Communication between two MKR IoT Carrier's
I wish to connect two MKR IoT Carrier to the same MKR1010 Wifi board in order to get additional relays for my project. Is this possible, and if so, how do I connect them to be able to control the four relays?
As I can understand I can connect two Oplà carrier boards using an I2C cable.
I tried using this code:
#include <Arduino_MKRIoTCarrier.h>//Include Carrier Shield for 2 relais
MKRIoTCarrier carrier; //Name of shield for the code
// Create instances of the Carrier class for each board
MKRIoTCarrier carrier1(0x08); // create object for first carrier board
MKRIoTCarrier carrier2(0x09); // create object for second carrier board
But I get this error:
Compilation error: no matching function for call to 'MKRIoTCarrier::MKRIoTCarrier(int)'
Welcome to the forum Sophie,
First Thank You for posting a well formed question that uses code tags.
But it would be better if you could post your entire code and the entire error.
The constructor for this library does not accept arguments. These two lines are the cause of your error.
Remove the arguments and the extra object(which was the only one that was correct):
MKRIoTCarrier carrier1; // create object for first carrier board
MKRIoTCarrier carrier2; // create object for second carrier board
It seems a waste to use a second Carrier for just a couple relays when a relay module is much cheaper.
This should get rid of that particular error.
