Communication between Arduino and Light Meter
Dear Community,
I'm pretty new in the Arduino although I did some very basic projects. So I need some help from you guys.
The project I'm going to do is to use Arduino to receive and read the measurement data from a light meter, which can be used for measuring illuminance value. From the manual of the light meter, I noticed that in order to get the data, it is necessary to send a series of commands to the light meter so that it can respond and send the data back.
I used the RS232 cable to connect Arduino with the light meter(Rx,Tx, GND) and tried to send a series of string from Arduino to the light meter, but I didn't get any response. So I reckon my programming and my understanding of this communication might have some problems.
This is my code I wrote:
#include <SoftwareSerial.h>
SoftwareSerial mySerial(7,8);
String strSndSTX = String(0x02); //STX=o2h
String strSndETX = String(0x03); //ETX=o3h
String strSndCommand;
String strSndBCC;
String strSendStr;
String strReceiveStr;
mySerial.begin(9600);
strSndCommand = "00541 "; //First command that I need to send based on the manual
strSndBCC = "13";
strSendStr = strSndSTX + strSndCommand + strSndETX + strSndBCC + "\r" + "\n"; //according to manual
mySerial.println(strSendStr); //send the serieal of command
strReceiveStr = Serial.read(); // read the response, but I didn't get any response
Serial.println(strReceiveStr);
I have attached the manual of the light meter so that you guys can have a look.
Any suggestions will be appreciated. Thank you so much.
cl-200a_cs0101e_eng comms specifications.pdf (415 KB)
Why do you concatenate a whole series of strings that are all written sequentially to the same port? Ditch the String class, it isn't reliable on a machine as small as the AVR. Have you tried connecting and sending commands to the meter manually? Does the meter have RS232 electrical levels or TTL levels?
aarg:
Hi Aarg,
Thank you for your reply.
The manual provides some code examples written in Visual Basic Language, and it uses String to send the command, so that's why I used String as well. But I'm not really sure how should I send all the commands using C language, can you give me some suggestions?
How should I send commands to the meter manually? Is it by using the serial monitor?
I measured the voltage level of the meter outlet, it was 5V. So I reckon it should be TTL level, am I correct?
Thanks again.
You can make the Arduino a pass through, something like:
while (Serial1.available())
Serial2.write(Serial1.read());
while (Serial2.available())
Serial1.write(Serial2.read());
But what should I type in the serial monitor when sending the command manually? According to the manual of the meter, it is necessary to send the command like this:
STX(02h) + "00541 " + ETX(03h) + "13"
So how should I send the STX and ETX from serial monitor?
Should I type and send each element separately or combine them as one line?
Many thanks!
Dear Community,
String strSndBCC;
String strSendStr;
strSndBCC = "13";
Maybe because you read the serial from Serial, not from mySerial. Try this (untested):
 strSndBCC = "13";
 mySerial.print(strSendStr); //send the serieal of command
  do {
   strReceiveStr = mySerial.read();
   Serial.print(strReceiveStr);
  while (mySerial.available());
Your light meter is using RS232 connection, not TTL serial communication.
To fix this, use this line:
SoftwareSerial mySerial(7,8,true);
Adding TRUE as last parameter is to inverse logic from TTL to RS232. https://www.arduino.cc/en/Reference/SoftwareSerialConstructor
Also, you can't just use:
You need to use something like:
String s="";
if (mySerial.available() >0) {
  char c=mySerial.read();
  s=s+c;
  ...  //next process
Bronson
www.pt-altraman.com
Bronson_alex:
String s="";
  s=s+c;
  ...  //next process
Bronson
[www.pt-altraman.com](http://www.pt-altraman.com)
Hi Bronson,
I modified my code as what you said, but it still doesn't work. I can't receive any response from the light meter. Maybe it's because the light meter doesn't receive the command? I'm sure whether I used a right way to send the command. Should I send it as a string or other types of data?
Hi guys,
I'm trying to connect Arduino UNO with a light meter device used for measuring illuminance value, so that Arduino can read and process the measured data from the meter. But I got some issues regarding the serial communication between these two devices.
I read the manual of the light meter and it says in order to receive the measured data, it is required to send a serial of commands to the light meter using RS232. I connected Arduino with the light meter (Tx,Rx,GND), and wrote the code for sending the commands and reading the data, but I didn't get any response from the light meter.
The communication format: STX(02h) + Command Characters + ETX(03h) + BCC + CR(0Dh) + LF(0Ah)
This is my code:
byte STX = 0x02; //STX=02h
byte ETX = 0x03; //ETX=03h
byte CR = 0x0D; //CR=0Dh
byte LF = 0x0A; //LF=0A
String strSndBCC;
byte incomingByte;
  strSndCommand = "00541   "; //Command
  strSndBCC = "13";
  //Send Command
  mySerial.write(STX);//HTX command begin code
  mySerial.write("00541   ");
  mySerial.write(ETX);//ETX command end code
  mySerial.write("13");
  mySerial.write(CR);//CRcode
  mySerial.write(LF);//CRcode
  //Receive Response
  Serial.println("Listening for response...");
  while (mySerial.available() > 0)
  incomingByte = mySerial.read();
  Serial.print("I received: ");
  Serial.println(incomingByte);
I also attached the Communication Specification Manual of the light meter.
Can anyone help me to deal with this issue? Any suggestions would be appreciated.
Thank you so much.
Best regards,
Mirko
Normally I would do:
byte msg1[] = {0xAA, 0x01, 0x42, 0x43, 0xA8};  //msg1 = hex AA, 01, 42, 43, A8
mySerial.write(msg1, sizeof(msg1));  //send msg1 to the RS232 device
String s="";
while (mySerial.available()>0) {    //receive and store response as string s
  if (c != '\n') {           //if not LF (linefeed)
    s=s+c;
    Serial.println(s);
You shouldn't send the message as string type, use byte type.
Hope it helps.
Bronson
www.pt-altraman.com
Thank you, Bronson. But how can I send string as byte?
The light meter manual mentions the command needs to be String such as "00541 ".
The Arduino Serial interface uses TTL level signals so you need a converter between the two
@MirkoZhou, do not cross-post. Threads merged.
Ugh. @MirkoZhou, do not cross-post again. Threads merged again.
Seriously? @MirkoZhou, do not cross-post ever again. Other thread removed.
MirkoZhou:
You can do:
byte msg1[] = {0x03, 0xBC, 0x0D, 0x0A};  //Dont know what BCC is
mySerial.write(0x02);
mySerial.print("00541   ");
I don't know what BCC is, so I just write 0xBC on my snippet
Is the device really an RS232 device? The Arduino can not handle an RS232 device directly. The serial signals are the wrong voltage and are inverted. You need a MAX232 chip between the Arduino and any RS232 device to handle the voltage differences.
@Coding Badly
Sorry, this is my first time using this Forum. I was not quite sure where is the most appropriate place to post my question, so I posted in multiple sections. Sorry again
PaulS:
Thanks Paul.
Yeah, I was thinking maybe I should use a converter between this two devices as well.
I did some research about the TTL voltage and RS232 voltage, and I noticed that the output voltage coming from RS232 would be as high as 25V. But when I used the voltage meter to measure the output port of the light meter, the voltage value was only 5V.
So I'm confused. The cable they provide is a RS232 cable, but the output doesn't reach the 25V.
Do I still need the MAX232 chip in this condition?
