Will this work? So that the if statement will become true when the sensor is in between 49 and 99?
Example:
If( 49 < sensor < 99)
do something here
Example:
do something here
No. That will always be true. You need two test clauses linked with a logical and (&&).
No, use this idiom:
If (49 < sensor and sensor < 99)
//do something here
'and' is the modern C++ alternative to &&, ditto 'or' for || and 'not' for !
I think you are thinking of Python syntax for range comparisons, which is different.
In C and C++ "a < b < c" parses as "(a < b) < c", which compares a boolean to a number, not what you were expecting.
Will this be correct?
if ((Sensor > 49 && Sensor < 99) && Flag == true)
Do something
Yes, but usually when testing booleans, you would drop the == true.
Oh sorry I am actually creating a push notification when the sensor is triggered so i added a flag in the variables but it should be "false" sorry
What would be the difference between this two? And which would be better to use?
if ((Sensor > 49 && Sensor < 99) && Flag == false)
//Do something here
if ((Sensor > 49 || Sensor < 99) && Flag == false)
//Do something here
The second is nonsense - its a tautology, Sensor must always be either less than 99 or more than 49.
Why not use
I'll try this and update you later with the results
Thanks it works like a charm!
