Even if COM7 appears with correct parameters in cmd MODE, as soon as I open Arduino IDE, the same command do not show COM7 anymore and upload gives an error (avrdude: ser_open(): can't open device "\.\COM7": Access is denied. Failed uploading: uploading error: exit status 1).
Closing IDE brings COM7 again.
Does anyone had this issue before? Thanks for any help.
Windows 11 and Arduino 2.3.2
Hi @pauloscheidegger .
Please provide a detailed description of what you mean by this. Make sure to provide enough information to allow us to reproduce the problem.
Only one process can have control over a serial port at a time. So it might be that whatever you are doing "in cmd MODE" is interfering with Arduino IDE's ability to upload to the port, and likewise Arduino IDE might be interfering with the use of the port "in cmd MODE".
Thank you for your reply, @ptillisch .
Run> cmd> mode> Enter is my short way to say I called the command line editor, typed MODE and hit Enter key.
If I turn the PC on with nothing connected to the port used by my Arduino PRO Mini (via an USB-TTL adapter) and Run cmd > mode > Enter, it shows just the CONsole device.
After connecting the adapter to the USB port and Run cmd> mode> Enter again, it shows the CON device and the COM7 device with 1200 bps setting. After adjusting to 9600 bps, COM7 still appears with the new configuration.
But after opening Arduino IDE and Run cmd> mode> Enter again, it shows only the CON device. Understandably, trying to upload any code produces the can't open COM7 device error. I must say Arduino IDE shows Arduino PRO Mini on COM7 at the lower right banner all the time.
Closing Arduino IDE and repeating Run mode command it shows both CONsole and COM7 devices normally.
Is there another info required? My PC has 3 USB ports, one has the wireless mouse dongle, another has an external HD and the third one has the Arduino. I could attach screenshots if my description is not clear enough.
Thanks for the clarification.
I can reproduce this by opening the Arduino IDE Serial Monitor . You might not notice that it is open because it is a tab in the bottom panel of the Arduino IDE window. Arduino IDE remembers whether you had Serial Monitor open the last time you had the sketch open, so when you start Arduino IDE, it will automatically open Serial Monitor.
Close Serial Monitor by clicking the X icon on the "Serial Monitor " tab in the bottom panel of the Arduino IDE window:
After doing that, run the mode command again. You should now see the COM7 listed, even while Serial Monitor is running.
Please tell us which USB to serial bridge chip is on the adapter you are using with the Pro Mini board. This will be the largest black chip on the adapter.
The chip will usually be identified by writing on the top. This might say something like "WCH CH340G " or "FTDI FT232RL ".
Examples:
π·
SparkFun - CC BY-SA 4.0 (cropped)
π·
ICIC-SS28-X-K232-01 by oomlout - CC BY-SA 2.0 (cropped)
If it isn't clear, alternatively you can provide the link to where you bought the adapter from and we'll see if we can determine the chip from the product listing.
Thank you very much @ptillisch ! You nailed it!
Now it uploads perfectly. And my adapter uses a FTDI FT232RL chip.
From now on I'll always close the Serial Monitor before leaving IDE.
Thank you!
You are welcome. I'm glad it is working now.
Although Arduino IDE is designed to allow uploading while Serial Monitor is open (it automatically closes the port in Serial Monitor at the start of the upload, then opens it again after), there is a bug that causes uploads to fail with this "Access is denied" error when using an FTDI FT232R chip:
opened 07:07AM - 23 Dec 22 UTC
conclusion: resolved
topic: code
type: imperfection
### Describe the problem
In order to upload to an Arduino board via a serial β¦ port, the upload tool (e.g., [**AVRDUDE**](https://github.com/avrdudes/avrdude)) must be able to open the port. This is not possible if another process already has control of the port.
Arduino IDE's "Serial Monitor" and and "Serial Plotter" components also use the serial port of the board. Arduino IDE handles this potential conflict of port usage automagically by closing the port in Serial Monitor/Plotter when an upload process is triggered, then opening it again after the upload is finished. This means no special action is needed from the user to upload while Serial Monitor/Plotter is open.
π The upload fails with an "`Access is denied`" error under the following conditions:
- The board uses an FTDI FT232R USB chip
- Arduino IDE is running on a Windows machine
- Serial Monitor or Serial Plotter is open
I've been using Arduino IDE 2.0.3 with Nano without issues when uploading on Ubuntu. Now I've tried it on Windows 11, and most of the time, it gives me this error:
```text
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Users\macie\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
Using Port : COM5
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: ser_open(): can't open device "\\.\COM5": Access is denied.
But I can see logs from the serial monitor in Arduino IDE -> serial monitor.
### To reproduce
#### Equipment
A board or other device that has an [FTDI FT232R USB chip](https://ftdichip.com/products/ft232rl/)
The [classic **Arduino Nano**](https://docs.arduino.cc/hardware/nano) is a common board that uses this chip.
FT232R modules ([example](https://docs.arduino.cc/retired/other/usb-serial-converter)) or cables ([example](https://www.sparkfun.com/products/9717)) are also often used to upload to boards such as the [**Arduino Pro Mini**](https://www.sparkfun.com/products/11113) that don't have an integrated USB chip.
The fault can be reproduced even if the FT232R-based device is not an Arduino board. In this case, the upload is expected to fail, but it would fail with a "`not in sync`" error instead of "`Access is denied`".
#### Steps
1. Select **File > New Sketch** from the Arduino IDE menus.
1. Connect the Arduino board to your computer.
1. Select the board and port from the Arduino IDE menus.
1. If the Serial Monitor view is not already open, select **Tools > Serial Monitor** from the Arduino IDE menus to open it.
1. Select **Sketch > Upload** from the Arduino IDE menus.
1. Wait for the upload process to finish.
π The upload fails:
```text
Using Port : COM5
1. Click the **X** icon on the "**Serial Monitor**" view tab in the bottom panel.
π The upload is successful.
1. Select **Tools > Serial Plotter** from the Arduino IDE menus.
π The upload fails:
```text
Using Port : COM5
1. Close the "**Serial Plotter**" window.
π The upload fails:
```text
Using Port : COM5
**β** This unexpected result is caused by a separate bug: https://github.com/arduino/arduino-ide/issues/1423
### Expected behavior
Serial Monitor and Serial Plotter do not interfere with upload process.
### Arduino IDE version
#### Original report
2.0.3
#### Last verified with
aa9b10d
### Operating system
Windows
### Operating system version
Edition Windows 11 Pro
Version 22H2
Installed on 07/11/2022
OS build 22621.963
Experience Windows Feature Experience Pack 1000.22638.1000.0
### Additional context
I bisected the introduction of the fault to df8658e
Logs generated from an upload that fails with this fault using the build for 053574b with the `arduino.cli.daemon.debug` [advanced setting](https://github.com/arduino/arduino-ide/blob/main/docs/advanced-usage.md#advanced-settings) set to `true`:
[2023-08-16_log.log](https://github.com/arduino/arduino-ide/files/12357046/2023-08-16_log.log)
I have no problems uploading sketches on Arduino IDE 1.8.19 from Microsoft Store on the same system. I can quit 2.0.3, start 1.8.19, and it's working immediately.
I cannot reproduce the fault on Linux (Ubuntu 22.04) or macOS (Ventura).
I cannot reproduce the fault when using native USB boards (e.g., [**Leonardo**](https://docs.arduino.cc/hardware/leonardo), [**MKR**](https://docs.arduino.cc/#mkr-family)) or boards that use other models of dedicated USB chip (e.g., ATmega16U2 on Uno and Mega, WCH CH340 on derivative boards).
<a name="workaround"></a>
#### Workaround
<a name="serial-monitor"></a>
##### Serial Monitor
1. Click the **X** icon on the "**Serial Monitor**" tab in the bottom panel of the Arduino IDE window to close the tab:
1. Upload the sketch.
1. Open **Serial Monitor** again if needed (by clicking the icon on the IDE toolbar or the **Tools > Serial Monitor** menu item) after the upload is finished.
<a name="serial-plotter"></a>
##### Serial Plotter
1. If the "**Serial Monitor**" view is not already open, select **Tools > Serial Monitor** from the Arduino IDE menus to open it.
**β** We must do an open/close cycle on **Serial Monitor** as a workaround for [a bug](https://github.com/arduino/arduino-ide/issues/1423) in **Serial Plotter**
1. Open **Serial Monitor** and/or **Serial Plotter** again if needed after the upload is finished.
#### Additional reports
- https://github.com/arduino/arduino-ide/issues/1937
- https://github.com/arduino/arduino-ide/issues/726#issuecomment-1464313325
- https://github.com/arduino/arduino-ide/issues/1783#issuecomment-1614370292
- https://github.com/arduino/arduino-ide/issues/1783#issuecomment-2196936864
- https://forum.arduino.cc/t/brand-new-nano-wont-connect-to-latestide-software/1129473/10
- https://forum.arduino.cc/t/arduino-nano-not-able-to-upload-comx-port-access-denied/1081669/15
- https://forum.arduino.cc/t/elusive-uno-upload-error-access-is-denied/1067785/5
- https://forum.arduino.cc/t/fdti-breakout-2-types-cause-usb-acess-denial/1088005
- https://forum.arduino.cc/t/port-access-is-denied/1089761
- https://forum.arduino.cc/t/cant-open-device-when-uploading-but-serial-monitor-works/1127731
- https://forum.arduino.cc/t/2-1-0-no-longer-disables-monitor-during-upload-update/1139065
- https://forum.arduino.cc/t/access-denied-when-uploading-to-arduino-nano/1139330/1
- https://forum.arduino.cc/t/access-denied-when-uploading-to-arduino-nano/1139330/11
- https://forum.arduino.cc/t/2-11-com3-access-is-denied/1143750
- https://forum.arduino.cc/t/cannot-upload-to-arduino-nano/1145391
- https://forum.arduino.cc/t/cant-upload-to-pro-mini-port-access-is-denied/1152460
- https://forum.arduino.cc/t/cannot-upload-to-ftdi-megas-only/1170683
- https://forum.arduino.cc/t/arduinon-nano-access-denied/1181808/6
- https://forum.arduino.cc/t/avrdude-ser-open-cant-open-device/1228096
- https://forum.arduino.cc/t/avrdude-ser-open-cant-open-device-com9-access-is-denied/1205151
- https://forum.arduino.cc/t/exit-status-1-only-sometimes/1180375
- https://forum.arduino.cc/t/have-to-kill-serial-monitor-exe-to-upload-to-the-board/1173764
- https://forum.arduino.cc/t/arduino-nano-not-recognised-correctly/1133051
- https://forum.arduino.cc/t/arduino-nano-avrdude-ser-open-cant-open-device-com5-access-is-denied/1124189
- https://forum.arduino.cc/t/i-have-a-problem-while-uploading-to-arduino-pro-mini/1255072
- https://forum.arduino.cc/t/problem-uploading-to-nano/1267124
- https://forum.arduino.cc/t/nano-appears-as-com6-and-doesnt-work/1273314
- https://www.reddit.com/r/arduino/comments/1bhwt6f/access_is_denied_error_on_nano/
#### Related
- https://forum.arduino.cc/t/issue-with-flashing-esp32-dev-kit-with-arduino-ide/1117755
- https://forum.arduino.cc/t/port-issues-with-ide-2-0-3/1069090
### Issue checklist
- [X] I searched for previous reports in [the issue tracker](https://github.com/arduino/arduino-ide/issues?q=)
- [X] I verified the problem still occurs when using the latest [nightly build](https://www.arduino.cc/en/software#nightly-builds)
- [X] My report contains all necessary details
