command lcd.clear() does not work
Hi
I recently purchased the Arduino Mega 2560 R3 and attached it to my HD44780A00 controlled lcd screen. For some reason the command[ lcd.clear() ]is not working. I do not want to post all my code so here is just a sample;
#include <LiquidCrystal.h>
LiquidCrystal lcd(0,1,2,3,4,5);
void setup(){
lcd.begin(40, 2);
lcd.clear();
lcd.println("hello my friend");
delay(2000);
lcd.clear(); // this command does not work
lcd.println("how are you");
Is this a software or hardware error? Does anyone know the cause of this?
Thank you
Probably.
What do you mean by that?
What did you see on the display during the first delay period?
What did you expect to see during that period?
What did you see on the display during the second delay period?
In general:
(1) You do not need an lcd.clear() statement immediately after lcd.begin() since the display is cleared as part of the initialization.
(2) You should not use the undocumented lcd.println() command. It is undocumented because it does not do what you expect it to do.
(3) If possible you should try to avoid using lcd.clear() in loop().
ALSO: You should put your code into a code block so that it is more legible. Highlight the part of your post that is code and use the 'code' button (it looks like a scroll with < > in front).
Don
As Don alluded to:
Neither the library nor the display handle end of line processing
so println() won't give you what you are probably expecting/wanting.
Also, depending on what else the sketch is doing, using digital pins 0 and
1 is not a good idea since those are used for the serial port interface.
Based on that code here is what I would expect:
setup:
  • lcd.begin() will initialize the display which clears it.
  • lcd.clear() clears the display again.
loop:
lcd.println(...) prints:
hello my friend**
on the top line of the display
(where the * characters are garbage/unpredictable characters)
then a 2 second time delay.
how are you**
on the top line, since the clear worked and positioned cursor back to 0,0
Then with no delay this starts over.
So when the loop starts over the display contains:
how are you**
on the top line and this will immediately be added to the top line:
hello my friend**
To make the to line look like this:
how are you**hello my friend**
all on the top line.
Then the 2 second delay,
and the loop continues repeating this.
I'm assuming that this is what you got and is not what you wanted.
--- bill
