Hello you all Ihave trouble communicating with my Arduino UNO R4 WIFI
i See it in the device manager as COM5
Tools/board info returns the correct info
HOWEVER
uploading a scetch to the board results in
Sketch uses 56216 bytes (21%) of program storage space. Maximum is 262144 bytes.
Global variables use 6924 bytes (21%) of dynamic memory, leaving 25844 bytes for local variables. Maximum is 32768 bytes.
No device found on COM5
Failed uploading: uploading error: exit status 1
IDE VERSION:
Version: 2.3.2
Date: 2024-02-20T10:04:35.814Z
CLI Version: 0.35.3
Is there somone who can help me with this
Hi @tapirjos. I'm going to ask you to provide the full verbose output from an upload attempt.
This procedure is not intended to solve the problem. The purpose is to gather more information.
Please do this:
Select File > Preferences... (or Arduino IDE > Settings... for macOS users) from the Arduino IDE menus.
The "Preferences" dialog will open.
Uncheck the box next to Show verbose output during: ☑ compile in the "Preferences" dialog.
Check the box next to Show verbose output during: ☐ upload.
Click the "OK" button.
The "Preferences" dialog will close.
Attempt an upload, as you did before.
Wait for the upload to fail.
You will see an "Upload error: ..." notification at the bottom right corner of the Arduino IDE window. Click the "COPY ERROR MESSAGES" button on that notification.
Open a forum reply here by clicking the "Reply" button.
Click the <CODE/> icon on the post composer toolbar.
This will add the forum's code block markup (```) to your reply to make sure the error messages are correctly formatted.
"C:\Users\josva\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.9.1-arduino5/bossac" -d --port=COM5 -U -e -w "C:\Users\josva\AppData\Local\arduino\sketches\DF357EA9228398D3E679245C1812E1BD/pid_T_controlv199.ino.bin" -R
