sorry I'm a young, novice girl with Arduino.
I would like to ask you a question,
I read two arduino pressure sensors through the analog pins.
I would like to be able to have an arduino
command a 220v inverter (which in turn will control a fan) via analogue or digital output (it accepts both)
These two values I would like to tell the arduino to read the difference between them and to control the inverter so that it keeps this value constant.
example: difference between the two values is = a 1v, controls the inverter to keep this value constant.
is it impossible to do it?
[code]
int MassaAria = analogRead(A1);
float voltage1= (float)MassaAria *(5.0/1023);
int Cil=analogRead(A2);
float voltage= (float) Cil/10235.0;
float pCil=(float)((((voltage /(1023/5))/5)+0.04)/0.00410);
int Atm=analogRead(A3);
float voltage3= (float) Atm/1023.05.0;
float pAtm=(float)((((voltage /(1023/5))/5)+0.04)/0.00410);
It is not clear from the description what you want to do. Do you want to control the speed of a 220 VAC fan? This is not simple, and may not even be possible with most AC fans.
The Arduino can safely turn ON or OFF an inverter or other household appliance only with something like this power switch.
I want to control the speed of a 220v fan approx.
I will use a toshiba vf-s15 inverter.
I would like the Arduino to command it, and to manage it.
Arduino must take into account the two pressure sensors, calculate the difference and send a command to the inverter to keep the difference between the two sensors constant.
Is there a way?
I'm a beginner and I'm trying to learn.
But it will be very difficult ......
Play with the IDE examples to get some coding experience .
Get your pressure transducers working so you can read their values ... then calculate the difference. Then ..... In other words take small steps in the project.
brugola:
Is there a way?
Please provide links to details of all the hardware - don't make us all search the internet for stuff you already have!
