Aim: I'm trying a sketch to read Voltages via Arduino pro mini. I can upload the sketch to the Arduino fine (I used the blink program, which works fine). The problem is when I go to use the serial monitor, I get "board at null is not available" which from my understanding means the com port isn't set? When I go to select the com port it is greyed out. When I go to device manager to see what com port is assigned, there are none. I have provided an image of what my Arduino is coming up as in device manager and the driver that I used via the zadig tool recommended by sparkfun.
What are you using to program the promini and what settings have you selected?
Hardware: I am using the sparkfun avr pocket programmer.
In Arduino > Tools > I have Arduino pro mini selected.
Arduino > Tools > Processor "ATmega328p (5V, 16MHz)
Arduino > Tools > Programmer "USBTinyISP"
I did just read that USBtiny isn't a serial device and can't create one. Would this be my problem? If it is, is there anything I can do to achieve my aim?
Yes, that is your problem. The solution is to buy a so-called FTDI cable (e.g. FTDI Cable 5V - DEV-09718 - SparkFun Electronics; this one is 5V, there is a 3.3V version as well) or a TTL-to-USB converter (e.g. SparkFun USB to Serial Breakout - FT232RL - BOB-12731 - SparkFun Electronics).
You did already buy a programmer but https://www.pololu.com/product/3172 would have been the better choice; it offers all the functionalities that you need (ISP programmer as well as TTL-to-USB converter). Those that have it (I have the V2.0) are convinced that it's the best you can buy for the given purpose.
Wicked. Thanks mate. I'll go the pololu then, mob in Australia sell them for a reasonable price.
This probably wasn't your problem but I was setting up for a new python sketch for ESP32 but Tools>>Port was greyed out. I chased around, installed PySerial. Still no Port options. Then I plugged in the board and Voila!
