I am trying to read the values from SHT75 via Uno but, whatever I do I get same result.
"Temperature = -40.10 C, Humidity = 0.10 %, Dewpoint = -90.17 C"
I connected the wires according to datasheet, changed the wires a few times, changed the pins on the uno but the result is same. Even if I disconnect the sensor from the board it gives the same values.
Could be a faulty sensor. Could be faulty wiring. Could be faulty code.
Why don't you read the forum guide in the sticky post at the top of the forum section. This will tell you what you need to include in your question in order for the forum to be able to help you.
Sorry if I made a mistake. I made some research on the internet, some people have the same issue but couldn't find the solution. That is the reason I created this topic.
I am new to Arduino but not to electronics and microprocessors.
Sensor is kinda new and expensive, don't think there is a problem with sensor.
Wiring is very simple, too hard to make a mistake. I attached the wiring diagram above. VDD is 3.3V
Here is the code that I use;
Thanks for beneficial comment. I already tried that too. The interesting thing was even if I pull all the cables from micro controller the values were the same.
Good news is I got another sensor today and it worked. The sensor is oversensitive, I think I damaged it while soldering. Soldering iron was in contact for a 1 minutes in 3 minutes time period.
I will try to read values from the screen this weekend, will try it with stm32 as well.
I hope this topic will help people who has problem with this sensor.
