So, IM trying to program a stepper motor to move XX CW, and then back to 0 - then i want to go YY steps CW and then back to 0, and THEN i want to go ZZ steps CW and then back to 0, and THEN i want to Delay for XXX seconds - and then start the loop over.
i have found some code that makes the motion i want - now im trying to string it together. the issue im having is that it runs... but its not going in order... its jumping all over the place.
// Include AccelStepper Library
#include <AccelStepper.h>
//Define motor pin connections
const int dirPin = 2;
const int stepPin = 4;
const long targetPos1 = 10000;
const long targetPos2 = 5000;
const long targetPos3 = 2500;
const long targetPos4 = 1;
const long targetPos5 = 2;
const long targetPos6 = 3;
#define motorInterfaceType 1
// Creates an instance
AccelStepper myStepper(motorInterfaceType, stepPin, dirPin);
// set the maximum speed, acceleration factor,
// initial speed and the target position
myStepper.setMaxSpeed(10000);
myStepper.setAcceleration(2000);
// myStepper.setSpeed(250); // This is useless, as .run() only follows maxSpeed!
myStepper.moveTo(5000);
// Change direction once the motor reaches target position
if (myStepper.distanceToGo() == 0) {
if (myStepper.currentPosition() == 0) {
myStepper.moveTo(targetPos1);
myStepper.moveTo(targetPos4);
myStepper.run();
if (myStepper.currentPosition() == targetPos4) {
myStepper.moveTo(targetPos2);
myStepper.moveTo(targetPos5);
myStepper.run();
if (myStepper.currentPosition() == targetPos5) {
myStepper.moveTo(targetPos3);
myStepper.moveTo(0);
myStepper.run();
// Move the motor one step
Here is a code-version that is well structured into functions and uses self-explaining names for variables and functions etc.
It uses a so called stateMachine.
stateMachines have the advantages of
minimizing the number of if-conditions
very easy to maintain and to expand
This is done through using a simplified version of "if-conditions"
The condition is simplified to if a variable has
value 1
value 2
value 3
and as for all conditions the samevariable is used
it is enough to say
if variable "myState"
has value 1
has value 2
has value 3
But you do not use the keyword "if"
you use the keyword "switch" in combination with "case" instead
You can imagine "switch" like a multi-position-switch with positions
1, 2, 3, 4, 5 .....
Where each switch-position make the "machine" run in a different mode of operation
if "switch" is in position 1 machine works in operation-mode 1
if "switch" is in position 2 machine works in operation-mode 2
if "switch" is in position 3 machine works in operation-mode 3
you don't use numbers like 1,2,3 ...
You use constants that represent the numbers.
This has the advantage that the constant-name already explains the mode of operation.
if "switch" is in position "StepToPosition" machine works in operation-mode 1 (which is mode StepToPosition
if "switch" is in position "returnToZero" machine works in operation-mode 2 (which is mode returnToZero
if "switch" is in position "wait" machine works in operation-mode 3 ( which is mode "waiting"
here is the code i started with. effectively it sets a accel speed, and a max speed, and then it moves the stepper motor so far in the setup loop
then it starts oscilating the motor back and forth by the targetpseed - which is GREAT - this is exactly what i need for my project... but then i also want to change the target speed a couple times - and then i want to delay for an hour.
im new to this coding stuff, and i have watched my fair share of tutorials - and i can understand most of the basics when your trying to do simple things.... but when i want to string concepts together i get lost.
const int stepPin = 3;
const long targetPos = 5000;
// Define motor interface type
myStepper.setMaxSpeed(350);
myStepper.setAcceleration(50);
myStepper.moveTo(targetPos);
myStepper.run();
that's kind of what i was thinking - it doesn't know "which distance to go" to go to next.
i have not watched videos on arrays yet. thank you for the advice, ill take a look!
i also was thinking some sort of homing technique would be useful - so i tried to use so/while loops an increment an integer to trigger the code to move on... and that didn't work... but it was probably still an issue with the "0" terms.
yeah i was looking into this last night aafter i posted my question and was going to investigate it more..... sounds like i have two homework actions today.
look at arrays
2 look at the example you posted for switch case.
