So I am taking on this project where I want to build safe that is password protected. I am going to use a keypad to give access to the safe with a combination code. The issue is that I only want the user to gain access to the safe once a day regardless of the code. So I had two ideas. One would be that there´s an auto-generated password every day - I´m not sure I like this idea. It seems harder than it needs to be. The other would be if I could somehow restrict the user in code.
I am not an Arduino expert, although I´ve dabbled with it some. My question is if this is do-able and I would also appreciate a nudge in the right direction.
I havent started the project so I dont have any code to supply as of yet. But I guess I will be using an arduino, a keypad and a solenoid lock.
If you want to restrict the user to once each calendar day, you will need a clock and a way to store the date of the most recent opening. You will also need to store that information in EEPROM so that it survives reset or power cycling.
Hi! Thanks for the reply. Sure. I mean I could have a 24 hour timer set every time the safe is opened. I am thinking of making this as a means of limiting myself to snus ( which is this swedish nicotine ) So I need to be able to open it once every 24 hours (or more ) to get my daily dose out.
