Commands from the documentation do not work.BT_201
I'm trying to call the command described in the documentation for the module.
On the SD card there is a folder "02test" in the root. This folder contains sound files
01 test.mp3
02 test.mp3
and so on.
When I enter the command AT+AJ/02*/01*.?? I get ER+6. What am I doing wrong, please tell me those who know.
That's the name of your folder?
Maybe try:
01testintheroot
You flagged this topic to say that you had fixed the problem
Please explain what the problem was and how you fixed it so that others can benefit
This information will probably not be useful to others. But the decision was that I myself was mistaken.
AT+AJ/02*/01*.???
the command will work if sent via Serial.println(AT+AJ/02*/01*.???);
If directly to the port, then you need to select NL&CR in the menu next to the baud rate selection. In general, both line transition and carriage return need to work.
