Communication between arduino and RFID-RC522 with ethernet shield
Well, I'm currently doing a project in which the goal is to send data from the card passed in RFID to my website via json ...
but I have a difficulty with ethernet shield because it uses ports 11, 12, 13, 10, because RDIF has these pre-defined without ethernet works and I can print the values on the console, not with ethernet shield.
If anyone knew of any solution I would appreciate it
#include <SPI.h>
#include <MFRC522.h>
#include <ArduinoJson.h>
#include <Ethernet.h>
#define SS_PIN 10
#define RST_PIN 9
#define buzzer 2
#define GREEN 4
#define RED 3
MFRC522 mfrc522(SS_PIN, RST_PIN);   // Create MFRC522 instance.
  Serial.begin(9600);   // Initiate a serial communication
  SPI.begin();      // Initiate  SPI bus
  mfrc522.PCD_Init();   // Initiate MFRC522
  Serial.println("Approximate your card to the reader...");
  pinMode(7, OUTPUT);
pinMode(buzzer, OUTPUT);
{digitalWrite(RED,HIGH);
  // Look for new cards
  if ( ! mfrc522.PICC_IsNewCardPresent())
    return;
  // Select one of the cards
  if ( ! mfrc522.PICC_ReadCardSerial())
    return;
  //Show UID on serial monitor
  Serial.print("UID tag :");
  String content= "";
  byte letter;
  for (byte i = 0; i < mfrc522.uid.size; i++)
     Serial.print(mfrc522.uid.uidByte[i] < 0x10 ? " 0" : " ");
     Serial.print(mfrc522.uid.uidByte[i], HEX);
     content.concat(String(mfrc522.uid.uidByte[i] < 0x10 ? " 0" : " "));
     content.concat(String(mfrc522.uid.uidByte[i], HEX));
  Serial.print("Message : ");
  content.toUpperCase();
  if (content.substring(1) == "69 F5 ED 6E") //change here the UID of the card/cards that you want to give access
    Serial.println("Authorized access");
   digitalWrite(GREEN,HIGH);
     tone(buzzer, 1000); // Send 1KHz sound signal...
  delay(800);        // ...for 1 sec
  noTone(buzzer);     // Stop sound...
  delay(800);
    digitalWrite(GREEN,LOW);
 else   {
    Serial.println(" Access denied");
  delay(800);
    digitalWrite(RED,LOW);
