Combining two codes (IR LED speed gate + LCD display)
Hello, I have a code (speed gate) that someone from this forum made for me for my project. It works perfect. Now instead of having it display on the serial monitor, I am hoping to have it display on a 16,2 LCD.
I cant even get a LCD tutorial code to work at the same time as the Speed gate code.
Below is the code for my speed gate. Can anyone help me?
#define LEDon            LOW
#define LEDoff           HIGH
#define noSIGNAL         HIGH
#define SIGNAL           LOW
const byte TX          = 3;
const byte statusLED   = 13;
const byte RX          = 2;
byte lastSensorStatus;
float Cardlength=42.6;
//timing stuff
unsigned long checkInputsMillis;
unsigned long detectedMillis;
  pinMode(statusLED, OUTPUT);
  digitalWrite(statusLED, LEDoff);
  pinMode(TX, OUTPUT);
  pinMode(RX, INPUT);
  tone(TX, 38000);
} //END of setup()
  //time to check the inputs (every 1ms) ?
  if (millis() - checkInputsMillis >= 1)
    //restart this TIMER
    checkInputsMillis = millis();
    checkInputs();
  //other non-blocking code goes here
} //END of loop
void checkInputs()
  byte inputStatus;
  inputStatus = digitalRead(RX);
  //was there a change in sensor status ?
  if (lastSensorStatus != inputStatus)
    //update to the new state
    lastSensorStatus = inputStatus;
    //has the signal disappeared ?
    if (inputStatus == noSIGNAL)
      digitalWrite(statusLED, LEDon);
      //the time the object went into the IR beam
      detectedMillis = millis();
    //the signal has returned
      Serial.print("Object was in beam for ");
      Serial.print(millis() - detectedMillis);
      Serial.println(" milliseconds.");
  float elapsedTime = (millis() - detectedMillis);
  float Speed = (Cardlength/1000)/(elapsedTime/1000);
  Serial.print(Speed);
  Serial.println("m/s");
} //END of   checkInputs()
Please clean up the code mess by putting all the code inside code tags.
Read the forum guidelines to see how to properly post code and some good information on making a good post.
Use the IDE autoformat tool (ctrl-t or Tools, Auto format) before posting code in code tags.
You can go back and fix your original post by highlighting the code and clicking the </> in the menu bar.
code tags new
What, exact, LCD do you have? Is it I2C or parallel? 4 bit or 8 bit?
Have you tried to write the code? What happened? If you post the code (formatted properly and in code tags) we can help. We probably won't write it for you though.
Thanks for response.
its LCD1602. Parallel and 4 bit I believe.
I can post the code Im trying to splice together for now (before I get the LCD to actually display the speed gate values). Its not pretty lol
We seldom see pretty code here. Just make sure to remove excess white space and use the IDE auto-format tool. That helps a lot.
Along with the code, please include a detailed description of what the code actually does and a description of what you expect the code to do. "My code doesn't work" conveys no useful information.
If there are compile errors, please include the entire error message. It is easy to do. There is a button (lower right of the IDE window) called "copy error message". Copy the error and paste into a post in code tags. Paraphrasing the error message leaves out important information.
So I am trying to just combine 2 codes to have both working at the same time (separately from each other). They both work when they're on their own but when I combine them, my LCD becomes a mess with random characters and the speed gate stops detecting signals.
#include <LiquidCrystal.h>
LiquidCrystal lcd (1, 8, 4, 5, 6, 7);
#define LEDon            LOW
#define LEDoff           HIGH
#define SIGNAL           LOW
const byte TX          = 3;
const byte RX          = 2;
float Cardlength = 42.6;
//timing stuff
  pinMode(RX, INPUT);
  tone(TX, 38000);
  lcd.begin(16, 2);
void loop
    checkInputs();
    lcd.print ("Arduino");
    delay (3000);
    lcd.setCursor(2, 1);
    lcd.print ("lcd tutorial");
    delay (3000);
    lcd.clear();
    lcd.blink();
    delay (4000);
    lcd.setCursor(7, 1);
    delay (3000);
    lcd.noBlink();
    lcd.cursor();
    delay (4000);
    lcd.noCursor();
    lcd.clear();
} //END of loop
void checkInputs()
  byte inputStatus;
      float Speed = (Cardlength / 1000) / (elapsedTime / 1000);
Small wonder, when you write to it 1000 times a second. EDIT - oh, wait, you have 17 seconds of delay() competing with millis() operation in loop(). That will never fly.
Small wonder, when you are spending 99% of your time twiddling your thumbs in delay() statements.
Pin 1 is the hardware serial (Serial) TX pin. Use a different pin for the RS. What happens once you make the pin change.
Please post the code in a new post if you change the code so that we can keep up.
Please post a schematic of your wiring (after fixing the LCD/Serial pin conflict). Written descriptions are always more ambiguous than a drawing. Hand drawn, photographed and posted is fine. Include all pin names/numbers, components, their part numbers and/or values and power supplies.
Changed RS to pin 9 and now the LCD portion works!
Still some weird readings/no readings from the speed gate timer portion. I will work on a schematic now. Thanks a lot GF
WIN_20220809_13_40_08_Pro
LiquidCrystal lcd (9, 8, 4, 5, 6, 7);
#define LEDon            LOW
#define LEDoff           HIGH
#define SIGNAL           LOW
const byte TX          = 3;
const byte RX          = 2;
//timing stuff
  pinMode(RX, INPUT);
  tone(TX, 38000);
  lcd.begin(16, 2);
void loop
    checkInputs();
    delay (3000);
    delay (3000);
    lcd.clear();
    lcd.blink();
    delay (4000);
    delay (3000);
    lcd.noBlink();
    lcd.cursor();
    delay (4000);
    lcd.noCursor();
    lcd.clear();
} //END of loop
void checkInputs()
  byte inputStatus;
I got a bunch of it figured out, thanks for helping me to this point GF
