial.println(down);
up = analogRead(A2);
Serial.print("up:  ");
Serial.println(up);
int sensor = pingforward();
Serial.print("sensor:  ");
Serial.println(sensor);
  int leftscanval = scanleft();
  Serial.print("leftscanval:  ");
  Serial.println(leftscanval);
  int rightscanval = scanright();
  Serial.print("rightscanval:  ");
  Serial.println(rightscanval);
  int centerscanval = scancenter();
  Serial.print("centrescanval:  ");
  Serial.println(centerscanval);
  if (down < 400 && centerscanval > distancelimit){
  backward(1);
  if (up < 400  && sensor > 150){
  forward(1);
  if (left > 400  && leftscanval > distancelimit){
  turnleft(1);
  if (right > 400  && rightscanval > distancelimit){
  turnright(1);
  if (down > 400 && up > 400 && left < 400 && right < 400){
  stopmotors(1);
void turnleft(int t){
  digitalWrite (13, HIGH);
  digitalWrite (8, LOW);
  digitalWrite (11, HIGH);
  delayMicroseconds(t);
void turnright(int t){
  digitalWrite (13, LOW);
void stopmotors(int t){
  digitalWrite (9, LOW);
  digitalWrite (3, LOW);
  digitalWrite (11, LOW);
  void forward(int t){
  digitalWrite(12, HIGH);
  digitalWrite(9, LOW);
  digitalWrite(PWM_M, HIGH);
  delay(t);
void backward(int t){
  digitalWrite (12, LOW);
  delay(t);
int ping(){
  long distance, duration;
  //Send Pulse
  pinMode(pingPin, OUTPUT);
  digitalWrite(pingPin, LOW);
  delayMicroseconds(2);
  digitalWrite(pingPin, HIGH);
  delayMicroseconds(5);
  //Read Echo
  duration = pulseIn(echoPin, HIGH);
  distance=(duration/2)*0.0341;
  return distance;
int pingforward(){
    long senseforward;
    for (int i = 0; i < 8; i++) {
    digitalWrite(txPin, LOW); // this sends out a short pulse for 10ms
    delayMicroseconds(9);
    digitalWrite(txPin, HIGH);
    delay(2);
    senseforward = analogRead(A4); // us the ping() function to see if anything is ahead.
    return senseforward;
char scanleft(){
  long leftscanval;
  scanservo.write(30);
  leftscanval = ping();
  return leftscanval;
char scanright(){
  long rightscanval;
  scanservo.write(150);
  rightscanval = ping();
  return rightscanval;
char scancenter(){
  long centerscanval;
  scanservo.write(90);
  centerscanval = ping();
  return centerscanval;
The delay 1000 during your scans are halting the code for a second at a time. Nothing processes during that time. I skipped the interesting appearance of a servo scanning front sensor for a more practical solution of 3 fixed sensors. The moment one sensor triggers the need for a decision, the data to make that decision is already there and it can be made without pausing.
Thanks for replying, yes I did think about using multiple sensors but as I am using an UNO i'm limiting by the number of I/O I have left. I was thinking that there may be some other way to delay that doesn't halt the code. Maybe using timers such as millis()...but I don't quite have the knowledge of Arduino programming to know how to use them just yet
Using a timer would allow the code to continue to flow. My only concern would be that the robot is driving forward and looking in a different direction, and runs into an obstacle. I notice that most of the panning ping sensor robots look forward, stop when they encounter an obstacle, then scan left and right to choose which way to proceed. With three sensors, you can keep moving.
With three sensors
... you have to be even more careful about making sure there are no returns from previous pings still in flight.
I am having really good results with one forward facing sensor and one at each front corner, facing forward at 45 degrees. I also have the timing set for 35 milliseconds between firings. No cross interference, even in a hallway with solid walls. I also tried two forward facing sensor and inference was fierce unless you really staggered the left and right pinging. I was trying to sense the direction of approach of a cross path moving obstacle. The code I am using is based off the newping 15 ping sensor example.
I'm going to have a bash at using timers. Something simple like this
Starttimer=millis()
Endtimer=Starttimer + 500;
So thought I'd try and simplify things a bit to try and experiment using timers as a delay to blink an LED for now. However, not working at the moment...this is where I'm at..
unsigned long previousMillis;
unsigned long starttimer;
unsigned long endtimer;
unsigned long present;
long interval = 1000;
  pinMode(13, OUTPUT);
 void loop(){
  present = millis();
  Serial.print("present:  ");
  Serial.println(present);
  starttimer = millis();
  Serial.print("starttimer:  ");
  Serial.println(starttimer);
  endtimer = starttimer + interval;
  if (endtimer < present)
  digitalWrite(13, LOW);
Ooops just this second I've found the blink without delay example which works,
Hoping to incorporate that into the main code now to add the delay. Sweeeeet
How do you know it isn't working?
This is what I'm trying now
I don't think Its having it though
#include <Servo.h>
#define txPin 4
#define rxPin A4
int up = 0;
int down = 0;
int left = 0;
int right = 0;
const int a = 800;
long previousMillis = 0;
  pinMode(A0, INPUT);
  pinMode(A1, INPUT);
  pinMode(A2, INPUT);
  pinMode(A3, INPUT);
void loop(){
Serial.println(up);
  backward(1);
  forward(1);
  turnleft(1);
  turnright(1);
  stopmotors(1);
  delay(t);
  delay(t);
int ping(){
  //Send Pulse
  //Read Echo
  distance =(duration/2)*0.0341;
  return distance;
int pingforward(){
    long senseforward;
    delay(2);
int scanleft(){
  long leftscanval;
  if(currentMillis - previousMillis > interval) {
  return leftscanval;
int scanright(){
  long rightscanval;
int scancenter(){
  long centerscanval;
Call the version of pulseIn that takes a timeout value and provide a suitable timeout.
Could you give me an example?
Not too familiar with how to use pulseIn
http://arduino.cc/en/Reference/PulseIn
Is today International Spoon-feeding Day, and I missed the announcement?
Ha, one can hope!
