I have two codes. They work fine independently. I want to combine the two codes. As I have combined them, only code 1 responds, not the code 2. Im a newbie and could not figure it out. Would appreciate any help!
#define pin1 2 // motor #1 +
#define pin2 3 // motor #1 –
#define pw1 7 // motor #1 pwm
#define pin3 4 // motor #2 +
#define pin4 5 // motor #2 –
#define pw2 6 // motor #2 pwm
#include <Servo.h>
#include <SoftwareSerial.h>
Servo myservo;
int bluetoothTx = 10; // bluetooth tx to 10 pin
int bluetoothRx = 11; // bluetooth rx to 11 pin
SoftwareSerial bluetooth(bluetoothTx, bluetoothRx);
Servo ser; // create servo object to control a servo
int poser = 90; // initial position of servo
int value; // initial value of input
pinMode(pin1, OUTPUT);
pinMode(pin2, OUTPUT);
pinMode(pin3, OUTPUT);
pinMode(pin4, OUTPUT);
pinMode(pw1, OUTPUT);
pinMode(pw2, OUTPUT);
digitalWrite(pin1, LOW);
digitalWrite(pin2, LOW);
digitalWrite(pin3, LOW);
digitalWrite(pin4, LOW);
analogWrite(pw1, 50);
analogWrite(pw2, 50);
myservo.attach(9);
bluetooth.begin(9600);
//CODE 1
if (bluetooth.available() >= 2 )
unsigned int a = bluetooth.read();
unsigned int b = bluetooth.read();
unsigned int val = (b * 256) + a;
if (val == 200) // motor #1 stop
else if (val == 300) // motor #1 forward
digitalWrite(pin1, HIGH);
else if (val == 500) // motor #2 stop
else if (val == 600) // motor #2 forward
digitalWrite(pin3, HIGH);
else if (val >= 1000 && val <= 1255)
analogWrite (pw1, val - 1000);
else if (val >= 2000 && val <= 2255)
analogWrite (pw2, val - 2000);
//CODE 2
if(bluetooth.available()> 0 ) // receive number from bluetooth
int servopos = bluetooth.read(); // save the received number to servopos
Serial.println(servopos); // serial print servopos current number received from bluetooth
myservo.write(servopos); // roate the servo the angle received from the android app
#define pin2 3 // motor #1 ΓÇô
#define pin4 5 // motor #2 ΓÇô
#include <Servo.h>
Servo myservo;
myservo.attach(9);
//CODE 1
//CODE 2
The way that you read from the software serial port is not very robust. There is no way for it to tell if the data is valid or not. I would suggest that you have a look at Robin2's serial input basics tutorial.
#include <SoftwareSerial.h> // TX RX software library for bluetooth
#include <Servo.h> // servo library
Servo myservo; // servo name
myservo.attach(9); // attach servo signal wire to pin 9
//Setup usb serial connection to computer
//Setup Bluetooth serial connection to android
//Read from bluetooth and write to usb serial
L298N DRIVER
if (Serial.available() >= 2 )
unsigned int a = Serial.read();
unsigned int b = Serial.read();
if (val == 100) // motor 1 reverse
digitalWrite(pin2, HIGH);
else if (val == 200) // motor #1 stop
else if (val == 400) // motor #2 reverse
digitalWrite(pin4, HIGH);
#include <Servo.h>
Servo myservo;
myservo.attach(9);
//CODE 1
