I bought a second physically identical UNO R3, but when I put the same sketch into both, the new one does not upload. Some suggestions would be appreciated.
Welcome to the forum
At a guess you have not installed the driver for the second one. Is it recognised by the Operating System when you plug it in to the PC ?
Ah OK thanks I've got AI's full explanation. I should be OK. I appreciate you being so instantly available. thanks....
Got the COM port specified.
But exit status 1 means a compilation error, doesn't it? The IDE is not attempting to upload anything.
Please post the full set of error messages, and the complete code. Use code tags for both please.
You mean ChatGPT? Don't fall for it's confident sounding explanations, it's as likely to be wrong as the average person, because that's who it learned from.
Driver should not be the problem if it's physically identical ![]()
Mind sharing the solution? Others can learn from it.
