Comparing RFID Tags
I need to compare two different char arrays, however, I've run into a wall. The first array is the RFID tag being swiped and the other is a preset one 0F03029400.
I hope someone can help point me in the right direction and help me realize what im doing wrong. Most of the code is from an arduino tutorial:
// Modified by Worapoht K.
#include <SoftwareSerial.h>
int  val = 0;
int ledRed = 3;
char code[10];   // this value is the ID being swiped
int bytesread = 0;
//char admincard[] = "0F03029400";
#define rxPin 8
#define txPin 9
// RFID reader SOUT pin connected to Serial RX pin at 2400bps to pin8
  Serial.begin(2400);  // Hardware serial for Monitor 2400bps
  pinMode(2,OUTPUT);       // Set digital pin 2 as OUTPUT to connect it to the RFID /ENABLE pin
  digitalWrite(2, LOW);    // Activate the RFID reader
  pinMode(ledRed, OUTPUT);
  SoftwareSerial RFID = SoftwareSerial(rxPin,txPin);
  RFID.begin(2400);
  if((val = RFID.read()) == 10)
  {   // check for header
    bytesread = 0;
    while(bytesread<10)
    {  // read 10 digit code
      val = RFID.read();
      if((val == 10)||(val == 13))
      {  // if header or stop bytes before the 10 digit reading
        break;                       // stop reading
      code[bytesread] = val;         // add the digit
      bytesread++;                   // ready to read next digit
    //This is where I am having trouble.
    if(bytesread == 10)
    {  // if 10 digit read is complete
     if (code == "0F03029400"){ //"0F03029400"
         Serial.println(" CORRECT TAG READ ");
         digitalWrite(ledRed, HIGH);
       Serial.print("TAG code is: ");   // possibly a good TAG
       Serial.println(code);            // print the TAG code
    bytesread = 0;
    delay(500);                       // wait for a second
  digitalWrite(ledRed, LOW);
You have an array of bytes from the card scanned, in code.
You have an array of bytes from another card, in admincard (currently commented out).
boolean matched = true;
for(int i=0; i<10; i++)
  if(code[i] != admincode[i])
     matched = false;
if(matched)
   // The cards match
   // Well, they don't
Wow that is brilliant. I never thought to loop through each byte of the array. Thanks so much
EDIT: And it works, 100%
