Communication between two NodeMCU too slow??
Hi @ all so I am working on this Project and I want to send values via a Client-Server communication from one to another NodeMCU.
It all works like a charm but since I analogRead values on the Client, it Would be great to have them as fast as possible on the Server-NodeMCU. Withe the Code below, I get like 2 Values in a Second but I want -so to say- a higher resolution of the different Values. For Example when my Values change gradientially from 1023 to 0 I dont want to receive on the Server-NodeMCU
    Client No 0 - 1023
    Client No 0 - 0
more Something like:
   Client No 0 - 1023
   Client No 0 - 1000
   Client No 0 - 990
   Client No 0 - 0
And that in the same time of reading and sending the Values.
Is there any way to speed up the communication (in my Code)??
Thank you!
Server-NodeMCU Code:
//-- Libraries Included --------------------------------------------------------------
  #include <ESP8266WiFi.h>
  // Define I/O Pins
  #define     LED0      2           // WIFI Module LED
  #define     LED1      D0          // Connectivity With Client #1
  #define     LED2      D2          // Connectivity With Client #2
  #define     BUTTON    D1          // Connectivity ReInitiate Button
  // Authentication Variables
  char*       TKDssid;              // SERVER WIFI NAME
  char*       TKDpassword;          // SERVER PASSWORD
  #define     MAXSC     1           // MAXIMUM NUMBER OF CLIENTS
   * MAXSC => Maximum Server Clients
   * They Are 6 Because
   * 1. Blue Fighter Suit
   * 2. Red Fighter Suit
   * 3. Corner Referee 1
   * 4. Corner Referee 2
   * 5. Corner Referee 3
   * 6. Corner Referee 4
  WiFiServer  TKDServer(9001);      // THE SERVER AND THE PORT NUMBER
  WiFiClient  TKDClient[MAXSC];     // THE SERVER CLIENTS (Devices)
    // Setting The Serial Port
    Serial.begin(115200);           // Computer Communication
    // Setting The Mode Of Pins
    pinMode(LED0, OUTPUT);          // WIFI OnBoard LED Light
    pinMode(LED1, OUTPUT);          // Indicator For Client #1 Connectivity
    pinMode(LED2, OUTPUT);          // Indicator For Client #2 Connectivity
    pinMode(BUTTON, INPUT_PULLUP);  // Initiate Connectivity
    // Print Message Of I/O Setting Progress
    Serial.println("I/O Pins Modes Set .... Done");
    // Setting Up A Wifi Access Point
    SetWifi("TAKEONE", "");
    // Checking For Available Clients
    AvailableClients();
    // Checking For Available Client Messages
    AvailableMessage();
  void SetWifi(char* Name, char* Password)
    // Stop Any Previous WIFI
    WiFi.disconnect();
    // Setting The Wifi Mode
    WiFi.mode(WIFI_AP_STA);
    Serial.println("WIFI Mode : AccessPoint Station");
    // Setting The AccessPoint Name & Password
    TKDssid      = "Hellowifi";
    TKDpassword  = "1234567890";
    // Starting The Access Point
    WiFi.softAP(TKDssid, TKDpassword);
    Serial.println("WIFI < " + String(TKDssid) + " > ... Started");
    // Wait For Few Seconds
    // Getting Server IP
    IPAddress IP = WiFi.softAPIP();
    // Printing The Server IP Address
    Serial.print("AccessPoint IP : ");
    Serial.println(IP);
    // Printing MAC Address
    Serial.print("AccessPoint MC : ");
    Serial.println(String(WiFi.softAPmacAddress()));
    // Starting Server
    TKDServer.begin();
    TKDServer.setNoDelay(true);
    Serial.println("Server Started");
  void AvailableClients()
    if (TKDServer.hasClient())
      // Read LED0 Switch To Low If High.
      if(digitalRead(LED0) == HIGH) digitalWrite(LED0, LOW);
      // Light Up LED1
      digitalWrite(LED1, HIGH);
      for(uint8_t i = 0; i < MAXSC; i++)
        //find free/disconnected spot
        if (!TKDClient[i] || !TKDClient[i].connected())
          // Checks If Previously The Client Is Taken
          if(TKDClient[i])
            TKDClient[i].stop();
          // Checks If Clients Connected To The Server
          if(TKDClient[i] = TKDServer.available())
            Serial.println("New Client: " + String(i));
          // Continue Scanning
          continue;
      //no free/disconnected spot so reject
      WiFiClient TKDClient = TKDServer.available();
      TKDClient.stop();
      // This LED Blinks If No Clients Where Available
      digitalWrite(LED0, HIGH);
      delay(250);
      delay(250);
  void AvailableMessage()
    //check clients for data
      if (TKDClient[i] && TKDClient[i].connected() && TKDClient[i].available())
          while(TKDClient[i].available())
            String Message = TKDClient[i].readStringUntil('\r');
            TKDClient[i].flush();
            Serial.println("Client No " + String(i) + " - " + Message);
Client-NodeMCU code:
// Libraries Needed For This Project
  #include <Wire.h>           // To Be Able To Use Sensors Like IMU9050
  #include <EEPROM.h>         // To Be Able To Store & Read Data Between Power Off
  #include <ESP8266WiFi.h>    // The Basic Function Of The ESP NOD MCU
// Defining I/O Pins
  #define       LED1      D0        // Indicate Connectivity With Client #1
  #define       LED2      D2        // Indicate Connectivity With Client #2
// BUTTON Variables
  int           ButtonState;
  int           LastButtonState   = LOW;
  int           LastDebounceTime  = 0;
  int           DebounceDelay     = 50;
  const String  Type              = "Remote";
// LED Delay Variables
  int           LEDState          = LOW;
  unsigned long CurrMillis        = 0;
  unsigned long PrevMillis        = 0;
  unsigned long Interval          = 1000;
// WIFI Authentication Variables
/* This Client Is Going To Connect To A WIFI Server Access Point
 * So You Have To Specify Server WIFI SSID & Password In The Code Not Here
 * Please See The Function Below Name (WiFi.Begin)
 * If WIFI dont need Any password Then WiFi.begin("SSIDNAME")
 * If WIFI needs a Password Then WiFi.begin("SSIDNAME", "PASSWORD")
  char*         TKDssid;            // Wifi Name
  char*         TKDpassword;        // Wifi Password
// WIFI Module Role & Port
/* This WIFI Module Code Works As A Client
 * That Will Connect To A Server WIFI Modul With (IP ADDress 192.168.4.1)
  int             TKDServerPort  = 9001;
  IPAddress       TKDServer(192,168,4,1);
  WiFiClient      TKDClient;
    // Setting The Serial Port ----------------------------------------------
    // Setting The Mode Of Pins ---------------------------------------------
    digitalWrite(LED0, !LOW);       // Turn WiFi LED Off
    // Print Message Of I/O Setting Progress --------------------------------
    Serial.println("\nI/O Pins Modes Set .... Done");
    // Starting To Connect --------------------------------------------------
    if(WiFi.status() == WL_CONNECTED)
      WiFi.disconnect();
      WiFi.mode(WIFI_OFF);
      delay(50);
    /* in this part it should load the ssid and password
     * from eeprom they try to connect using them */
    WiFi.mode(WIFI_STA);            // To Avoid Broadcasting An SSID
    WiFi.begin("Hellowifi", "1234567890");      // The SSID That We Want To Connect To
    // Printing Message For User That Connetion Is On Process ---------------
    Serial.println("!--- Connecting To " + WiFi.SSID() + " ---!");
    // WiFi Connectivity ----------------------------------------------------
    CheckWiFiConnectivity();        // Checking For Connection
    // Stop Blinking To Indicate Connected ----------------------------------
    digitalWrite(LED0, !HIGH);
    Serial.println("!-- Client Device Connected --!");
    // Printing IP Address --------------------------------------------------
    Serial.println("Connected To      : " + String(WiFi.SSID()));
    Serial.println("Signal Strenght   : " + String(WiFi.RSSI()) + " dBm");
    Serial.print  ("Server IP Address : ");
    Serial.println(TKDServer);
    Serial.print  ("Server Port Num   : ");
    Serial.println(TKDServerPort);
    Serial.print  ("Device MC Address : ");
    Serial.println(String(WiFi.macAddress()));
    Serial.print  ("Device IP Address : ");
    // Conecting The Device As A Client -------------------------------------
    TKDRequest();
   SendValues();
  void SendValues()
    // Reading The Button
    int reading = analogRead(BUTTON);
          TKDClient.println(reading);
          TKDClient.flush();
  void CheckWiFiConnectivity()
    while(WiFi.status() != WL_CONNECTED)
      for(int i=0; i < 10; i++)
        delay(250);
        delay(250);
        Serial.print(".");
      Serial.println("");
  void I2C_Begin()
     * Setting The I2C Pins SDA, SCL
     * Because We Didnt Specify Any Pins The Defult
     * SDA = D4 <GPIO2>, SCL = D5 <GPIO14> For ESP8266 Dev Kit Node MCU v3
    // Frequency Of The I2C
    #define TWI_FREQ  400000L       // I2C Frequency Setting To 400KHZ
    // If Ever You Needed To Use Wire I2C
    Wire.begin();                   // Begginning The I2C
    // Setting Up The I2C Of The MPU9250 ------------------------------------
    Wire.setClock(TWI_FREQ);        // Setting The Frequency MPU9250 Require
  void TKDRequest()
    // First Make Sure You Got Disconnected
    TKDClient.stop();
    // If Sucessfully Connected Send Connection Message
    if(TKDClient.connect(TKDServer, TKDServerPort))
      Serial.println    ("<" + Type + "-CONNECTED>");
      TKDClient.println ("<" + Type + "-CONNECTED>");
The fastest way I know is to use the mqtt protocol. Well programmed it can be almost delay-less
andre123aei:
Thank You for your hint....can you provide any Example-Code??
This is a mqtt example for com between pc and mcu. In the video, instead of deleting the publishing part u use it to send data to the other. You create a topic named like "communication" and subscribe one of the mcu. as soon as the other publishes in that topic the other will recieve.
