Voici le code de la mega2560
et voici le code MEGA2560
int getMedianNum(int bArray[], int iFilterLen)
int bTab[iFilterLen];
for (byte i = 0; i < iFilterLen; i++)
bTab[i] = bArray[i];
int i, j, bTemp;
for (j = 0; j < iFilterLen - 1; j++)
for (i = 0; i < iFilterLen - j - 1; i++)
if (bTab[i] > bTab[i + 1])
bTemp = bTab[i];
bTab[i] = bTab[i + 1];
bTab[i + 1] = bTemp;
if ((iFilterLen & 1) > 0)
bTemp = bTab[(iFilterLen - 1) / 2];
bTemp = (bTab[iFilterLen / 2] + bTab[iFilterLen / 2 - 1]) / 2;
return bTemp;
unsigned long previousMillis = 0; // will store last time sensor was updated
const long interval = 5000; // temps entre mesures
#include <SPI.h>
#include <SD.h>
const int chipSelect = 49;
#include <virtuabotixRTC.h> //Library used
#define DS1302_GND_PIN 33
#define DS1302_VCC_PIN 31
#include <ArduinoJson.h>
LiquidCrystal_I2C lcd(0x27, 16, 2); // set the LCD address to 0x27 for a 16 chars and 2 line display
String message = "";
bool messageReady = false;
#define RELAY1 24
#define LAMPES 22
#include <DHT.h>;
#include <DallasTemperature.h>
//Constants
#define DHTPIN 8 // what pin we're connected to
#define DHTTYPE DHT22 // DHT 22 (AM2302)
DHT dht(DHTPIN, DHTTYPE); //// Initialize DHT sensor for normal 16mhz Arduino
#define ONE_WIRE_BUS 7
OneWire oneWire(ONE_WIRE_BUS);
DallasTemperature sensors(&oneWire);
//Variables
int chk;
float humi; //Stores humidity value
float temp; //Stores temperature value
#define TdsSensorPin A3
#define VREF 5.0 // analog reference voltage(Volt) of the ADC
#define SCOUNT 3 // sum of sample point
int analogBuffer[SCOUNT]; // store the analog value in the array, read from ADC
int analogBufferTemp[SCOUNT];
int analogBufferIndex = 0, copyIndex = 0;
float averageVoltage = 0, tdsValue = 0;
virtuabotixRTC myRTC(35, 37, 39); //If you change the wiring change the pins here also
const int OnHour = 00;
const int OnMin = 07; //set hour and minutes for timer
const int OffHour = 22;
const int OffMin = 26; //The setup is done only one time and the module will continue counting it automatically
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
Serial.print("Initializing SD card...");
// see if the card is present and can be initialized:
if (!SD.begin(chipSelect)) {
Serial.println("Card failed, or not present");
// don't do anything more:
while (1);
Serial.println("card initialized.");
dht.begin();
sensors.begin();
pinMode(TdsSensorPin, INPUT);
pinMode(RELAY1, OUTPUT);
digitalWrite(DS1302_GND_PIN, LOW);
pinMode(DS1302_GND_PIN, OUTPUT);
digitalWrite(DS1302_VCC_PIN, HIGH);
pinMode(DS1302_VCC_PIN, OUTPUT);
pinMode(LAMPES, OUTPUT);
lcd.init();
lcd.backlight();
lcd.setCursor(0, 0);
lcd.print("Alex's Project");
lcd.setCursor(2, 1);
lcd.print("Mars 2020");
delay(3000);
lcd.clear();
sensors.requestTemperatures();
float temperature = sensors.getTempCByIndex(0);
if (temperature < 19)
digitalWrite(RELAY1, 0);
else if (temperature > 20)
digitalWrite(RELAY1, 1);
File dataFile = SD.open("datalog.txt", FILE_WRITE);
if (currentMillis - previousMillis >= interval) {
// save the last time you blinked the LED
dataFile.println(temperature);
dataFile.close();
myRTC.updateTime();
// Start printing elements as individuals
Serial.print("Current Date / Time: ");
Serial.print(myRTC.dayofmonth); //You can switch between day and month if you're using American system && myRTC.minutes == OnMin
Serial.print("/");
Serial.print(myRTC.month);
Serial.print("/");
Serial.print(myRTC.year);
Serial.print(" ");
Serial.print(myRTC.hours);
Serial.print(":");
Serial.print(myRTC.minutes);
Serial.print(":");
Serial.println(myRTC.seconds);
delay (3000);
if (myRTC.hours == OnHour && myRTC.minutes == OnMin ) { // add && myRTC.minutes == OnMin ; (myRTC.hours == OffHour && myRTC.minutes == OffMin){
digitalWrite(LAMPES, HIGH);
Serial.println("LIGHT ON");
delay(250);
else if (myRTC.hours == OffHour && myRTC.minutes == OffMin ) { // add && myRTC.minutes == OnMin ; (myRTC.hours == OffHour && myRTC.minutes == OffMin){
digitalWrite(LAMPES, LOW);
Serial.println("LIGHT Off");
float humi = dht.readHumidity();
float temp = dht.readTemperature();
static unsigned long analogSampleTimepoint = millis();
if (millis() - analogSampleTimepoint > 40U) //every 40 milliseconds,read the analog value from the ADC
analogBuffer[analogBufferIndex] = analogRead(TdsSensorPin); //read the analog value and store into the buffer
analogBufferIndex++;
if (analogBufferIndex == SCOUNT)
analogBufferIndex = 0;
static unsigned long printTimepoint = millis();
if (millis() - printTimepoint > 800U)
for (copyIndex = 0; copyIndex < SCOUNT; copyIndex++)
analogBufferTemp[copyIndex] = analogBuffer[copyIndex];
averageVoltage = getMedianNum(analogBufferTemp, SCOUNT) * (float)VREF / 1024.0; // read the analog value more stable by the median filtering algorithm, and convert to voltage value
float compensationCoefficient = 1.0 + 0.02 * (temperature - 25.0); //temperature compensation formula: fFinalResult(25^C) = fFinalResult(current)/(1.0+0.02*(fTP-25.0));
float compensationVolatge = averageVoltage / compensationCoefficient; //temperature compensation
tdsValue = (133.42 * compensationVolatge * compensationVolatge * compensationVolatge - 255.86 * compensationVolatge * compensationVolatge + 857.39 * compensationVolatge) * 0.5; //convert voltage value to tds value
//Serial.print("voltage:");
//Serial.print(averageVoltage,2);
//Serial.print("V ");
while (Serial.available()) {
message = Serial.readString();
messageReady = true;
// Only process message if there's one
if (messageReady) {
// The only messages we'll parse will be formatted in JSON
DynamicJsonDocument doc(1024); // ArduinoJson version 6+
// Attempt to deserialize the message
DeserializationError error = deserializeJson(doc, message);
if (error) {
Serial.print(F("deserializeJson() failed: "));
Serial.println(error.c_str());
return;
if (doc["type"] == "request") {
doc["type"] = "response";
// Get data from analog sensors
doc["teau"] = sensors.getTempCByIndex(0);
doc["tair"] = dht.readTemperature();
doc["hum"] = dht.readHumidity();
doc["tds"] = tdsValue ;
serializeJson(doc, Serial);
Serial.print("Humidity: ");
Serial.print(humi);
Serial.println(" %");
Serial.print("Temp air: ");
Serial.print(temp);
Serial.println(" Celsius");
Serial.print("Temp H2O ;");
Serial.print(temperature);
Serial.print("TDS Value:");
Serial.print(tdsValue, 0);
Serial.println("ppm");
delay(2000); //Delay 2 sec.
lcd.print("Eau ");
lcd.print(temperature, 1);
lcd.setCursor(9, 0);
lcd.print("Hum ");
lcd.print(humi, 0);
lcd.print("%");
lcd.setCursor(0, 1);
lcd.print("Air ");
lcd.print(temp, 1);
lcd.setCursor(9, 1);
lcd.print("TDS ");
lcd.print(tdsValue, 0);
