How to store a previous value
How am i able to store a previous value and then compare it with the next value?
For example compare the previous temperature value with the new temperature value to see if it is decreasing or increasing.
You can store a value into a ram variable.
int myOldTemperature;
Look up if( )
Here is a demo code with the use of a couple saved values, one for temperature and one for timing (see the blink without delay example).
const byte temperaturePin = A0;
int temperature;
int lastTemperature;
   lastTemperature = analogRead(temperaturePin); // get initial value
   static unsigned long lastMillis = 0;
   unsigned long interval = 500;
   if (millis() - lastMillis >= interval)
      lastMillis = millis();
      temperature = analogRead(temperaturePin);
      Serial.print("temperature difference = ");
      Serial.println(temperature - lastTemperature);
      lastTemperature = temperature;
Something like this.
int oldTemp;
int newTemp;
Serial.println(abs(oldTemp - newTemp));
Appears you might want to spend time with learning:
Arduino links of interest.
How to use this forum:
Getting started:
https://www.arduino.cc/en/Guide
Listing of downloadable 'Arduino PDFs' :
Either Google >>>- - - - > arduino filetype: pdf
Or
https://www.google.ca/search?q=arduino+filetype%3A+pdf&rlz=1C9BKJA_enCA739CA739&oq=arduino+filetype%3A+pdf&aqs=chrome..69i57j69i65.1385j0j7&hl=en-US&sourceid=chrome-mobile&ie=UTF-8
Listing of downloadable 'C++ PDFs' :
Either Google >>>- - - - > C++ filetype: pdf
Or
https://www.google.ca/search?q=c%2B%2B+filetype%3A+pdf&rlz=1C9BKJA_enCA739CA739&oq=c%2B%2B+filetype%3A+pdf&aqs=chrome..69i57.22790j0j7&hl=en-US&sourceid=chrome-mobile&ie=UTF-8
Arduino cheat sheet:
https://dlnmh9ip6v2uc.cloudfront.net/learn/materials/8/Arduino_Cheat_Sheet.pdf
Watch these:
Arduino programming syntax:
https://m.youtube.com/watch?v=CbJHL_P5RJ8
Arduino arithmetic operators:
https://m.youtube.com/watch?v=UUx0_s-ElSs
Arduino control flow:
https://m.youtube.com/watch?v=QpPGGuaGbCA
Arduino data types:
https://m.youtube.com/watch?v=xmZXWMEltEc
Understanding Destructive LC Voltage Spikes:
https://www.pololu.com/docs/0J16/all
OR
https://www.pololu.com/docs/pdf/0J16/destructive_LC_voltage_spikes.pdf
Why decoupling capacitors:
Some things to read
LCD information:
https://learn.adafruit.com/character-lcds?view=all
OR
https://cdn-learn.adafruit.com/downloads/pdf/character-lcds.pdf?timestamp=1573085286
Reading a schematic:
https://learn.sparkfun.com/tutorials/how-to-read-a-schematic
Language Reference:
https://www.arduino.cc/en/Reference/HomePage
Foundations:
https://www.arduino.cc/en/Tutorial/Foundations
How and Why to avoid delay():
http://playground.arduino.cc/Code/AvoidDelay
Demonstration code for several things at the same time.
http://forum.arduino.cc/index.php?topic=223286.0
How to power a project:
https://learn.sparkfun.com/tutorials/how-to-power-a-project/all
Ladyada's Learn Arduino - Lesson #0:
Multitasking:
Part 1:
https://learn.adafruit.com/multi-tasking-the-arduino-part-1?view=all
Part 2:
https://learn.adafruit.com/multi-tasking-the-arduino-part-2?view=all
Part 3:
https://learn.adafruit.com/multi-tasking-the-arduino-part-3?view=all
Sparkfun Tutorials:
https://learn.sparkfun.com/tutorials?page=all
Micro Controllers:
https://learn.adafruit.com/mcus-how-do-they-work?view=all
Useful links:
https://forum.arduino.cc/index.php?topic=384198.0
Arduino programming traps, tips and style guide:
http://www.gammon.com.au/forum/?id=12153
Arduino programming course:
https://startingelectronics.org/software/arduino/learn-to-program-course/
Jeremy Blume:
https://m.youtube.com/playlist?list=PLA567CE235D39FA84
Arduino products:
https://www.arduino.cc/en/Main/Products
Motors/MOSFETs
http://www.gammon.com.au/motors
Making a library
https://www.arduino.cc/en/Hacking/libraryTutorial
Switches:
http://www.gammon.com.au/forum/?id=11955
https://www.amazon.ca/Arduino-Cookbook-Recipes-Enhance-Projects/dp/1449313876/ref=sr_1_1?ie=UTF8&qid=1522801721&sr=8-1&keywords=arduino+cookbook
Soldering FYI
https://m.youtube.com/watch?v=eBIjsZ1dcT0
https://m.youtube.com/watch?v=6PB0u8irn-4
https://m.youtube.com/watch?v=5uiroWBkdFY
https://m.youtube.com/watch?v=lpgMY1JeOAA
https://m.youtube.com/watch?v=_6tpQE7ptqo
https://m.youtube.com/watch?v=L_DIpklxXcI
https://m.youtube.com/watch?v=b15MMzb_GWw
Tips and Traps
Share tips you have come across, 900+ posts:
https://forum.arduino.cc/index.php?topic=445951.0
Debug discussion:
https://forum.arduino.cc/index.php?topic=215334.msg1575801#msg1575801
Frequently Asked Questions:
https://www.arduino.cc/en/main/FAQ#toc10
SMD soldering:
SMD soldering
How to make and post a schematic:
How to make a schematic.
Number 'type's.
  • boolean (8 bit) - simple logical true/false, Arduino does not use single bits for bool
  • byte (8 bit) - unsigned number from 0 to 255
  • char (8 bit) - signed number from -128 to 127. The compiler will attempt to interpret this data type as a character in some circumstances, which may yield unexpected results
  • unsigned char (8 bit) - same as 'byte'; if this is what you're after, you should use 'byte' instead, for reasons of clarity
  • word (16 bit) - unsigned number from 0 to 65535
  • unsigned int (16 bit)- the same as 'word'. Use 'word' instead for clarity and brevity
  • int (16 bit) - signed number from -32768 to 32767. This is most commonly what you see used for general purpose variables in Arduino example code provided with the IDE
  • unsigned long (32 bit) - unsigned number from 0 to 4,294,967,295. The most common usage of this is to store the result of the millis() function, which returns the number of milliseconds the current code has been running
  • long (32 bit) - signed number from -2,147,483,648 to 2,147,483,647
    float (32 bit) - signed number from -3.4028235E38 to 3.4028235E38. Floating point on the Arduino is not native; the compiler has to jump through hoops to make it work. If you can avoid it, you should. We'll touch on this later. Sparkfun.
You select the 'type' best suited for your variables.
ex:
  • your variable does not change and it defines a pin on the Arduino. const byte limitSwitchPin = 34;
  • since an analog variable can be 0 to 1023, a byte will not do, you can select 'int'. int temperature;
  • if your variable needs to be within -64 to +64 a 'char' will do nicely. char joystick;
  • if your variable is used for ASCII then you need type 'char', char myText[ ] = {"Raspberry Pie Smells"};
  • if your variable enables some code then boolean can be used. boolean enableFlag = false;
  • millis() returns the time in ms since rebooting, unsigned long currentTime = millis();
    etc.
Oh, and have fun too :slight_smile: !
Getting started:
Or
Or
Watch these:
Arduino data types:
OR
Some things to read
LCD information:
OR
Language Reference:
Foundations:
Multitasking:
Part 1:
Part 2:
Part 3:
Sparkfun Tutorials:
Micro Controllers:
Useful links:
Jeremy Blume:
Arduino products:
Motors/MOSFETs
Making a library
Switches:
Soldering FYI
Tips and Traps
Debug discussion:
SMD soldering:
SMD soldering
Number 'type's.
ex:
    etc.
Thank you. I have used this code below, but the 'previousValue' does not update on the serial monitor. It displays the first value and then does not change despite me changing the temperature.
// Initialise variables
int Temperature;
int previousValue;
Serial.begin(9600); // Serial monitor comms
previousValue = map(((analogRead(A0) - 20) * 3.04), 0, 1023, -40, 125);
analogRead(A0);
Temperature = map(((analogRead(A0) - 20) * 3.04), 0, 1023, -40, 125);
Serial.print(previousValue);
Serial.print(Temperature);
int Temperature;
int previousValue;
analogRead(A0);
[/quote]
// Initialize variables
int Temperature;
int previousValue;
analogRead(A0);
Serial.print(\t);
Serial.print(\t);
Serial.println( abs(previousValue - Temperature));
previousValue = Temperature;
Thanks for your help LarryD!
How am I then able to print if the temperature is increasing or decreasing? I have tried if, else if and else statement but it hasnt had any effect but I dont understand why.
if (Temperature>previousValue){
Serial.print("Up");
else if (Temperature<previousValue){
Serial.print("Down");
else {
int Temperature;
int previousValue;
analogRead(A0);
Serial.print(\t);
Serial.print(\t);
Serial.print("Up");
Serial.println(“Same”);
} //END of loop( )
