working code for Daly Smart BMS via ESP32 Bluetooth
#include <Arduino.h>
#include <NimBLEDevice.h>
#define BMS_MAC_ADDRESS "50:18:06:01:15:2a"
#define SERVICE_UUID_MAIN "0000fff0-0000-1000-8000-00805f9b34fb"
#define CHAR_UUID_TX "0000fff1-0000-1000-8000-00805f9b34fb" // NOTIFY (BMS->Host)
#define CHAR_UUID_RX "0000fff2-0000-1000-8000-00805f9b34fb" // WRITE (Host->BMS)
// Default fallback cell count until 0x94 arrives
static int expectedCellCount = 12;
static int expectedFramesNeeded = (expectedCellCount + 2) / 3;
// Buffers and state
static float cellVoltages[48]; // up to 48 cells
static uint16_t cellRawMv[48]; // raw mV values
static bool frameReceived[16]; // up to 16 frames
static int framesReceivedCount = 0;
static bool assembled = false; // set true after we've printed assembled cells
// For determining whether 0x95 frame numbering is 0-based or 1-based
static bool frameBaseDetected = false;
static int frameBase = 0; // 0 => frames start at 0, 1 => frames start at 1
// stream buffer for incoming BLE notifications (they may contain many 13-byte frames)
static uint8_t rxStreamBuf[1024];
static size_t rxStreamLen = 0;
// NimBLE handles
static NimBLEClient* pClient = nullptr;
static NimBLERemoteCharacteristic* pTxCharacteristic = nullptr;
static NimBLERemoteCharacteristic* pRxCharacteristic = nullptr;
static bool connected = false;
static bool scanning = false;
// Basic BMS info
struct BMSDeviceInfo {
NimBLEAddress address;
String name;
int rssi;
bool found;
} bmsInfo;
bool verifyChecksum(const uint8_t* pkt, size_t len) {
if (len < 2) return false;
uint8_t sum = 0;
for (size_t i = 0; i < len - 1; ++i) sum += pkt[i];
return (sum == pkt[len - 1]);
void recomputeExpectedFrames() {
if (expectedCellCount < 1) expectedCellCount = 12;
if (expectedCellCount > 48) expectedCellCount = 48;
expectedFramesNeeded = (expectedCellCount + 3 - 1) / 3; // ceil div3
// reset assembly state (but keep detected frameBase)
void resetCellAssembly() {
memset(cellVoltages, 0, sizeof(cellVoltages));
memset(cellRawMv, 0, sizeof(cellRawMv));
memset(frameReceived, 0, sizeof(frameReceived));
assembled = false;
// convert raw mV to "mV (V)" string printing per user's option 1C
void printCellVoltages() {
Serial.println("--- DALY FRAME CMD=0x95 ---");
Serial.println("===============================================");
Serial.println("--- Cell Voltages ---");
for (int i = 0; i < expectedCellCount; ++i) {
uint16_t mv = cellRawMv[i];
float v = mv / 1000.0f;
Serial.printf("Cell %02d: %u mV (%.3f V)\n", i + 1, mv, v);
Serial.println("--- End Cell Voltages ---");
// parse a single 13-byte DALY frame
void parseFrame(const uint8_t* frame) {
if (frame[0] != 0xA5) return;
if (!verifyChecksum(frame, 13)) return;
uint8_t cmd = frame[2];
const uint8_t* payload = frame + 4; // payload[0..7]
switch (cmd) {
case 0x90: {
uint16_t total_raw = (payload[0] << 8) | payload[1];
uint16_t accum_raw = (payload[2] << 8) | payload[3];
uint16_t current_raw = (payload[4] << 8) | payload[5];
uint16_t soc_raw = (payload[6] << 8) | payload[7];
Serial.println("--- DALY FRAME CMD=0x90 ---");
Serial.println("Basic Status Info: Voltage, Current, SOC");
Serial.println("------------------------------------------------");
Serial.printf("Total Voltage: %.1f V\n", total_raw / 10.0f);
Serial.printf("Accum Voltage: %.1f V\n", accum_raw / 10.0f);
Serial.printf("Current: %.1f A\n", ((int)current_raw - 30000) / 10.0f);
Serial.printf("SOC: %.1f %%\n", soc_raw / 10.0f);
case 0x91: {
uint16_t max_mv = (payload[0] << 8) | payload[1];
uint8_t max_no = payload[2];
uint16_t min_mv = (payload[3] << 8) | payload[4];
uint8_t min_no = payload[5];
Serial.println("--- DALY FRAME CMD=0x91 ---");
Serial.println("Min/Max Cell Voltage Info:");
Serial.printf("MaxCell %d: %.3f V\n", max_no, max_mv / 1000.0f);
Serial.printf("MinCell %d: %.3f V\n", min_no, min_mv / 1000.0f);
Serial.printf("Voltage Difference: %.3fV (%dmV)\n", (max_mv - min_mv) / 1000.0f, (max_mv - min_mv));
case 0x92: {
float max_t = payload[0] - 40.0f;
uint8_t max_no = payload[1];
float min_t = payload[2] - 40.0f;
uint8_t min_no = payload[3];
Serial.println("--- DALY FRAME CMD=0x92 ---");
Serial.println("Temperature Info:");
Serial.printf("MaxTemp: %.1f C (sensor %d)\n", max_t, max_no);
Serial.printf("MinTemp: %.1f C (sensor %d)\n", min_t, min_no);
case 0x93: {
uint8_t state = payload[0];
uint8_t chargeMOS = payload[1];
uint8_t dischargeMOS = payload[2];
uint32_t remCap =
((uint32_t)payload[4] << 24) |
((uint32_t)payload[5] << 16) |
((uint32_t)payload[6] << 8) |
payload[7];
const char* stateStr = "Unknown";
if (state == 0) stateStr = "Stationary";
else if (state == 1) stateStr = "Charging";
else if (state == 2) stateStr = "Discharging";
const char* chargeMOSstr = (chargeMOS == 1) ? "ON" : "OFF";
const char* dischargeMOSstr = (dischargeMOS == 1) ? "ON" : "OFF";
Serial.println("--- DALY FRAME CMD=0x93 ---");
Serial.println("BMS State Info:");
Serial.printf("State: %s (%d)\n", stateStr, state);
Serial.printf("Charge MOS: %s\n", chargeMOSstr);
Serial.printf("Discharge MOS: %s\n", dischargeMOSstr);
Serial.printf("Remaining Capacity: %u mAh\n", remCap);
case 0x94: {
uint8_t batteryStrings = payload[0]; // number of cells
uint8_t tempCount = payload[1]; // temp sensors
uint8_t chargerStatus = payload[2]; // 0=disconnected, 1=connected
uint8_t loadStatus = payload[3]; // 0=disconnected, 1=connected
uint16_t cycles = (payload[5] << 8) | payload[6]; // bytes 5-6
Serial.println("--- DALY FRAME CMD=0x94 ---");
Serial.println("Battery Configuration Info:");
Serial.printf("Cells: %d cells\n", batteryStrings);
Serial.printf("Temperature Sensors: %d\n", tempCount);
Serial.printf("Charger Status: %s\n", chargerStatus ? "Connected" : "Disconnected");
Serial.printf("Load Status: %s\n", loadStatus ? "Connected" : "Disconnected");
Serial.printf("Charge Cycles: %d\n", cycles);
if (batteryStrings >= 1 && batteryStrings <= 48) {
expectedCellCount = batteryStrings;
recomputeExpectedFrames();
resetCellAssembly();
case 0x95: {
uint8_t rawFrameNo = payload[0];
if (!frameBaseDetected) {
if (rawFrameNo == 0) frameBase = 0;
else frameBase = 1;
frameBaseDetected = true;
int idx = (int)rawFrameNo - frameBase; // remap to 0-based index
if (idx < 0 || idx >= 16) break;
if (assembled) break;
if (frameReceived[idx]) break;
for (int i = 0; i < 3; ++i) {
int p = 1 + i * 2;
uint16_t mv = (payload[p] << 8) | payload[p + 1];
int cellIndex = idx * 3 + i; // 0-based
if (cellIndex < expectedCellCount) {
if (mv == 0xFFFF || mv == 0x0000) {
cellRawMv[cellIndex] = 0;
cellRawMv[cellIndex] = mv;
cellVoltages[cellIndex] = mv / 1000.0f;
frameReceived[idx] = true;
framesReceivedCount++;
bool allGot = true;
for (int f = 0; f < expectedFramesNeeded; ++f) {
if (!frameReceived[f]) { allGot = false; break; }
if (allGot) {
printCellVoltages();
assembled = true;
case 0x97: {
Serial.println("--- DALY FRAME CMD=0x97 ---");
Serial.println("Cell Balance State (0=Closed, 1=Open):");
int byteIndex = i / 8;
int bitIndex = i % 8;
bool balanced = (payload[byteIndex] >> bitIndex) & 0x01;
Serial.printf("Cell %02d: %s\n", i + 1, balanced ? "Open" : "Closed");
default:
// Process rxStreamBuf: extract any number of complete 13-byte frames
void processRxStream() {
while (rxStreamLen >= 13) {
if (rxStreamBuf[0] != 0xA5) {
size_t pos = 0;
while (pos < rxStreamLen && rxStreamBuf[pos] != 0xA5) ++pos;
if (pos == rxStreamLen) { rxStreamLen = 0; return; }
if (pos > 0) {
memmove(rxStreamBuf, rxStreamBuf + pos, rxStreamLen - pos);
rxStreamLen -= pos;
if (rxStreamLen < 13) return;
uint8_t frame[13];
memcpy(frame, rxStreamBuf, 13);
memmove(rxStreamBuf, rxStreamBuf + 13, rxStreamLen - 13);
rxStreamLen -= 13;
parseFrame(frame);
// Notification callback
static void notifyCB(NimBLERemoteCharacteristic* pRemoteCharacteristic,
uint8_t* pData, size_t length, bool isNotify) {
if (rxStreamLen + length > sizeof(rxStreamBuf)) {
rxStreamLen = 0;
memcpy(rxStreamBuf + rxStreamLen, pData, length);
rxStreamLen += length;
processRxStream();
class MyAdvertisedDeviceCallbacks : public NimBLEAdvertisedDeviceCallbacks {
void onResult(NimBLEAdvertisedDevice* dev) override {
String addr = dev->getAddress().toString().c_str();
addr.toLowerCase();
if (addr == BMS_MAC_ADDRESS) {
bmsInfo.address = dev->getAddress();
bmsInfo.name = dev->haveName() ? dev->getName().c_str() : "";
bmsInfo.rssi = dev->getRSSI();
bmsInfo.found = true;
if (scanning) {
NimBLEDevice::getScan()->stop();
scanning = false;
class ClientCallbacks : public NimBLEClientCallbacks {
void onConnect(NimBLEClient* pClient) override {
connected = true;
rxStreamLen = 0;
void onDisconnect(NimBLEClient* pClient) override {
connected = false;
rxStreamLen = 0;
if (::pClient) {
NimBLEDevice::deleteClient(::pClient);
::pClient = nullptr;
void scanForBMS(int durationSeconds) {
bmsInfo.found = false;
scanning = true;
NimBLEScan* scan = NimBLEDevice::getScan();
scan->setAdvertisedDeviceCallbacks(new MyAdvertisedDeviceCallbacks());
scan->setActiveScan(true);
scan->setInterval(80);
scan->setWindow(60);
scan->setMaxResults(0);
scan->start(durationSeconds, false);
unsigned long start = millis();
while (millis() - start < (unsigned long)durationSeconds * 1000 + 1000) {
if (!scanning) break;
delay(100);
if (scanning) {
scan->stop();
scanning = false;
void sendDalyRequest(uint8_t cmd, const uint8_t payload8[8] = nullptr) {
if (!pRxCharacteristic || !connected) return;
if (cmd == 0x95) {
uint8_t pkt[13];
pkt[0] = 0xA5;
pkt[1] = 0x40;
pkt[2] = cmd;
pkt[3] = 0x08;
for (int i = 0; i < 8; ++i) pkt[4 + i] = payload8 ? payload8[i] : 0x00;
uint8_t sum = 0;
for (int i = 0; i < 12; ++i) sum += pkt[i];
pkt[12] = sum;
if (pRxCharacteristic->canWrite()) {
pRxCharacteristic->writeValue(pkt, 13, true);
bool discoverAndSubscribe() {
if (!pClient || !pClient->isConnected()) return false;
NimBLERemoteService* svc = pClient->getService(SERVICE_UUID_MAIN);
if (!svc) return false;
pTxCharacteristic = svc->getCharacteristic(CHAR_UUID_TX);
pRxCharacteristic = svc->getCharacteristic(CHAR_UUID_RX);
if (!pTxCharacteristic || !pRxCharacteristic) return false;
if (pTxCharacteristic->canNotify()) pTxCharacteristic->subscribe(true, notifyCB);
return true;
bool connectToBMS() {
if (!bmsInfo.found) return false;
if (pClient) { NimBLEDevice::deleteClient(pClient); pClient = nullptr; }
pClient = NimBLEDevice::createClient();
pClient->setClientCallbacks(new ClientCallbacks());
pClient->setConnectTimeout(5);
if (!pClient->connect(bmsInfo.address)) {
pClient = nullptr;
return false;
if (!discoverAndSubscribe()) {
pClient->disconnect();
pClient = nullptr;
return false;
return true;
void cleanupClient() {
NimBLEDevice::init("ESP32-Daly-UART-BLE");
scanForBMS(8);
if (bmsInfo.found) {
if (connectToBMS()) {
connected = true;
delay(300);
sendDalyRequest(0x94);
delay(200);
sendDalyRequest(0x90); delay(120);
sendDalyRequest(0x91); delay(120);
sendDalyRequest(0x92); delay(120);
sendDalyRequest(0x93); delay(120);
sendDalyRequest(0x95);
sendDalyRequest(0x97);
static unsigned long lastPoll = 0;
if (connected && pClient && pClient->isConnected()) {
if (millis() - lastPoll > 1000) {
sendDalyRequest(0x90); delay(80);
sendDalyRequest(0x91); delay(80);
sendDalyRequest(0x92); delay(80);
sendDalyRequest(0x93); delay(80);
sendDalyRequest(0x94); delay(150);
lastPoll = millis();
static unsigned long lastReconnect = 0;
if (millis() - lastReconnect > 3000) {
cleanupClient();
scanForBMS(6);
connectToBMS();
lastReconnect = millis();
if (Serial.available()) {
char c = Serial.read();
switch (c) {
case 'c': if (!connected && bmsInfo.found) connectToBMS(); break;
case 'd': if (pClient && pClient->isConnected()) pClient->disconnect(); cleanupClient(); connected = false; break;
case '0': sendDalyRequest(0x90); break;
case '1': sendDalyRequest(0x91); break;
case '2': sendDalyRequest(0x92); break;
case '3': sendDalyRequest(0x93); break;
case '4': sendDalyRequest(0x94); break;
case '5': sendDalyRequest(0x95); break;
case '6': sendDalyRequest(0x97); break;
case 'r': resetCellAssembly(); frameBaseDetected = false; break;
default: break;
delay(20);
platformio.ini
; PlatformIO Project Configuration File
; Build options: build flags, source filter
; Upload options: custom upload port, speed and extra flags
; Library options: dependencies, extra library storages
; Advanced options: extra scripting
; Please visit documentation for the other options and examples
; https://docs.platformio.org/page/projectconf.html
[env:esp32dev]
platform = espressif32
board = esp32dev
framework = arduino
lib_compat_mode = strict
build_flags =
-D CORE_DEBUG_LEVEL=0 ; Disable Arduino core debug messages (was set to 5)
-D NIMBLE_DEBUG=0 ; Disable NimBLE debug messages
monitor_speed = 115200
monitor_filters = log2file, time, colorize, esp32_exception_decoder
lib_deps =
h2zero/NimBLE-Arduino@^1.4.1 ; Supported version 1.4.3
