Hi
Experience:
I have only been tinkering with Arduino coding for a few weeks, so I'm still struggling... alot.
Hardware:
I am using an Arduino Uno along with a DS1307 RTC and 2 x 28BYJ-48 Steppers with their power modules.
Purpose of the program:
The purpose of the program is to calculate the current elevation and azimuth of the sun (Based on my local time from RTC and Geographical Location) using some fancy math I found online (Julian dates and a lot of sin, cos & tan ). I would then loop this every 60 sec (Can be more or less. does not matter). I would then get the difference between the current elevation and azimuth and that of 60sec ago. This difference will then move 2 stepper motors a corresponding amount of steps, resulting (hopefully one day) in a device/system that can track the sun as it moves through the day sky.
Also:
I do not want to use a system making use of LDRs and relying on direct sunlight. (So we can skip that debate... :))
The Problem:
My problem is storing the previous calculated elevation/azimuth in order to compare it with the current value and get a difference between the 2.
What I tried to do:
From what I found online, the solution to this problem is as simple as...
Calculate the current value => Use Current and Previous Value to get the difference => Store the current value as the previous value (Something like Previous_Value = Current_Value).
This does not work on my code. Not sure why, not sure how to fix it. Please help...
The Full Code:
The problem is in the "//STEPPER PART"
#include "RTClib.h"
#include <Stepper.h>
#include <SPI.h>
#define DEG_TO_RAD 0.01745329
#define PI 3.141592654
#define TWOPI 6.28318531
#define STEPS 32
RTC_DS1307 rtc;
Stepper Stepper_azimuth(STEPS , 6 , 8 , 7 , 9);
Stepper Stepper_elev(STEPS , 2 , 4 , 3 , 5);
//RTC Setup
#ifndef ESP8266
 while (!Serial); // wait for serial port to connect. Needed for native USB
#endif
 if (! rtc.begin()) {
  Serial.println("Couldn't find RTC");
  Serial.flush();
  abort();
 rtc.adjust(DateTime(F(__DATE__), F(__TIME__)));
 if (! rtc.isrunning()) {
  Serial.println("RTC is NOT running, let's set the time!");
  // When time needs to be set on a new device, or after a power loss, the
  // following line sets the RTC to the date & time this sketch was compiled
  // This line sets the RTC with an explicit date & time, for example to set
  // January 21, 2014 at 3am you would call:
  // rtc.adjust(DateTime(2014, 1, 21, 3, 0, 0));
 // When time needs to be re-set on a previously configured device, the
 // rtc.adjust(DateTime(F(__DATE__), F(__TIME__)));
 //Stepper Setup
 Stepper_azimuth.setSpeed(200); //Set Speed at "x" RPM
 Stepper_elev.setSpeed(200);  //Set Speed at "x" RPM
void loop() {Â Â Â Â
//RTC Part
 DateTime now = rtc.now();
//Position Part
 int hour=now.hour(),minute=now.minute(),second=now.second(),month=now.month(),day=now.day(),year,zone=0;
 float Lon=28.17286*DEG_TO_RAD, Lat=-25.94973*DEG_TO_RAD;
 float T , JD_frac , L0 , M , e , C , L_true , f , R , GrHrAngle , Obl , RA , Decl , HrAngle , elev , azimuth , elev_f , azimuth_f ;
 float azimuth_step_dec , azimuth_step_round , elev_step_dec , elev_step_round ;
 long JD_whole,JDx;
 float elev_diff;
 float elev_prev;
 Serial.print("Longitude and latitude "); Serial.print(Lon/DEG_TO_RAD,3);
 Serial.print(" "); Serial.println(Lat/DEG_TO_RAD,3);Â
 Serial.println("year,month,day,local hour,minute,second,elevation,azimuth");
 year=now.year();
   JD_whole=JulianDate(year,month,day);
   JD_frac=(hour+minute/60.+second/3600.)/24.-.5;
   T=JD_whole-2451545; T=(T+JD_frac)/36525.;
   L0=DEG_TO_RAD*fmod(280.46645+36000.76983*T,360);
   M=DEG_TO_RAD*fmod(357.5291+35999.0503*T,360);
   e=0.016708617-0.000042037*T;
   C=DEG_TO_RAD*((1.9146-0.004847*T)*sin(M)+(0.019993-0.000101*T)*sin(2*M)+0.00029*sin(3*M));
   f=M+C;
   Obl=DEG_TO_RAD*(23+26/60.+21.448/3600.-46.815/3600*T); Â
   JDx=JD_whole-2451545;Â
   GrHrAngle=280.46061837+(360*JDx)%360+.98564736629*JDx+360.98564736629*JD_frac;
   GrHrAngle=fmod(GrHrAngle,360.); Â
   L_true=fmod(C+L0,TWOPI);
   R=1.000001018*(1-e*e)/(1+e*cos(f));
   RA=atan2(sin(L_true)*cos(Obl),cos(L_true));
   Decl=asin(sin(Obl)*sin(L_true));
   HrAngle=DEG_TO_RAD*GrHrAngle+Lon-RA;
  Â
   elev=asin(sin(Lat)*sin(Decl)+cos(Lat)*(cos(Decl)*cos(HrAngle)));      //Elevation in RADS
   elev_f = elev/DEG_TO_RAD;                          //Elevation in Deg
   // Azimuth measured eastward from north.
   azimuth=PI+atan2(sin(HrAngle),cos(HrAngle)*sin(Lat)-tan(Decl)*cos(Lat));  //Azimuth in RADS
   azimuth_f = azimuth/DEG_TO_RAD;                       //Azimuth in Deg
   Serial.print(year); Serial.print(","); Serial.print(month);
   Serial.print(","); Serial.print(day); Serial.print(", ");
   Serial.print(hour-zone); Serial.print(",");
   Serial.print(minute); Serial.print(","); Serial.print(second);
   Serial.print(","); Serial.print(elev/DEG_TO_RAD,3);
   Serial.print(","); Serial.print(azimuth/DEG_TO_RAD,3); Serial.println();
//STEPPER PART
   //For 28BYJ-48 ... 1 Step = 2*5.625deg = 11.25deg of motor rotation.
   //Speed ration is 1/64 ... 1 step = 11.25deg/64 = 0.17578125deg on shaft
   //Direct Drive ... For 1deg change in elev/azimuth (Output Shaft) = 1/0.17578125 = 5.688...steps
   //Calculate angular difference
   //Elevation
  Â
Â
   elev_diff = elev_f-elev_prev;
Â
   //Calculate Steps
   elev_step_dec=elev_diff/0.17578125;
   int elev_step_int = (elev_step_dec+.5);
  // Stepper_elev.step(elev_step_int);  Â
     Â
   azimuth_step_dec=(azimuth)/0.17578125;        //Amount of steps in decimals
   azimuth_step_round=round(azimuth_step_dec);      //Amount of steps rounded
 // Stepper_azimuth.step(azimuth_step_round);
Â
  Â
//Serial Print Stepper Results
   Serial.println(elev_f,30);
   Serial.println(elev_prev,30);
   Serial.println(elev_diff,30);
   Serial.print(elev_step_dec,5);Serial.print(" , ");Serial.print(elev_step_int);Serial.println();
Â
   elev_prev=elev_f;   Â
  Â
delay(60000);
Â
long JulianDate(int year, int month, int day) {
 long JD_whole;
 int A,B;
 if (month<=2) {
  year--; month+=12;
 }Â
 A=year/100; B=2-A+A/4;
 JD_whole=(long)(365.25*(year+4716))+(int)(30.6001*(month+1))+day+B-1524;
 return JD_whole;
