I'm new to this forum. I have a basic question that may appear elementary to some of you but I would really appreciate a help.
I want to connect 2 Arduino Uno (let's call them A and B) so that they can communicate with a third component (C).
here's a simplified example of what I want to make:
A and B would generate numbers and send them to C.
C would read the numbers of A and B and process them.
for example:
A generates the number 45.
B generates the number 33.
C receives and reads both the numbers and makes the sum 78.
The process is very easy. But is it feasible?
I have 2 Arduino Uno available. And jumpers and breadboard.
What else would I need?
I was reading in some forum about I2C, but maybe it would not be good in my case.
Do you think that the best thing to do is to have 3 Arduino of which:
A and B programmed to generate numbers;
C programmed to read the numbers of A and B and process them?
and in this case I would only need some jumpers to connect A, B and C?
or some other components is needed?
I2C might be better than serial, since C can cantrol just when it reads the data. If you use software serial it can only listen to one at a time. A mega would allow for multiple hardware serial ports, and might be a better choice.
KeithRB:
An Arduino Mega2560 - look up the Arduino product page.
That wasn't really why I pressed Reply, however ...
It must be blindingly obvious to all that you don't need three Arduinos to add two numbers. So it would probably be useful if you explain what your project is really about.
Robin2:
...R
ahahah yes I would not need three Arduino, one would be probably enough.
BUT, since it is an art project/experiment, I need three physical hardwares interconnected.
A and B would interact between them only through C.
I think it would make life very much easier if you use a Mega2560 for "C". It has 4 hardware serial ports so you can connect one to each of the other Arduinos and have a serial connection to your PC for development and debugging.
Robin2:
