I am a complete noob when it comes to coding and sketching. I do highly detailed models, and do lighting in them. Up until now, it's typically been just pre-wired 9v LEDs, 3v SMD LEDs and at times combined with fiber optics.
But I have a new model I'm working on where I want some action in the engine. So I have a Trinket with a single neopixel LED and I've created 3 sketches that on their own all work just fine. Sketch 1- fade from 0 to full yellow brightness. Sketch 2- fade from yellow to red. Sketch 3- flicker red. So I want to combine these into a single sketch where the engine warms up yellow, heats up to red and then flickers. But I cannot figure out how to combine the sketches together to make it a single action.
I also don't know how to present my sketches here for help. Do I upload the .ino file? Or do I copy and paste the sketch? Sorry for the ignorance. Never touched any of this before.
Please read the first post in any forum entitled how to use this forum. http://forum.arduino.cc/index.php/topic,148850.0.html then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
OK. Don't know how to draw a circuit. Here's a photo of my setup. Just a single neopixel, gnd to gnd on Trinket, postive to 3v on Trinket, and pin 1 to the data input on the neopixel.
And here are my 3 sketches. Again, I want sketch 1 to run and when done go to 2, then 2 go to 3. And 3 would then run infinitely.
Sketch 1
// Simple yellow brightness fade up from 0 to full
// (c) 2017 Christopher Olson
// Which pin on Trinket is connected to the Neopixel
#define PIN 1
// Parameter 1 = number of pixels
// Parameter 2 = Trinket pin number
// Parameter 3 = pixel type flags, add together as needed:
Adafruit_NeoPixel strip = Adafruit_NeoPixel(1, PIN, NEO_GRB + NEO_KHZ800);
strip.setPixelColor(0, 255, 255, 0); // pixel color set to yellow
strip.begin();
strip.show();
for (int i = 1; i <255; ++i){
strip.setBrightness(0+i); // brings up brightness from 0 to full
strip.show();
delay (40); // speed of brightness adjustment
Sketch 2
// Simple yellow to red color fade
#define PIN 1
strip.begin();
strip.show();
for (int i = 255; i >0; --i){
strip.setPixelColor(0, 255, i, 0); // fades pixel color from yellow to red
strip.show();
delay(25); // speed of color fade
Sketch 3
// Simple red flicker effect
#define PIN 1
strip.begin();
strip.setPixelColor(0, 255, 0, 0); // pixel color set to red
strip.setBrightness(255); // pixel set to full brightness
strip.setBrightness(random(150,255)); // random brightness adjust for flicker effect
strip.show();
delay(random(0,200)); // random delay for flicker effect
OK. Thanks for the input Delta_G. Figured it out. And yes, I guess I could draw a couple boxes and lines. I was thinking more like an actual circuit drawing with the correct symbols and all. Anyway, I reworked my sketches slightly and ran the first 2 within setup and the 3rd in the loop. It works like a charm now. Here's what I did. Don't know if this is the best sketching, but it works just fine for my needs.
#define PIN 1
strip.begin();
strip.show();
void engineBrighten();
// begin brightening 0 to 255
int i = 0;
do {
i = i+1;
strip.show();
} while (i < 255);
void engineColorFade();
// begin color fade yellow to red
int c = 255;
do {
c = c-1;
strip.setPixelColor(0, 255, c, 0); // set pixel color
strip.show();
} while (c >0);
// begin engine flicker
strip.show();
Delta_G:
While that stuff is nice, and you certainly could use the internet and find all the symbols I'm sure, sometimes we just need to know how you wired the thing up.
Got it. Thanks. If I need help again on something (which I probably will), I'll be sure to do that up front.
