I want to create a game where people have to put the right objects in the right place, in order for a door to open. To get the job the done, I thought of doing it with RFID sensors and found this code(exacly what I need).
The problem is that I cant upload it due to this error: "Compilation error: 'dump_byte_array' was not declared in this scope"
I have no idea how to solve it, can anybody help me?
#define DEBUG
// LIBRARIES
#include <SPI.h>
#include <MFRC522.h>
// GLOBALS
// The number of RFID readers
const byte numReaders = 3;
// Each reader has a unique Slave Select pin
const byte ssPins[] = {2, 3, 4};
// They'll share the same reset pin
const byte resetPin = 8;
// Initialise an array of MFRC522 instances representing each reader
MFRC522 mfrc522 [numReaders];
// The sequence of NFC tag IDs required to solve the puzzle
const String correctIDs[] = {"3acbbd49", "ca767564", "3af4f763", "87e0f0a4"};
// The tag IDs currently detected by each reader
String currentIDs [numReaders];
// This pin will be driven LOW to release a lock when puzzle is solved
const byte lockPin = A0;
* Initialisation
#ifdef DEBUG
// Initialise serial communications channel with the PC
Serial.println (F("Serial communication started"));
#endif
// Set the lock pin as output and secure the lock
pinMode(lockPin, OUTPUT);
digitalWrite(lockPin, HIGH);
// Initialise the SPI bus
SPI.begin();
for (uint8_t i=0; i<numReaders; i++) {
// Initialise the reader
// Note that SPI pins on the reader must always be connected to certain
// Arduino pins (on an Uno, MOSI=> pin11, MISO=> pin12, SCK=>pin13)
// The Slave Select (SS) pin and reset pin can be assigned to any pin
mfrc522[i].PCD_Init(ssPins[i],resetPin);
// Set the gain to max - not sure this makes any difference..
//mfrc522[i].PCD_SetAntennaGain (MFRC522:: PCD_RxGain::RxGain_max);
// Dump some debug information to the serial monitor
Serial.print(F("Reader #"));
Serial.print(i);
Serial.print(F(" initialised on pin "));
Serial.print(String (ssPins[i]));
Serial.print(F(". Antenna strength: "));
Serial.print(mfrc522[i].PCD_GetAntennaGain ());
Serial.print(F(". Version : "));
mfrc522[i].PCD_DumpVersionToSerial();
// slight delay before activating next reader
delay(100);
Serial.println (F("--- END SETUP ---"));
// Assume that the puzzle has been solved
boolean puzzleSolved = true;
// Assume that the tags have not changed since last reading
boolean changedValue = false;
// Loop through each reader
// Initialise the sensor
mfrc522[i].PCD_Init();
// String to hold the ID detected by each sensor
String readRFID = "";
// If the sensor detects a tag and is able to read it
if (mfrc522[i].PICC_IsNewCardPresent() && mfrc522[i].PICC_ReadCardSerial()) {
// Extract the ID from the tag
readRFID = dump_byte_array(mfrc522[i].uid.uidByte, mfrc522[i].uid.size);
// If the current reading is different from the last known reading
if (readRFID != currentIDs [i]) {
// Set the flag to show that the puzzle state has changed
changedValue = true;
// Update the stored value for this sensor
currentIDs[i] = readRFID;
// If the reading fails to match the correct ID for this sensor
if (currentIDs[i] = correctIDs[i]) {
// The puzzle has not been solved
puzzleSolved = false;
// Halt PICC
mfrc522[i].PICC_HaltA();
// Stop encryption on PCD
mfrc522[i].PCD_StopCrypto1();
// If the changedValue flag has been set, at least one sensor has changed
if (changedValue) {
// Dump to serial the current state of all sensors
Serial.print (F("Reader #"));
Serial.print (String (i));
Serial.print (F(" on Pin #"));
Serial.print(String ((ssPins[i])));
Serial.print (F(" detected tag: "));
Serial.println (currentIDs[i]);
Serial.println(F("---"));
// If the puzzleSolved flag is set, all sensors detected the correct ID
if (puzzleSolved){
onSolve();
// Add a short delay before next polling sensors
//delay(100);
void onSolve () {
#ifdef DEBUG
// Print debugging message
Serial.println (F("Puzzle Solved!"));
#endif
// Release the lock
digitalWrite(lockPin, LOW);
while(true){}
