Hi , I am having this error in the code, I already :
- Check your connections. Your board needs to be connected with a data USB cable (charge-only cables will not work). Make sure the cable is fully inserted in the port on each end. Try a different USB cable, and avoid hubs and other adapters if possible. Remove connections to the board pins, especially the 0 (RX) and 1 (TX) digital pins.
- Check your board and port selections. In the top menu bar, make sure the correct board is selected in Tools > Board, and that you’ve selected the right port in Tools > Port. Try disconnecting and reconnecting your board if you’re unsure which port is being used (close and reopen the Port menu to refresh the list). For more information, see Select the right port and board.
Make sure other applications aren’t using the port. Close other instances of the IDE, serial monitors, and any other applications that may be using the port. See Find and stop process blocking a port.
But still having the same problem, how can i fix it ?
this is the code :
#include <MPU6050.h>
#include <MPU6050_6Axis_MotionApps20.h>
#include <MPU6050_9Axis_MotionApps41.h>
#include <helper_3dmath.h>
#include <Wire.h>
MPU6050 mpu;
#define Pi 3.14159
#define EN34 6 //m2 enable
#define EN12 5 //m1 enable
#define M2neg 8
#define M2pos 9
#define M1neg 10
#define M1pos 11
float K1 = 1, K2 = 0.2394, K3 = -34.1812, K4 = -3.2186;
float x1, x2, x3, x4;
float input;
long accelX, accelY, accelZ;
float gForceX, gForceY, gForceZ;
long gyroXCalli = 0, gyroYCalli = 0, gyroZCalli = 0;
long gyroXPresent = 0, gyroYPresent = 0, gyroZPresent = 0;
long gyroXPast = 0, gyroYPast = 0, gyroZPast = 0;
float rotX, rotY, rotZ;
float angelX = 0, angelY = 0, angelZ = 0;
long timePast = 0;
long timePresent = 0;
void setPwmFrequency(int pin, int divisor) {
byte mode;
if (pin == 5 || pin == 7 || pin == 9 || pin == 10) {
switch (divisor) {
case 1: mode = 0x01; break;
case 8: mode = 0x02; break;
case 64: mode = 0x03; break;
case 256: mode = 0x04; break;
case 1024: mode = 0x05; break;
default: return;
if (pin == 5 || pin == 6) {
TCCR0B = TCCR0B & 0b11111000 | mode;
TCCR1B = TCCR1B & 0b11111000 | mode;
} else if (pin == 3 || pin == 11) {
switch (divisor) {
case 32: mode = 0x03; break;
case 64: mode = 0x04; break;
case 128: mode = 0x05; break;
case 256: mode = 0x06; break;
case 1024: mode = 0x07; break;
default: return;
TCCR2B = TCCR2B & 0b11111000 | mode;
void setUpMPU() {
// power management
Wire.beginTransmission(0b1101000); // Start the communication by using address of MPU
Wire.write(0x6B); // Access the power management register
Wire.write(0b00000000); // Set sleep = 0
Wire.endTransmission(); // End the communication
// configure gyro
Wire.write(0x1B); // Access the gyro configuration register
// configure accelerometer
Wire.write(0x1C); // Access the accelerometer configuration register
void getGyroValues() {
Wire.write(0x43); // Access the starting register of gyro readings
Wire.requestFrom(0b1101000, 6); // Request for 6 bytes from gyro registers (43 - 48)
while (Wire.available() < 6)
; // Wait untill all 6 bytes are available
gyroXPresent = Wire.read() << 8 | Wire.read(); // Store first two bytes into gyroXPresent
gyroYPresent = Wire.read() << 8 | Wire.read(); // Store next two bytes into gyroYPresent
gyroZPresent = Wire.read() << 8 | Wire.read(); //Store last two bytes into gyroZPresent
void callibrateGyroValues() {
for (int i = 0; i < 5000; i++) {
getGyroValues();
gyroXCalli = gyroXCalli + gyroXPresent;
gyroYCalli = gyroYCalli + gyroYPresent;
gyroZCalli = gyroZCalli + gyroZPresent;
gyroXCalli = gyroXCalli / 5000;
gyroYCalli = gyroYCalli / 5000;
gyroZCalli = gyroZCalli / 5000;
void readAndProcessAccelData() {
Wire.write(0x3B);
accelX = Wire.read() << 8 | Wire.read();
accelY = Wire.read() << 8 | Wire.read();
accelZ = Wire.read() << 8 | Wire.read();
processAccelData();
void processAccelData() {
gForceX = accelX / 16384.0;
gForceY = accelY / 16384.0;
gForceZ = accelZ / 16384.0;
void readAndProcessGyroData() {
gyroXPast = gyroXPresent; // Assign Present gyro reaging to past gyro reading
gyroYPast = gyroYPresent; // Assign Present gyro reaging to past gyro reading
gyroZPast = gyroZPresent; // Assign Present gyro reaging to past gyro reading
timePast = timePresent; // Assign Present time to past time
timePresent = millis(); // get the current time in milli seconds, it is the present time
void getAngularVelocity() {
rotX = gyroXPresent / 131.0;
rotY = gyroYPresent / 131.0;
rotZ = gyroZPresent / 131.0;
void calculateAngle() {
// same equation can be written as
// angelZ = angelZ + ((timePresentZ - timePastZ)*(gyroZPresent + gyroZPast - 2*gyroZCalli)) / (2*1000*131);
// 1/(1000*2*131) = 0.00000382
// 1000 --> convert milli seconds into seconds
// 2 --> comes when calculation area of trapezium
// substacted the callibated result two times because there are two gyro readings
angelX = angelX + ((timePresent - timePast) * (gyroXPresent + gyroXPast - 2 * gyroXCalli)) * 0.00000382;
angelY = angelY + ((timePresent - timePast) * (gyroYPresent + gyroYPast - 2 * gyroYCalli)) * 0.00000382;
angelZ = angelZ + ((timePresent - timePast) * (gyroZPresent + gyroZPast - 2 * gyroZCalli)) * 0.00000382;
pinMode(EN34, OUTPUT);
pinMode(EN12, OUTPUT);
pinMode(M2neg, OUTPUT);
pinMode(M2pos, OUTPUT);
pinMode(M1neg, OUTPUT);
pinMode(M1pos, OUTPUT);
//Serial.begin(115200);
Serial.println("Initialize MPU6050");
//checkSettings();
Wire.begin();
setUpMPU();
callibrateGyroValues();
//float Vector rawAccel = mpu.readRawAccel();
//float Vector normAccel = mpu.readNormalizeAccel();
//float input=(normAccel.YAxis-0.3)*10;
//Serial.println(input);
//x3=input/57.3;
// === Read acceleromter data === //
Serial.print(" Accel (g)");
float readAndProcessAccelData();
float readAndProcessGyroData();
getGyroValues(); // get gyro readings
getAngularVelocity(); // get angular velocity
calculateAngle(); // calculate the angle
input = rotY;
x3 = input;
int pwm = abs(constrain(-K3 * x3 * 6.5, -254, 254));
analogWrite(EN34, pwm - 4);
analogWrite(EN12, pwm);
Serial.println(pwm);
if (input < -7) {
digitalWrite(M1pos, HIGH);
digitalWrite(M1neg, LOW);
digitalWrite(M2pos, HIGH);
digitalWrite(M2neg, LOW);
} else if (input > 7) {
digitalWrite(M1pos, LOW);
digitalWrite(M1neg, HIGH);
digitalWrite(M2pos, LOW);
digitalWrite(M2neg, HIGH);
