Common code problems
We are trying to upload code in esp32 dev module in arduino ide software and we wre geting this type of error .
and here the code:-
#include <Wire.h>;
#include <ESP8266WiFi>;
#include <WiFiUdp.h&gt>;
WiFiUDP UDP;
char packet[4];
//IPAddress local_IP(192, 168, 203, 158);
//IPAddress gateway(192, 168, 1, 158);
//IPAddress subnet(255, 255, 0, 0);
//_________________________________________//
int ESCout_1 ,ESCout_2 ,ESCout_3 ,ESCout_4;
int input_PITCH = 50;
int input_ROLL = 50;
int input_YAW = 50;
volatile int input_THROTTLE = 0;
int Mode = 0;
boolean wall_car_init = false;
boolean set_motor_const_speed = false;
int8_t target_axis=0;
int8_t target_dirr=0;
boolean wheal_state = false;
uint8_t pwm_stops;
int arr[] = {20,10,20,10};
volatile int order[] = {0,0,0,0}; //volatile key
int temp_arr[] = {0,0,0,0};
int pulldown_time_temp[] = {0,0,0,0,0};
int pulldown_time[] = {0,0,0,0,0};
volatile int pulldown_time_temp_loop[] = {0,0,0,0,0}; //volatile key
uint8_t pin[] = {14,12,13,15};
int i,j,temp_i,temp;
boolean orderState1,orderState2,orderState3,orderState4,Timer_Init;
int16_t gyro_x, gyro_y, gyro_z, acc_x, acc_y, acc_z, temperature, acc_total_vector;
float angle_pitch, angle_roll,angle_yaw,prev_roll,prev_pitch,prev_yaw;
boolean set_gyro_angles;
float angle_roll_acc, angle_pitch_acc;
float angle_pitch_output, angle_roll_output, angle_yaw_output;
long Time, timePrev;
float elapsedTime,P_factor;
float acceleration_x,acceleration_y,acceleration_z;
long gyro_x_cal, gyro_y_cal, gyro_z_cal;
float pitch_PID,roll_PID,yaw_PID;
float roll_error, roll_previous_error, pitch_error, pitch_previous_error, yaw_error, yaw_previous_error;
float roll_pid_p, roll_pid_d, roll_pid_i, pitch_pid_p, pitch_pid_i, pitch_pid_d, yaw_pid_p, yaw_pid_i, yaw_pid_d;
float roll_desired_angle, pitch_desired_angle, yaw_desired_angle;
double twoX_kp=5; //5
double twoX_ki=0.003; //0.003
double twoX_kd=1.4; //1.4
double yaw_kp=8; //5
double yaw_ki=0; //0.005
double yaw_kd=4; //2.8
void ICACHE_RAM_ATTR PWM_callback() {
switch (pwm_stops){
case 0:
pulldown_time_temp[0] = pulldown_time_temp_loop[0];
pulldown_time_temp[1] = pulldown_time_temp_loop[1];
pulldown_time_temp[2] = pulldown_time_temp_loop[2];
pulldown_time_temp[3] = pulldown_time_temp_loop[3];
pulldown_time_temp[4] = pulldown_time_temp_loop[4];
pwm_stops = 1;
if(input_THROTTLE!=0){GPOS = (1 &lt;&lt; 14);GPOS = (1 &lt;&lt; 12);GPOS = (1 &lt;&lt; 15);GPOS = (1 &lt;&lt; 13);}
timer1_write(80*pulldown_time_temp[0]);
case 1:
pwm_stops = 2;
GPOC = (1 &lt;&lt; pin[order[0]]);
timer1_write(80*pulldown_time_temp[1]);
case 2:
pwm_stops = 3;
GPOC = (1 &lt;&lt; pin[order[1]]);
timer1_write(80*pulldown_time_temp[2]);
case 3:
pwm_stops = 4;
GPOC = (1 &lt;&lt; pin[order[2]]);
timer1_write(80*pulldown_time_temp[3]);
case 4:
pwm_stops = 0;
GPOC = (1 &lt;&lt; pin[order[3]]);
timer1_write(80*pulldown_time_temp[4]);
pinMode(D5,OUTPUT);pinMode(D6,OUTPUT);pinMode(D7,OUTPUT);pinMode(D8,OUTPUT);pinMode(D0,OUTPUT);
GPOC = (1 &lt;&lt; 14);GPOC = (1 &lt;&lt; 12);GPOC = (1 &lt;&lt; 13);GPOC = (1 &lt;&lt; 15);
digitalWrite(D0,LOW);
WiFi.mode(WIFI_STA);
WiFi.begin("Redmi_R", "deywifi3210");
while (WiFi.status() != WL_CONNECTED){ delay(500);}
UDP.begin(9999);
delay(6000);
//____________________________________________________________________//
Wire.begin();
Wire.setClock(400000);
Wire.beginTransmission(0x68);
Wire.write(0x6B);
Wire.write(0x00);
Wire.endTransmission();
Wire.write(0x1C); //accel
Wire.write(0x08); //+-4g
Wire.write(0x1B); //gyro
Wire.write(0x18); //2000dps
Wire.write(0x1A);
Wire.write(0x03);
for (int cal_int = 0; cal_int &lt; 4000 ; cal_int ++){
if(cal_int % 125 == 0)Serial.print(".");
Wire.write(0x3B);
Wire.requestFrom(0x68,14);
while(Wire.available() &lt; 14);
acc_y = Wire.read()&lt;&lt;8|Wire.read();
acc_x = Wire.read()&lt;&lt;8|Wire.read();
acc_z = Wire.read()&lt;&lt;8|Wire.read();
temperature = Wire.read()&lt;&lt;8|Wire.read();
gyro_y = Wire.read()&lt;&lt;8|Wire.read();
gyro_x = Wire.read()&lt;&lt;8|Wire.read();
gyro_z = Wire.read()&lt;&lt;8|Wire.read();
gyro_x_cal += gyro_x;
gyro_y_cal += gyro_y;
gyro_z_cal += gyro_z;
delayMicroseconds(100);
gyro_x_cal /= 4000;
gyro_y_cal /= 4000;
gyro_z_cal /= 4000;
timer1_attachInterrupt(PWM_callback);
timer1_enable(TIM_DIV1, TIM_EDGE, TIM_SINGLE);
//--------------------------------MPU6050----------------------------//
timePrev = Time;
Time = micros();
elapsedTime = (float)(Time - timePrev) / (float)1000000;
Wire.write(0x3B);
gyro_x -= gyro_x_cal;
gyro_y -= gyro_y_cal;
gyro_z -= gyro_z_cal;
acceleration_x = gyro_x * (-0.0610687023);
acceleration_y = gyro_y * (-0.0610687023);
acceleration_z = gyro_z * (-0.0610687023);
angle_pitch += acceleration_x * elapsedTime;
angle_roll += acceleration_y * elapsedTime;
angle_yaw += acceleration_z * elapsedTime;
if(angle_yaw &gt;= 180.00){angle_yaw-=360;}
else if(angle_yaw &lt; -180.00){angle_yaw+=360;}
angle_roll_acc = atan(acc_x/sqrt(acc_y *acc_y + acc_z*acc_z))*(-57.296);
angle_pitch_acc = atan(acc_y/sqrt(acc_x*acc_x + acc_z*acc_z))*57.296;
angle_pitch_acc -= 4;
angle_roll_acc += 9;
if(set_gyro_angles){
angle_pitch = angle_pitch * 0.9996 + angle_pitch_acc * 0.0004;
angle_roll = angle_roll * 0.9996 + angle_roll_acc * 0.0004;
else{
angle_pitch = angle_pitch_acc;
angle_roll = angle_roll_acc;
set_gyro_angles = true;
angle_pitch_output = angle_pitch_output * 0.9 + angle_pitch * 0.1;
angle_roll_output = angle_roll_output * 0.9 + angle_roll * 0.1;
angle_yaw_output = angle_yaw_output * 0.9 + angle_yaw * 0.1;
//--------------------------PID_Calculation--------------------------//
if(wall_car_init==false){
roll_desired_angle = 3*(input_ROLL - 50)/10.0;
pitch_desired_angle = 3*(input_PITCH - 50)/10.0;
P_factor = 0.001286376*input_THROTTLE + 0.616932;
roll_error = angle_roll_output - roll_desired_angle;
pitch_error = angle_pitch_output - pitch_desired_angle;
yaw_error = angle_yaw_output;
roll_pid_p = P_factor*twoX_kp*roll_error;
pitch_pid_p = P_factor*twoX_kp*pitch_error;
yaw_pid_p = yaw_kp*yaw_error;
roll_pid_i += twoX_ki*roll_error;
pitch_pid_i += twoX_ki*pitch_error;
yaw_pid_i += yaw_ki*yaw_error;
roll_pid_d = twoX_kd*acceleration_y;
pitch_pid_d = twoX_kd*acceleration_x;
yaw_pid_d = yaw_kd*acceleration_z;
if(roll_pid_i &gt; 0 &amp;&amp; roll_error &lt; 0){roll_pid_i=0;}
else if(roll_pid_i &lt; 0 &amp;&amp; roll_error &gt; 0){roll_pid_i=0;}
if(pitch_pid_i &gt; 0 &amp;&amp; pitch_error &lt; 0){pitch_pid_i=0;}
else if(pitch_pid_i &lt; 0 &amp;&amp; pitch_error &gt; 0){pitch_pid_i=0;}
if(yaw_pid_i &gt; 0 &amp;&amp; yaw_error &lt; 0){yaw_pid_i=0;}
else if(yaw_pid_i &lt; 0 &amp;&amp; yaw_error &gt; 0){yaw_pid_i=0;}
roll_PID = roll_pid_p + roll_pid_i + roll_pid_d;
pitch_PID = pitch_pid_p + pitch_pid_i + pitch_pid_d;
yaw_PID = yaw_pid_p + yaw_pid_i + yaw_pid_d;
ESCout_1 = input_THROTTLE + pitch_PID - roll_PID + yaw_PID;
ESCout_2 = input_THROTTLE + pitch_PID + roll_PID - yaw_PID;
ESCout_3 = input_THROTTLE - pitch_PID + roll_PID + yaw_PID;
ESCout_4 = input_THROTTLE - pitch_PID - roll_PID - yaw_PID;
//------------------------- CarMode -----------------------------//
if(Mode==1 &amp;&amp; (abs(input_ROLL-50)&gt;30 || abs(input_PITCH-50)&gt;30)){
wall_car_init = true;
if(input_ROLL &gt; 30){target_axis = 1; target_dirr = 1;}
else if(input_ROLL &lt; -30){target_axis = 1; target_dirr = -1;}
else if(input_PITCH &gt; 30){target_axis = 2; target_dirr = 1;}
else if(input_PITCH &lt; -30){target_axis = 2; target_dirr = -1;}
else if(Mode==0){wall_car_init=false;set_motor_const_speed=false;}
if(wall_car_init==true){
if(target_axis=1){roll_desired_angle = 90*target_dirr;}
else if(target_axis=2){pitch_desired_angle = 90*target_dirr;}
if((abs(acceleration_x)&lt;15 &amp;&amp; abs(acceleration_y)&lt;15) &amp;&amp; (abs(angle_roll_output)&gt;45 || abs(angle_pitch_output)&gt;45)){set_motor_const_speed = true;}
if(set_motor_const_speed==true){
ESCout_1 = 1100; ESCout_2 = 1103; ESCout_3 = 1106; ESCout_4 = 1109;
if(input_ROLL&gt;50 &amp;&amp; wheal_state == true){digitalWrite(D0,HIGH);}
if(ESCout_1&gt;1199) ESCout_1=1199;
else if(ESCout_1&lt;1) ESCout_1=1;
if(ESCout_2&gt;1199) ESCout_2=1199;
else if(ESCout_2&lt;1) ESCout_2=1;
if(ESCout_3&gt;1199) ESCout_3=1199;
else if(ESCout_3&lt;1) ESCout_3=1;
if(ESCout_4&gt;1199) ESCout_4=1199;
else if(ESCout_4&lt;1) ESCout_4=1;
//----------------------------- Sorting -------------------------------//
arr[0]=ESCout_1;arr[1]=ESCout_2;arr[2]=ESCout_3;arr[3]=ESCout_4;
temp_arr[0] = arr[0];temp_arr[1] = arr[1];temp_arr[2] = arr[2];temp_arr[3] = arr[3];
for (i = 0; i &lt; 3; i++){
temp_i = i;
for (j = i+1; j &lt; 4; j++)
if (temp_arr[j] &lt; temp_arr[temp_i])
temp_i = j;
temp = temp_arr[temp_i];
temp_arr[temp_i] = temp_arr[i];
temp_arr[i] = temp;
pulldown_time[0]=temp_arr[0];
pulldown_time[1]=temp_arr[1]-temp_arr[0];
pulldown_time[2]=temp_arr[2]-temp_arr[1];
pulldown_time[3]=temp_arr[3]-temp_arr[2];
pulldown_time[4]=1200-temp_arr[3];
if(pulldown_time[1]==0){pulldown_time[1]=1;}
if(pulldown_time[2]==0){pulldown_time[2]=1;}
if(pulldown_time[3]==0){pulldown_time[3]=1;}
if(pulldown_time[4]==0){pulldown_time[4]=1;}
pulldown_time_temp_loop[0] = pulldown_time[0];
pulldown_time_temp_loop[1] = pulldown_time[1];
pulldown_time_temp_loop[2] = pulldown_time[2];
pulldown_time_temp_loop[3] = pulldown_time[3];
pulldown_time_temp_loop[4] = pulldown_time[4];
orderState1=false;orderState2=false;orderState3=false;orderState4=false;
for(int k=0; k &lt;4; k++){
if(temp_arr[0] == arr[k] &amp;&amp; orderState1 == false){ order[0] = k; orderState1=true;}
else if(temp_arr[1] == arr[k] &amp;&amp; orderState2 == false){ order[1] = k; orderState2=true;}
else if(temp_arr[2] == arr[k] &amp;&amp; orderState3 == false){ order[2] = k; orderState3=true;}
else if(temp_arr[3] == arr[k] &amp;&amp; orderState4 == false){ order[3] = k; orderState4=true;}
//----------------------------- WiFi ----------------------------------//
int packetSize = UDP.parsePacket();
if (packetSize) {
int len = UDP.read(packet, 4);
if(len&gt;0){packet[len] = '\0';}
input_ROLL = int(packet[0]);
input_PITCH = int(packet[1]);
input_THROTTLE = int(packet[2])*24;
Mode = int(packet[3]);
if(input_THROTTLE == 0){
angle_yaw_output=0;angle_yaw=0;yaw_PID=0;
yaw_pid_p=0;yaw_pid_i=0;yaw_pid_d=0;twoX_ki=0;
//Serial.print(input_ROLL);Serial.print(" ");
//Serial.print(input_PITCH);Serial.print(" ");
//Serial.print(input_THROTTLE);Serial.print(" ");
//Serial.print(angle_roll_output,0);Serial.print(" ");
//Serial.print(angle_pitch_output,0);//Serial.print(" ");
//Serial.println(input_THROTTLE);
if(wheal_state == false){digitalWrite(D0,LOW);}
if(Timer_Init == false){
timer1_write(80);
Timer_Init = true;
wheal_state = !wheal_state;
while(Time - timePrev &lt;1200);
how to resolved this error ?
thank you
#include &lt;ESP8266WiFi.h&gt;
#include &lt;WiFiUdp.h&gt;
At a guess you copied the code from a Web site
The &Lt; should presumably be < and the &gt; should be >
That would make those lines of code
#include <ESP8266WiFi.h>
#include <WiFiUdp.h>
There may be other errors but I did not look any further because of the inconvenient way in which the code and error messages were posted
Use code tags (the < CODE/ > icon above the compose window) to make it easier to read and copy for examination
Do the same when posting error messages
there are several other problems
  • besides < and >, there's also &
  • semicolons after #includes
  • didn't see where GPOS & GPOC are defined
  • time1_write(), timer1_enable() and timer1_interrupt() weren't defined
  • places where '<' and '<' were on separate lines
  • extra chars preceeding a yaw_pid_d =
  • couples places where target_axis=1 should probably be target_axis == 1
  • at the end of the file, while (Time - timePrev < 1200) won't terminate without either Time or timePrev being updated
considering these probelms, assume there are many others
Interesting. The &lt occurs throughout the sketch, looks like every time the < symbol for I suppose some bit shifting later, too.
I used a little Google Fu and found
Bug: When pasting from Excel, < turns into "<"If you copy text from Excel and paste into column or row titles in Prism, the less than symbol < gets converted to "<" , which is the is the HTML entity for 'less than' character. Similarly, the greater than symbol > gets converted to ">"
yes, those are HTML symbol escape sequences. You must have copied the code off a web page instead of getting the .txt version
as you have said earlier we tried that but we didnt get the results but we get this .
we include this library :
1 esp32wifi.h
2 esp8266wifi.h
3 wire.h
how to resolve this ?
we copied this code from a website .
You have the board set to ESP32 but the code is for an ESP8266
In my experience the easiest way to tidy up the code and add the code tags is as follows
Start by tidying up your code by using Tools/Auto Format in the IDE to make it easier to read. Then use Edit/Copy for Forum and paste what was copied in a new reply. Code tags will have been added to the code to make it easy to read in the forum thus making it easier to provide help.
Where did you get the code? I'm not going through this and hand fixing every copy-paste error.
It is a bad idea just a copy a code somewhere if you don't understand it.
I did a search and replace for &amp;, &gt;, &lt;, and removed ";" from the #include<>s... see if this crashes...
#include <Wire.h>
WiFiUDP UDP;
char packet[4];
int ESCout_1, ESCout_2, ESCout_3, ESCout_4;
int input_YAW = 50;
int Mode = 0;
int8_t target_axis = 0;
int8_t target_dirr = 0;
uint8_t pwm_stops;
int arr[] = {20, 10, 20, 10};
volatile int order[] = {0, 0, 0, 0}; //volatile key
int temp_arr[] = {0, 0, 0, 0};
int pulldown_time_temp[] = {0, 0, 0, 0, 0};
int pulldown_time[] = {0, 0, 0, 0, 0};
volatile int pulldown_time_temp_loop[] = {0, 0, 0, 0, 0}; //volatile key
uint8_t pin[] = {14, 12, 13, 15};
int i, j, temp_i, temp;
boolean orderState1, orderState2, orderState3, orderState4, Timer_Init;
float angle_pitch, angle_roll, angle_yaw, prev_roll, prev_pitch, prev_yaw;
float elapsedTime, P_factor;
float acceleration_x, acceleration_y, acceleration_z;
float pitch_PID, roll_PID, yaw_PID;
double twoX_kp = 5; //5
double twoX_ki = 0.003; //0.003
double twoX_kd = 1.4; //1.4
double yaw_kp = 8; //5
double yaw_ki = 0; //0.005
double yaw_kd = 4; //2.8
  switch (pwm_stops) {
    case 0:
      pwm_stops = 1;
      if (input_THROTTLE != 0) {
        GPOS = (1  <<  14);
        GPOS = (1  <<  12);
        GPOS = (1  <<  15);
        GPOS = (1  <<  13);
      timer1_write(80 * pulldown_time_temp[0]);
    case 1:
      pwm_stops = 2;
      GPOC = (1  <<  pin[order[0]]);
      timer1_write(80 * pulldown_time_temp[1]);
    case 2:
      pwm_stops = 3;
      GPOC = (1  <<  pin[order[1]]);
      timer1_write(80 * pulldown_time_temp[2]);
    case 3:
      pwm_stops = 4;
      GPOC = (1  <<  pin[order[2]]);
      timer1_write(80 * pulldown_time_temp[3]);
    case 4:
      pwm_stops = 0;
      GPOC = (1  <<  pin[order[3]]);
      timer1_write(80 * pulldown_time_temp[4]);
  pinMode(D5, OUTPUT); pinMode(D6, OUTPUT); pinMode(D7, OUTPUT); pinMode(D8, OUTPUT); pinMode(D0, OUTPUT);
  GPOC = (1  <<  14); GPOC = (1  <<  12); GPOC = (1  <<  13); GPOC = (1  <<  15);
  digitalWrite(D0, LOW);
  UDP.begin(9999);
  delay(6000);
  Wire.begin();
  Wire.write(0x6B);
  Wire.write(0x00);
  Wire.write(0x1A);
  Wire.write(0x03);
  for (int cal_int = 0; cal_int < 4000 ; cal_int ++) {
    if (cal_int % 125 == 0)Serial.print(".");
    Wire.write(0x3B);
    Wire.requestFrom(0x68, 14);
    while (Wire.available() < 14);
    acc_y = Wire.read() << 8 | Wire.read();
    acc_x = Wire.read() << 8 | Wire.read();
    acc_z = Wire.read() << 8 | Wire.read();
    temperature = Wire.read() << 8 | Wire.read();
    gyro_y = Wire.read() << 8 | Wire.read();
    gyro_x = Wire.read() << 8 | Wire.read();
    gyro_z = Wire.read() << 8 | Wire.read();
  gyro_x_cal /= 4000;
  gyro_y_cal /= 4000;
  gyro_z_cal /= 4000;
  timePrev = Time;
  Time = micros();
  Wire.write(0x3B);
  if (angle_yaw  > = 180.00) {
    angle_yaw -= 360;
  else if (angle_yaw < -180.00) {
    angle_yaw += 360;
  angle_roll_acc = atan(acc_x / sqrt(acc_y * acc_y + acc_z * acc_z)) * (-57.296);
  angle_pitch_acc = atan(acc_y / sqrt(acc_x * acc_x + acc_z * acc_z)) * 57.296;
  if (set_gyro_angles) {
  else {
  if (wall_car_init == false) {
    roll_desired_angle = 3 * (input_ROLL - 50) / 10.0;
    pitch_desired_angle = 3 * (input_PITCH - 50) / 10.0;
  P_factor = 0.001286376 * input_THROTTLE + 0.616932;
  roll_pid_p = P_factor * twoX_kp * roll_error;
  pitch_pid_p = P_factor * twoX_kp * pitch_error;
  yaw_pid_p = yaw_kp * yaw_error;
  roll_pid_i += twoX_ki * roll_error;
  pitch_pid_i += twoX_ki * pitch_error;
  yaw_pid_i += yaw_ki * yaw_error;
  roll_pid_d = twoX_kd * acceleration_y;
  pitch_pid_d = twoX_kd * acceleration_x;
  yaw_pid_d = yaw_kd * acceleration_z;
  if (roll_pid_i > 0 && roll_error < 0) {
    roll_pid_i = 0;
  else if (roll_pid_i < 0 && roll_error > 0) {
    roll_pid_i = 0;
  if (pitch_pid_i > 0 && pitch_error < 0) {
    pitch_pid_i = 0;
  else if (pitch_pid_i < 0 && pitch_error > 0) {
    pitch_pid_i = 0;
  if (yaw_pid_i > 0 && yaw_error < 0) {
    yaw_pid_i = 0;
  else if (yaw_pid_i < 0 && yaw_error > 0) {
    yaw_pid_i = 0;
  if (Mode == 1 && (abs(input_ROLL - 50) > 30 || abs(input_PITCH - 50) > 30)) {
    if (input_ROLL > 30) {
      target_axis = 1;
      target_dirr = 1;
    else if (input_ROLL < -30) {
      target_axis = 1;
      target_dirr = -1;
    else if (input_PITCH > 30) {
      target_axis = 2;
      target_dirr = 1;
    else if (input_PITCH < -30) {
      target_axis = 2;
      target_dirr = -1;
  else if (Mode == 0) {
  if (wall_car_init == true) {
    if (target_axis = 1) {
      roll_desired_angle = 90 * target_dirr;
    else if (target_axis = 2) {
      pitch_desired_angle = 90 * target_dirr;
    if ((abs(acceleration_x) < 15 && abs(acceleration_y) < 15) && (abs(angle_roll_output) > 45 || abs(angle_pitch_output) > 45)) {
    if (set_motor_const_speed == true) {
      if (input_ROLL > 50 && wheal_state == true) {
        digitalWrite(D0, HIGH);
  if (ESCout_1 > 1199) ESCout_1 = 1199;
  else if (ESCout_1 < 1) ESCout_1 = 1;
  if (ESCout_2 > 1199) ESCout_2 = 1199;
  else if (ESCout_2 < 1) ESCout_2 = 1;
  if (ESCout_3 > 1199) ESCout_3 = 1199;
  else if (ESCout_3 < 1) ESCout_3 = 1;
  if (ESCout_4 > 1199) ESCout_4 = 1199;
  else if (ESCout_4 < 1) ESCout_4 = 1;
  arr[0] = ESCout_1; arr[1] = ESCout_2; arr[2] = ESCout_3; arr[3] = ESCout_4;
  temp_arr[0] = arr[0]; temp_arr[1] = arr[1]; temp_arr[2] = arr[2]; temp_arr[3] = arr[3];
  for (i = 0; i < 3; i++) {
    temp_i = i;
    for (j = i + 1; j < 4; j++)
      if (temp_arr[j] < temp_arr[temp_i])
        temp_i = j;
    temp_arr[i] = temp;
  pulldown_time[0] = temp_arr[0];
  pulldown_time[1] = temp_arr[1] - temp_arr[0];
  pulldown_time[2] = temp_arr[2] - temp_arr[1];
  pulldown_time[3] = temp_arr[3] - temp_arr[2];
  pulldown_time[4] = 1200 - temp_arr[3];
  if (pulldown_time[1] == 0) {
    pulldown_time[1] = 1;
  if (pulldown_time[2] == 0) {
    pulldown_time[2] = 1;
  if (pulldown_time[3] == 0) {
    pulldown_time[3] = 1;
  if (pulldown_time[4] == 0) {
    pulldown_time[4] = 1;
  orderState1 = false; orderState2 = false; orderState3 = false; orderState4 = false;
  for (int k = 0; k  < 4; k++) {
    if (temp_arr[0] == arr[k] && orderState1 == false) {
      order[0] = k;
      orderState1 = true;
    else if (temp_arr[1] == arr[k] && orderState2 == false) {
      order[1] = k;
      orderState2 = true;
    else if (temp_arr[2] == arr[k] && orderState3 == false) {
      order[2] = k;
      orderState3 = true;
    else if (temp_arr[3] == arr[k] && orderState4 == false) {
      order[3] = k;
      orderState4 = true;
  if (packetSize) {
    if (len > 0) {
      packet[len] = '\0';
    input_THROTTLE = int(packet[2]) * 24;
  if (input_THROTTLE == 0) {
    angle_yaw_output = 0; angle_yaw = 0; yaw_PID = 0;
    yaw_pid_p = 0; yaw_pid_i = 0; yaw_pid_d = 0; twoX_ki = 0;
  if (wheal_state == false) {
  if (Timer_Init == false) {
    timer1_write(80);
    Timer_Init = true;
  while (Time - timePrev  < 1200);
P.S. I found the "original" web site... complete with &amp;, &lt;, &gt; and extra ";"
It is a shame these sites can't be taken down.
We have tried your given code but it didn't work as you can see the picture we are facing this problem .
here we are using ESP32 WROOM modual . we also tried <ESP32WiFi.h> instead of <ESP8266WiFI.h> but we didn't get any result .
how do we add file directory ?
Why have you chosen the advice given to post code using code tags ?
I gave no code, just edited the original. You failed to provide a link. I found the place you copied the bad code from. That person/web site also copied bad code from somewhere else. Learn to code by learning to code, not by copy/paste and have someone else fix the mess. You learn nothing that way.
Stop guessing how it should be programmed and look at the WiFi examples for the ESP32 to see the name of the WiFi library to #include
we have done changes in code and also installed eeprom library but then also we are getting a problem in eeprom,
in the end we are getting this error :-
and some changes in our code
code :-
#include <Wire.h>
#include <WiFi.h>
#include <GPS.h>
WiFiUDP UDP;
char packet[4];
int input_YAW = 50;
int Mode = 0;
uint8_t pwm_stops;
    case 0:
      pwm_stops = 1;
        GPOS = (1  <<  14);
        GPOS = (1  <<  12);
        GPOS = (1  <<  15);
        GPOS = (1  <<  13);
    case 1:
      pwm_stops = 2;
    case 2:
      pwm_stops = 3;
    case 3:
      pwm_stops = 4;
    case 4:
      pwm_stops = 0;
  UDP.begin(9999);
  delay(6000);
  Wire.begin();
  Wire.write(0x6B);
  Wire.write(0x00);
  Wire.write(0x1A);
  Wire.write(0x03);
    Wire.write(0x3B);
  gyro_x_cal /= 4000;
  gyro_y_cal /= 4000;
  gyro_z_cal /= 4000;
  timePrev = Time;
  Time = micros();
  Wire.write(0x3B);
    angle_yaw -= 360;
    angle_yaw += 360;
  else {
    roll_pid_i = 0;
    roll_pid_i = 0;
    pitch_pid_i = 0;
    pitch_pid_i = 0;
    yaw_pid_i = 0;
    yaw_pid_i = 0;
    temp_i = i;
        temp_i = j;
    temp_arr[i] = temp;
      order[0] = k;
      orderState1 = true;
      order[1] = k;
      orderState2 = true;
      order[2] = k;
      orderState3 = true;
      order[3] = k;
      orderState4 = true;
  if (packetSize) {
    if (len > 0) {
      packet[len] = '\0';
    timer1_write(80);
    Timer_Init = true;
According to error message, you installed the library for AVR controllers, while your board is ESP.
@0arjuns_2005
How many times do we have to tell you not to put pictures of code and error messages in the forum before you understand that???
@0arjuns_2005
Why do you need to upload this code?
You obviously don't have even basic knowledge of Arduino and programming. If you want to learn, you need to start with simple examples: blinking an LED, controlling a motor, an LED strip.
The project you took is an advanced level, which you will grow up to in a year at best.
