Compilation error: expected unqualified-id before
HI.
i am a real newbie on this and would really like some guidens on this one.
i have managed to fix all the other errors, but this last one i cant seem to figure out.
The program is:
#include <ESP8266WiFi.h>
#include <WiFiClientSecure.h>
#include <base64.h>
// Your network SSID and password
const char* ssid = "YourNetworkId";
const char* password = "YourNetworkPassword";
const char* account_sid = "YourTwilioAccountSID";
const char* auth_token = "YourAuthToken";
String from_number      = "+16505551111";
String to_number        = "+16505552222";
String message_body     = "Hello from the NodeMCU.";
// Find the api.twilio.com SHA1 fingerprint using,
//  echo | openssl s_client -connect api.twilio.com:443 | openssl x509 -fingerprint
const char fingerprint[] = "BC B0 1A 32 80 5D E6 E4 A2 29 66 2B 08 C8 E0 4C 45 29 3F D0";
String urlencode(String str) {
  String encodedString = "";
  char c;
  char code0;
  char code1;
  char code2;
  for (int i = 0; i < str.length(); i++) {
    c = str.charAt(i);
    if (c == ' ') {
      encodedString += '+';
    } else if (isalnum(c)) {
      encodedString += c;
      code1 = (c & 0xf) + '0';
      if ((c & 0xf) > 9) {
        code1 = (c & 0xf) - 10 + 'A';
      c = (c >> 4) & 0xf;
      code0 = c + '0';
      if (c > 9) {
        code0 = c - 10 + 'A';
      code2 = '\0';
      encodedString += '%';
      encodedString += code0;
      encodedString += code1;
    yield();
  return encodedString;
String get_auth_header(const String& user, const String& password) {
  size_t toencodeLen = user.length() + password.length() + 2;
  char toencode[toencodeLen];
  memset(toencode, 0, toencodeLen);
  snprintf(toencode, toencodeLen, "%s:%s", user.c_str(), password.c_str());
  String encoded = base64::encode((uint8_t*)toencode, toencodeLen - 1);
  String encoded_string = String(encoded);
  std::__cxx11::basic_string<char>
  // Strip newlines (after every 72 characters in spec)
  while (i < encoded_string.length()) {
    i = encoded_string.indexOf('\n', i);
    if (i == -1) {
    encoded_string.remove(i, 1);
  return "Authorization: Basic " + encoded_string;
  Serial.begin(115200); // 115200 or 9600
  delay(1000);        // Give the serial connection time to start before the first print.
  Serial.println(""); // Newline after garbage characters.
  Serial.println(F("+++ Setup."));
  Serial.println("+ Connect to WiFi. ");
  WiFi.begin(ssid, password);
    Serial.print(".");
  Serial.println("");
  Serial.print("+ Connected to WiFi, IP address: ");
  // Use WiFiClientSecure to create a TLS 1.2 connection.
  //  Note, using a cert fingerprint is required.
  WiFiClientSecure client;
  client.setFingerprint(fingerprint);
  Serial.printf("+ Using fingerprint '%s'\n", fingerprint);
  const char* host = "api.twilio.com";
  const int   httpsPort = 443;
  Serial.print("+ Connecting to ");
  Serial.println(host);
  if (!client.connect(host, httpsPort)) {
    Serial.println("- Connection failed.");
    return; // Skips to loop();
  Serial.println("+ Connected.");
  Serial.println("+ Post an HTTP send SMS request.");
  String post_data = "To=" + urlencode(to_number)
                     + "&From=" + urlencode(from_number)
                     + "&Body=" + urlencode(message_body);
  String auth_header = get_auth_header(account_sid, auth_token);
  String http_request = "POST /2010-04-01/Accounts/" + String(account_sid) + "/Messages HTTP/1.1\r\n"
                        + auth_header + "\r\n"
                        + "Host: " + host + "\r\n"
                        + "Cache-control: no-cache\r\n"
                        + "User-Agent: ESP8266 Twilio Example\r\n"
                        + "Content-Type: application/x-www-form-urlencoded\r\n"
                        + "Content-Length: " + post_data.length() + "\r\n"
                        + "Connection: close\r\n"
                        + "\r\n"
                        + post_data
                        + "\r\n";
  client.println(http_request);
  // Read the response.
  String response = "";
  while (client.connected()) {
    String line = client.readStringUntil('\n');
    response += (line);
    response += ("\r\n");
  Serial.println("+ Connection is closed.");
  Serial.println("+ Response:");
  Serial.println(response);
  Serial.println(F("+ Starting the loop."));
And this is the error message:
C:\Users\Peter\Desktop\ESP32_ESP8266\HttpTwPost\HttpTwPost.ino: In function 'String get_auth_header(const String&, const String&)':
C:\Users\Peter\Desktop\ESP32_ESP8266\HttpTwPost\HttpTwPost.ino:63:3: error: expected unqualified-id before 'while'
   63 |   while (i < encoded_string.length()) {
exit status 1
Compilation error: expected unqualified-id before 'while'
Thank you in advance for any tip how to solve this.
Best regards.
Welcome to the forum
Can you please explain what this line of code does ?
Hi and big thanks for the welcome!
This is what the code that i downloaded looked like:
// Code from:
//  https://github.com/TwilioDevEd/twilio_esp8266_arduino_example
// Documentation:
//  https://www.twilio.com/docs/sms/tutorials/how-to-send-sms-messages-esp8266-cpp
// Fingerprint note,
//  https://github.com/TwilioDevEd/twilio_esp8266_arduino_example/issues/1
//  echo | openssl s_client -connect api.twilio.com:443 | openssl x509 -fingerprint | grep Fingerprint
//  SHA1 Fingerprint=0E:15:35:A9:DD:DB:63:DF:CE:D3:02:2E:A8:6A:5A:E0:28:9B:FF:26
//  SHA1 Fingerprint=BC:B0:1A:32:80:5D:E6:E4:A2:29:66:2B:08:C8:E0:4C:45:29:3F:D0
 * Sample runtime output,
+++ Setup.
+ Connect to WiFi.
+ Connected to WiFi, IP address: 192.168.1.76
+ Using fingerprint '0E 15 35 A9 DD DB 63 DF CE D3 02 2E A8 6A 5A E0 28 9B FF 26'
+ Connecting to api.twilio.com
+ Connected.
+ Response:
HTTP/1.1 201 CREATED
Date: Thu, 16 Jul 2020 20:39:49 GMT
Content-Type: application/xml
Content-Length: 878
Connection: close
Twilio-Concurrent-Requests: 1
Twilio-Request-Id: RQe4fbdd142fca4b2fab24697e74006837
Twilio-Request-Duration: 0.116
Access-Control-Allow-Origin: *
Access-Control-Allow-Headers: Accept, Authorization, Content-Type, If-Match, If-Modified-Since, If-None-Match, If-Unmodified-Since
Access-Control-Allow-Methods: GET, POST, DELETE, OPTIONS
Access-Control-Expose-Headers: ETag
Access-Control-Allow-Credentials: true
X-Powered-By: AT-5000
X-Shenanigans: none
X-Home-Region: us1
X-API-Domain: api.twilio.com
Strict-Transport-Security: max-age=31536000
<?xml version='1.0' encoding='UTF-8'?>
<TwilioResponse><Message><Sid>SM8a...88237</Sid><DateCreated>Thu, 16 Jul 2020 20:39:49 +0000</DateCreated><DateUpdated>Thu, 16 Jul 2020 20:39:49 +0000</DateUpdated><DateSent/><AccountSid>ACa...3</AccountSid><To>+16504837603</To><From>+16505552222</From><MessagingServiceSid/><Body>Hello.</Body><Status>queued</Status><NumSegments>1</NumSegments><NumMedia>0</NumMedia><Direction>outbound-api</Direction><ApiVersion>2010-04-01</ApiVersion><Price/><PriceUnit>USD</PriceUnit><ErrorCode/><ErrorMessage/><Uri>/2010-04-01/Accounts/ACa...3/Messages/SM8a...237</Uri><SubresourceUris><Media>/2010-04-01/Accounts/ACa...3/Messages/SM8a...237/Media</Media></SubresourceUris></Message></TwilioResponse>
#include <base64.h>
  char c;
  char code0;
  char code1;
  char code2;
    c = str.charAt(i);
    if (c == ' ') {
      encodedString += c;
      c = (c >> 4) & 0xf;
      code0 = c + '0';
      if (c > 9) {
      code2 = '\0';
    yield();
  std::string::size_type i = 0;
    if (i == -1) {
    Serial.print(".");
  Serial.println("");
                        + "\r\n"
                        + post_data
                        + "\r\n";
    response += (line);
all i have done here so far is adding #include <base64.h> that was missing.
And then i got this error:
C:\Users\Peter\AppData\Local\Temp\.arduinoIDE-unsaved202503-14900-1dxucen.7jiq\sketch_jan3a\sketch_jan3a.ino: In function 'String get_auth_header(const String&, const String&)':
C:\Users\Peter\AppData\Local\Temp\.arduinoIDE-unsaved202503-14900-1dxucen.7jiq\sketch_jan3a\sketch_jan3a.ino:105:16: error: incomplete type 'std::string' {aka 'std::__cxx11::basic_string<char>'} used in nested name specifier
  105 |   std::string::size_type i = 0;
C:\Users\Peter\AppData\Local\Temp\.arduinoIDE-unsaved202503-14900-1dxucen.7jiq\sketch_jan3a\sketch_jan3a.ino:107:10: error: 'i' was not declared in this scope
  107 |   while (i < encoded_string.length()) {
exit status 1
Compilation error: incomplete type 'std::string' {aka 'std::__cxx11::basic_string<char>'} used in nested name specifier
I then tried to change std::string::size_type i = 0; to std::__cxx11::basic_string<char>
and then that error did not show any more and i am left with:
exit status 1
I do not know if that action did something else that is not good?
Best regards.
Huh, but can you tell me why you need that "std::string::size_type", instead of just an "int" (or "unsigned int", or "size_t")?? You're just stripping newlines, it isn't rocket science!
int i = 0; did the trick =)
Thanks!
(I still have a lot to learn, so thanks for your patience! :slight_smile:
